Issues/Maintenance with 3rd gen?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 4runnerToTacoma, Apr 12, 2024.
  1. Apr 12, 2024 at 7:51 PM
    4runnerToTacoma
    4runnerToTacoma [OP] Well-Known Member
    22 SR5 V6 Taco, 03 SR5 V6 4runner
    I see almost no issues here. So if anyone has some, please leave a comment. Even if its minor, i wanted to try old threads when 3rd gen was brand new, like 2016-2017 but couldnt
  2. Apr 12, 2024 at 7:53 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Trans jerks like an old lady…
    Stevie17 likes this.
  3. Apr 12, 2024 at 8:00 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    The whole truck is an issue.
    It's worse on Fridays too. Weird.
  4. Apr 12, 2024 at 11:35 PM
    OZ TRD
    OZ TRD Well-Known Member
    Central Coast CA
    6sp Manual TRD PRO - Lunar Rock '21
    Evo A SmartCap, Cali Raised Sliders (0 degree), 2WD low Mod, Puddle Pods, 3 switch overhead panel, 8 slot middle console panel, Custom driver's switch panel, Rek Gens, 265 75 16 Falkens, lil B Bed Stiffeners, All new Speakers, Diff Breather, AC Drain, Many interior bits...
    Are you sure you are reading THIS board???
    When I started reading, I expected to see tacos explode around me at every turn...
    Boards are where all issues are vented... for anything...
    Tacos are still one of the more reliable vehicles for sale in this country...
    Stevie17, turbosnail and 23MGM like this.
  5. Apr 12, 2024 at 11:43 PM
    23MGM
    23MGM Well-Known Member
    2023 TRD Off Road
    The truck is fine. Fill it with oil and gas from time to time and worry about more important things like what's for breakfast.
    Stevie17 and Steves104x4 like this.
  6. Apr 13, 2024 at 1:14 AM
    mike s
    mike s Well-Known Member
    South Carolina
    2019 TRD OR
    I have a 2019 with 110000 miles, I keep having tires wear out every 50000 miles
  7. Apr 13, 2024 at 7:45 AM
    4runnerToTacoma
    Yea that is true, I actually had that in 03 4runner too, although it never affected engine power and acceleration.
    I know truck is reliable guys, but I was wondering if there were any issues that people didn't write up, like 2016-2017 models maybe?
  8. Apr 13, 2024 at 8:09 AM
    Clearwater Bill
    Billy
    Largo Florida
    There are hundreds of threads across several topics.
    You can't really search by 'tell me bad stuff about 16 and 17 models'. But you can search by specific topic.
    Try transmission, leaking differential, out of round brake drums, head unit rebooting, 3rd brake light leak, wind noise, CPS failure.
    Also understand this was 7-8 years ago. For the low % of afflicted units, most would have been repaired long ago.
  9. Apr 13, 2024 at 8:24 AM
    Stevie17
    Stevie17 Well-Known Member
    Stevie
    Crossville, Alabama
    24 Celestial Silver Sr 5 DCSB 4x4
    Bought my 17 with 77xxx on it , did the usual maintenance on it . Plugs , fluids and filters and runs like a brand new 1. Service records showed rotors resurfaced and regular oil changes done at the dealership. I’m the 3rd owner , certified preowned from a Toyota dealer. :thumbsup:
    Koolbreeze7 and Lunar Squirrel like this.
  10. Apr 13, 2024 at 8:28 AM
    Lunar Squirrel
    Lunar Squirrel Well-Known Member
    24 TRDOR Hybrid SPF100-Octane
    I had a new ‘16. Sure back then it had most of the early teething issues that have been shared repeatedly here. Those were annoying, then corrected, and I liked it so much, that I bought my ‘18.
    My best advice is don’t assume just because “cracked coolant pipe” and “front timing cover leak” are popular topics here, that they affect the majority of trucks Toyota sold. In fact, while it’s little consolation to someone who had either problem, the odds of yours having those issues are between slim and none. In other words, research here, but separate the anecdotal mishaps & subjective feedback from the statistically relevant.
    Case in point: Consumer Reports initially placed the then new ‘16-‘17 Tacomas on its avoid list, (and many people here trolled and generally acted like the sky was falling….) But unsurprisingly, today CR highly recommends those same years as reliable used trucks.
    Good luck.
    turbosnail, Koolbreeze7 and Stevie17 like this.
  11. Apr 13, 2024 at 8:55 AM
    mangler
    mangler Well-Known Member
    Saskatchewan, Canada
    1998 Tacoma 4x4
    2016 here, 122,000 km , 3 issues I've had
    1. Door weather stripping noise with heavy cross winds (fixed with clear tubing to beef up)
    2. Heated seat failure ( removed bad connector and soldered new wires)
    3. Front body mount bushings ( replaced with poly bushings)
    All cheap easy fixes, all other issues I've had were
    chasing vibrations and issues from installing 2" lift so self induced problems
  12. Apr 13, 2024 at 9:24 AM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    I had a handful of first year TSBs to address but after those my truck has only required regular maintenance. I did have a braking vibration at 40K miles. New PowerStop rotors and pads made the vibration go away.
    First year problems: transmission came one quart low on fluid, weeping rearend, CPS, trip meter random resets.
  13. Apr 13, 2024 at 2:07 PM
    Kobe_lee24
    Kobe_lee24 Well-Known Member
    SOCAL
    2020 Tacoma TRD OR
    If you keep it stock and do your periodic maintenance itll last forever
  14. Apr 13, 2024 at 2:42 PM
    4runnerToTacoma
