Issues ordering from Factory ?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by cgalloni, Mar 25, 2021.
  1. Mar 25, 2021 at 12:36 PM
    cgalloni
    cgalloni [OP] Well-Known Member
    Recently place the order for a 2021 TRD off Road Cement Manual ,no crazy packages just the Tech package with the LED headlights.
    Inventory manager called from the dealer yesterday that the order is in the system and that we have to wait for the factory to accept the order, he stated it could be a possibility of the order being rejected but its unlikely .
    Has any of you experience your order being canceled by the factory?
    Would appreciate your feedback
  2. Mar 25, 2021 at 12:43 PM
    OZ TRD
    OZ TRD Well-Known Member
    Central Coast CA
    6sp Manual TRD PRO - Lunar Rock '21
    Evo A SmartCap, Cali Raised Sliders (0 degree), 2WD low Mod, Puddle Pods, 3 switch overhead panel, 8 slot middle console panel, Custom driver's switch panel, Rek Gens, 265 75 16 Falkens, lil B Bed Stiffeners, All new Speakers, Diff Breather, AC Drain, Many interior bits...
    DogStar84 and farmtacoma like this.
  3. Mar 25, 2021 at 12:47 PM
    DogStar84
    DogStar84 Well-Known Member
    Northern California
    2021 Off-Road MGM
    AllPro Apex Rock Sliders SSO Slimline Front Bumper Baja Design lite bar 20" Baja Design Squadron SAE fog lites Mountain Hatch Tailgate Rek Gen mud flaps
    I tried to order from the factory last fall. Was basically laughed at. They want you to buy from dealer inventory.
    i bet you can get ALMOST exactly what you want from a dealer. Your package isn't that rare. Email every dealer within 200 miles of you. They know what's coming and can reserve it for you.
    If you wanted a Limited or Nightshade, you could be in trouble though.
    Has ANYONE found a Nightshade or Limited? at the time, I searched within 1000 miles. There was ONE up in Oregon.
  4. Mar 25, 2021 at 12:51 PM
    cgalloni
    But don't understand why couldn't you order what you wanted?
  5. Mar 25, 2021 at 12:59 PM
    waltuo
    waltuo Well-Known Member
    Toyotas
    Be careful, we don’t like the term “ordering” around here.
    Tac0maSteve and DogStar84 like this.
  6. Mar 25, 2021 at 1:05 PM
    DogStar84
    Northern California
    2021 Off-Road MGM
    Read the thread OZ TRD posted above. My experience is factory order is a scam.
    Email what you want to every dealer close enough to drive to. They know what they are getting in. Then negotiate. You may get a few extra things but you can negotiate on price.
    I wanted that new nightshade. That was impossible to find. Limited was also impossible. Someone found me very very close to what I wanted. And I am basically blacking it out aftermarket now.
    I also was able to negotiate on price against several dealers. Then just drove to pick it up.
    I did the same thing for a friend. He wanted white long cab TRD sport, loaded. Googled around and found it, then negotiated price. He got everything he wanted BUT it already had nerf bars on it. Bought it and he can replace the nerf bars on his own. Oh well
    Or wait 5 months. HA. And the closer you get to new model year, the harder it is.
    Plus, Tacomas are hot right now and interest rates are low, so its tougher than normal
  7. Mar 25, 2021 at 1:20 PM
    cgalloni
    well hopefully with mine is not going to be such an issue my packages are really straightforward and i did not order anything out of ordinary. What threw me off is the salesman' comment that there is a slight chance of Toyota Rejecting it. I just want the truck i want don't mind waiting
  8. Mar 25, 2021 at 1:28 PM
    Wicker24
    Wicker24 Well-Known Member
    2018 TRD Off Road
    There is no such thing as "factory order" with Toyota. Each dealer get a allocation, they may or may not be allocated a specific package or trim of a truck. They can request certain things like color or port installed options. If they are not allocated for a certain trim that you are looking for they have to dealer trade with a dealership that does have a allocation and give up one of their own in a different trim/style. Allocation is fairly arbitrary and mostly based on market penetration (which dealership sells the most in a given area, gets the most inventory typically).
    Chew, piff, ReelAddict and 1 other person like this.
  9. Mar 25, 2021 at 1:35 PM
    ReelAddict
    ReelAddict Well-Known Member
    Rob
    Lynnwood, Washington
    2018 TACOMA TRD OFF-ROAD DBL CAB
    SUSPENSION: Bilstein B8 6112 Off-Road Suspension Kit - 47-234413 (5/4 Setting) Bilstein 600lb Front Coils Bilstein 5160 Series Shock - w/0" to 1.5" Rear Suspension Lift SPC Adjustable Upper Control Arms (SPC 25470) Wheelers Off-Road Multi-Leaf Add-A-Leaf Set - 1.5" Lift 3 Leaf Progressive Wheeler's Front Superbump Set Wheeler's Rear SuperBump Bumpstop Set Tacoma 2005-2020 Toyota 4WD - Carrier Bearing Shim Kit by Old Man Emu 2016-2020 Toyota Tacoma 4x4 (2"- 6" lift) Front Differential Drop Kit by Revtek Front Strut Mounting Kit KYB SM5640 WHEELS & TIRES: Venomrex 602 17" X 9" -12 Offset Coal Black Venomrex Red Center Cap Inlay NITTO Ridge Grappler All-Season Radial Tire-LT285/70R17 C Rated Cab Mount Chop PERFORMACE: Toyota OEM Intake Flow Accelerator Mod Toyota OEM TRD Air Filter MBRP Cat-Back Exhaust System Single Side Exit 3" Black Series Toyota TSB Software Update (Transmission) KDMAX Performance Tune LIGHTING: AUXITO H11 LED Headlight Bulbs 80W 16,000LM (High & Low Beam) Complete Interior LED Lighting Kit (Xenon White) NAKOBO White 29mm Festoon Led Bulb (Vanity Mirrors) XSPEED 7440 7441 T20 LED Light Bulbs XSPEED 921 912 906 W16W T15 LED Light Bulbs XSPEED 7443 7440 7444NA W21W T20 LED Light Bulbs CaliRaised Side Shooter Ditch Lights R4T Smoked White Grille Lights Meso Customs Ultimate Turn Signal CaliRaised LED 18W Slim Flood Work Lights (Roof Rack) DV8 Offroad BS20E100W5W BS-20 20" SL8 Slim Series LED Light Bar iJDMTOY Yellow Fog Lights CaliRaised LED 18W Slim Flood Work Lights (Bed Rack) STYLING & ACCESSORIES: TRD Pro Grille W/ OEM Garnish Sensor Cover N-Fab Textured Black Nerf Steps Coverking Neosupreme Seat Covers Full Front and Half Hood CHIPPROTECT by IDENS 30% Front Window Tint Toyota OEM TRD Skid Plate Toyota OEM Bed Mat Toyota OEM Bed Cleats Toyota OEM Door Sill Protectors Toyota OEM All-Weather Floor Mats Toyota OEM Blackout Emblem Overlay Kit Matte Black TRD Off-Road Decals Bed Net Organizer Storage Box Center Console Organizer EGR Matte Black In-Channel Vent Visors TAC Fender Flares Sprayed W/Line-X Smittybilt Smart Cover Tonneau Cover AJT Key Fob CaliRaised Low Profile Ditch Light Brackets BFP Heavy Duty Recovery Tow Hook (Painted In Super Red 2) TufSkinz Red Glove Box Insert Center Console Armrest Cover Cup and Console Liners 7" Screen Protector R4T Off-Road Badges Prinsu Design Cabrack Anti Glare Hood Vinyl Custom Rocker Panel Vinyl Mountain Graphics TacoVinyl Pro Grill Decal Pelican Vault V770 Case (2) Blacked Out Side Mirrors X-Bull Traction Board's DV8 Toyota Tacoma Center Mount Winch Capable Front Bumper OEdRo D Ring Shackles Mountain Hatch Tailgate Insert (Red) Toyota OEM Tailgate Power Lock Custom Tailgate Vinyl by IDENS Kentro License Plate Holder AJT Steering Wheel Overlay (Red) AJT Cup Holder Ring (Red) Meso Custom Door Handle Covers Prinsu Ridgeline Handles All-Pro Off-Road Bed Stiffeners Rek Gen Mud Flaps (Red Lettering) Original Quick Fists (2) 3" Quick Fist (2) RotopaX RX-DLX-PM Deluxe Pack Mount (2) RotopaX RX-1.75G Gasoline Pack RotopaX RX-2G Storage Pack First Alert Fire Extinguisher Bond LH043 Red Fiberglass Shovel Gzila Awning Mount Thule 4.5' Overcast Awning CaliRaised DItch Lights Switch CaliRaised Zombie Lights Switch Nexar NEXS1 Smart Dash Cam Ironman 4x4 Fridge Slide Frontrunner RTT Quick Release Mounts Thule X Tepui Explorer Kukenam 3 Yakima Roadshower 7G Havoc Off-Road Running Boards JoyTutus Portable Car 42 Quart Refrigerator
    I just want to let you know that Toyota does not take any special orders or build one off vehicles. What this dealer is doing is waiting to see if they get one allocated to them and if not will run a search within their region to find the Tacoma with the specs you are looking for. They will try to work out a dealer trade with the dealer that either has it or is getting it. If it gets "rejected", that means they were not able to lock one down for you.
    Chew and DogStar84 like this.
  10. Mar 25, 2021 at 1:47 PM
    mwrood
    mwrood Well-Known Member
    2021 Voodoo Blue TRD Premium Sport
    This is correct
    Wicker24[QUOTED] likes this.
  11. Mar 25, 2021 at 2:04 PM
    cgalloni
    I understand now, thanks for the explanation but what happens if the factory cannot allocate one or the dealer cannot find one to trade with another dealers . I'm left without any options?
    Wicker24 likes this.
  12. Mar 25, 2021 at 2:11 PM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    I got a similar answer from my dealer saying they'd have hear back for this vehicle to be made available. They called me the next day it went through. About 10 weeks later i was driving it home.
  13. Mar 25, 2021 at 2:13 PM
    cgalloni
    i hope that is my case, Congrats !
  14. Mar 25, 2021 at 2:14 PM
    stuka
    stuka Well-Known Member
    21 Taco TRD Pro 6 speed
    I was going to say find a different dealer but then I see that you live in Kalifornistan.
    I lived there for a long time and have had lots of new cars but all but one was bought in state because dealers there act like they are doing you a favor selling you a car that you don't really want.
    I have a few friends who still live there that ended up buying Raptors out of state because dealers there wanted 10 to 15K over sticker, and you can't even spec it.
    It's a lot of money, order exactly what you want.
  15. Mar 25, 2021 at 2:18 PM
    stuka
    Including my Pro manual my dealer got exactly 2 in the last 6 months.
    During this time they had quite a few automatic Pro come through.
    That was their explanation as well. You can't really order per se but wait for them to build them a certain way and hope that you get one. That's how I ended up waiting 6 months for one.
    Chew and Wicker24[QUOTED] like this.
  16. Mar 25, 2021 at 2:19 PM
    ReelAddict
    Rob
    The TRD Off-Road in cement with a manual is in high demand, especially with just the LED lights and Tech Package. You will have a better chance finding one with an automatic. Toyota does not build manuals like the automatics and cement is the most popular color. We just recently had two at the dealership I work at (Marysville Toyota) with this set up and they lasted one day, once they hit our our website and 3rd parties like Autotrader, Cargurus, Cars.com, etc. If you're not in a rush, your local dealer will eventually get one or find one. Allocation locks for each dealer at the 2nd or 3rd of each month. Best bet is to call the dealers near you and see if they earned any. A dealer can also put in what's called a "boss exchange". Say they get one set up the way you want but it's in silver. They can put in a request to change the color to cement and delete or add certain options. There is a 50/50 chance that request will get approved by Toyota.
    rizrox likes this.
  17. Mar 25, 2021 at 2:23 PM
    farmtacoma
    farmtacoma Date Farmer
    Julia
    Twentynine Palms, California
    2021 Cement TRD OR DCLB 4x4 & 2018 Silver SR ACLB 4x2
    ALL my local Raptors friend, get them in Montana. Same reason my Cement 21 DCLB was out of state. Why give CA dealers any business. Sheisty Morons.
    Internet has level'd the playing field. Mobster CA dealers can't hold us hostage. Now if we choose to overpay and give them our hard earned money, its on us.
    One of my neighbors paid $10,000 over MSRP for a Type R. Another friend, went to WI and got it at MSRP + 800$ shipping.
    Chew, shakerhood and stuka[QUOTED] like this.
  18. Mar 25, 2021 at 2:48 PM
    DogStar84
    Northern California
    2021 Off-Road MGM
    That's about right. Horrible here. I hit up 8 dealers in Nor Cal. All but one was thousands over MRSP. ONE dealer (Elk Grove) gave me and a friend the Costco deal. Found what we wanted (or at least very very close) and we paid $2000 under MSRP w/no BS add ons. waited about two weeks and He sold two trucks to us in under two hours.
    farmtacoma[QUOTED] likes this.
  19. Mar 25, 2021 at 3:08 PM
    cgalloni
    thank you. I don’t mind waiting but definitely not getting an automatic. Had a 2016 automatic and hated that transmission hunting. I don’t mind waiting as long as I get the truck I want
  20. Mar 25, 2021 at 3:18 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    It's worth the wait!
