Issues towing my boat
Discussion in 'Technical Chat' started by tacopre2002, Nov 23, 2013.
  1. Nov 23, 2013 at 7:43 AM
    tacopre2002
    tacopre2002 [OP] Member
    Sean
    Savannah, GA
    2015 TRD off-road
    I'm towing a flats boat and whenever I run at 2500 rpm after about 2 hours straight my rpm begins to jolt rapidly or slow rapidly and will not resume to 2500rpm. I'd say the weight of my boat is at most 2000lbs. I have a 2002 Tacoma prerunner v6 sr5 with a 3400 four cam 24. Has anyone else experienced this problem. Any idea why this is happening? How do other tacomas tow? Any info would help greatly.
  2. Nov 23, 2013 at 9:08 AM
    Tacoma Mike
    Southern Maine
    So I take it your running cruise if your trying to "resume"
    Is it searching for gears?
    Any funny smells?
    Never seen this or had reference to it in the shop.
    Should almost tow as if it's almost not even there.
    Some more info for us if you can think of it.
    Did this just start happening?
  3. Nov 24, 2013 at 7:21 AM
    tacopre2002
    Sean
    Savannah, GA
    2015 TRD off-road
    I do not have cruise control and yes it is searching for gears. No funny smells or sign of overheating...
  4. Nov 24, 2013 at 9:07 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Are you leaving it in O/D the whole trip? Try turning it off next time. It will cost more gas, but be gentler on the tranny.
  5. Nov 24, 2013 at 9:21 AM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Is this happening during flat stretches or hills? If hills it's completly normal... just searching for a lower gear.
  6. Nov 24, 2013 at 10:36 AM
    tacopre2002
    Sean
    Savannah, GA
    2015 TRD off-road
    Yeah I tend to leave O/D on all the time. I will turn off next time and see if there's a difference. I have to tow it up to GA from Fort Lauderdale this week will see how it goes...it does it on hills but as well as flat strechtes.
