Issues turning off truck
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Cardsallday13, Feb 8, 2019.
  1. Feb 8, 2019 at 6:15 AM
    Cardsallday13
    Cardsallday13 [OP] Well-Known Member
    2017 DCSB TRD Sport 4x4
    Ok. I need to know if other have seen this or advice on what this could be.
    I recently have started seeing a couple things when I turn the car off. Somewhat intermittently.
    • Dome light not coming on immediately after turning truck off
    • Engine shutting off but all others staying on - radio, etc. Almost like accessory mode
    • Truck beeps when I get out and shut the door. Similar beep to when the truck is on and you get out and shut door with keys outside of the truck.
    Any thoughts?
  2. Feb 8, 2019 at 6:20 AM
    CouchlessPotato
    CouchlessPotato Handcuffed to steering wheels still won firefights
    Zach
    You don't buy a truck for its fucking fenders!
    2.5" lift w/35's
    Headlights on?
  3. Feb 8, 2019 at 6:23 AM
    Cardsallday13
    Most of the time on auto but it doesn't seem to make a difference
  4. Feb 8, 2019 at 6:27 AM
    TEXAS BS
    TEXAS BS Formerly known as MMXVII
    JB
    Texas
    2017 ACLB TRD OR 4X4
    Have you tried disconnecting the battery for 20 minutes to clear all the computers (shade tree computer reboot).
    SR-71A likes this.
  5. Feb 8, 2019 at 6:28 AM
    Cardsallday13
    Negative. Something to try that I didn't think about.
  6. Feb 8, 2019 at 6:29 AM
    bajatacoguy
    bajatacoguy Well-Known Member
    Johnny
    RI to NH
    Blk Taco
    OEM: Bed Mat Roof Rack Tri-Fold Tonneau Cover Door Sill Protectors KO2's Dobinson GTS Suspension TRD Beadlocks Timbren Bump Stops SPC UCA Rear SuperSpring SSO Slimline Winch Bumper SmittyBilt x20 Mobtown Sliders Mobtown Front Skid Avid Basket Bed Rack DECKED Draw Organizer Total Chaos Bed Stiffners Relentless Fab Bed Corner Tie Downs CBI Ditch Light Brackets ARB Dual Compressor Instant Air Tank Smittybilt RTT Road Shower II Indel-B Fridge/Freezer w/ Slide Ironman 4x4 Insulated Fridge Case Redline Tuning Hood QuickLIFT Yo_Hec - Center Console Molle Little Johnny III CB Radio KB Voodoo Flashlight Kit Switch Pro 8100 BlueSea Fuse Pelfreybilt Fuse Panel Mount Gecko - LED Bed Lights Gecko - LED Hood Lights Raptor Grill Lights Cali Raised - Bed Flag Pole Holder Center Console Tray & Organizer Weather Tech Floor Mats Weather Tech Hood Deflector TRAILER BUILD HAPPENING! Plate: Negan
    User Error?
  7. Feb 8, 2019 at 6:30 AM
    Cardsallday13
    Elaborate? What would I be doing wrong?
  8. Feb 8, 2019 at 6:30 AM
    TEXAS BS
    JB
    Texas
    Remember that this will also clear everything the ECM and TCM have learned so the truck will drive differently for a while after this.
  9. Feb 8, 2019 at 6:32 AM
    Cardsallday13
    Oh ok. Well I thought about taking it in to the dealer to see if they could find anything. 1500 miles till the factory warranty is up
  10. Feb 8, 2019 at 6:50 AM
    Cardsallday13
    I should also note that I changed out light bulbs in the map and dome lights and had a speaker amp installed .
  11. Feb 8, 2019 at 7:13 AM
    PHLinPHX
    PHLinPHX Well-Known Member
    Brian
    Bucks County, PA
    2023 Tundra CrewMax TRD Offroad 4x4 Limited
    Are you turning the truck off after opening the door? For some reason if you do that the truck beeps like the keys are in the ignition (even though i have a push button) til you close the door.
  12. Feb 8, 2019 at 7:15 AM
    Cardsallday13
    Nope turning off then opening door
  13. Feb 8, 2019 at 7:22 AM
    LTG4087
    LTG4087 Well-Known Member
    LT
    DFW
    2019 TRD Off Road
    May or may not be your issue, but I killed my dome light fixture attempting to put in an LED bulb, after which all of my interior lights began to malfunction. Thankfully the dealership replaced it under warranty although that was two trips and 4+hour wait time.
  14. Feb 8, 2019 at 7:57 AM
    Jes
    Jes Well-Known Member
    Knoxville
    2017 Taco TRD Pro Cement
    This is the problem... pull out the dome LED. I bought some that kept shorting the LED and causing funky light issues. I ordered the VLED light recommended in another thread and will try it next.
  15. Feb 8, 2019 at 8:04 AM
    Cardsallday13
    Thanks everyone
  16. Feb 8, 2019 at 8:15 AM
    Cardsallday13
    The shop that did the amp is also going to look at a couple things for me as well.
  17. Feb 8, 2019 at 9:30 AM
    Cardsallday13
    The place that did the amp thinks they found it. They found that the amp was back feeding and staying on about 15 seconds past the time of turning the truck off. they put in a relay to cut it off and the issue went away.
  18. Feb 8, 2019 at 9:37 AM
    Larmo63
    Larmo63 Well-Known Member
    SoCal
    2019 Tacoma Access Cab TRD Sport
    If you push the start/stop button when the truck isn't in park, the audio stays on.
    Try it.
  19. Feb 8, 2019 at 9:39 AM
    Cardsallday13
    i know.
    but the truck IS in park and it was staying on.
  20. Feb 8, 2019 at 9:40 AM
    Larmo63
    SoCal
    Hmmmm, my brand new truck doesn't do that.
    I thought I could help......
