Issues turning with new differential?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by buntcake, Apr 1, 2022.
  1. Apr 1, 2022 at 3:59 PM
    buntcake
    buntcake [OP] Well-Known Member
    Booboo
    2020 TRD OR Cement
    Hey guys,
    Recently had a new ARB lock down differental installed in the front of my truck, the guys at the shop said that it would be super useful to get it for offroading on the forest service roads so I went ahead and pulled the trigger and had them install it with my new manual gears.
    I turned on the locker when I was driving the other day and it's like the steering wheel is fighting me and doesn't want to let me turn? I thought maybe the 4x4 wasn't clicking in maybe or the brakes were messed up. I put it into 4 wheel drive and gave it some gas and this loud creaky noise like it's stuck on something happened then there was this jerky motion from the truck. I think they might have messed up my truck's brakes? Not sure what the deal is with it
    photogr4x4 likes this.
  2. Apr 1, 2022 at 4:02 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Were you on pavement when all this happened?
    MalinoisDad and Chew like this.
  3. Apr 1, 2022 at 4:13 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
  4. Apr 1, 2022 at 4:15 PM
    buntcake
    Booboo
    2020 TRD OR Cement
    Yeah I was just driving to my house from the gas station and decided to try it out and it started lurching everywhere and fighting me when I turned it on but stopped once I turned it back off
  5. Apr 1, 2022 at 4:20 PM
    44-16 Taco
    44-16 Taco Do I look like a guy with a plan?
    KMS
    2017 SuperWhite DCORSB
    It's officially friday
    Hank Heel, Junkhead, Bastek and 15 others like this.
  6. Apr 1, 2022 at 4:20 PM
    E.J.
    E.J. International Overlander
    Josh
    NWA
    2017 White Tacoma TRD Off Road
  7. Apr 1, 2022 at 4:20 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Is this a Friday thread or do you honestly not understand what a locker does and how to use or in your case not use one?
  8. Apr 1, 2022 at 4:21 PM
    E.J.
    Josh
    NWA
    FTFY
  9. Apr 1, 2022 at 4:25 PM
    Hook78
    Hook78 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    It can’t be a coincidence that we’ve had basically the same thread two Friday’s in a row. Besides no one is actually this stupid.
  10. Apr 1, 2022 at 4:29 PM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Tacoma transfer case is part-time so when you put it in 4x4 and lock the front and back diff any turns involve the wheels going at different speeds due to different distances so with no differential action in the transfer case the wheels will hop if off road instead of binding as on pavement. That's why lots of 4x4s have an "auto" setting on the transfer case and a center diff in the case - Tacomas never did and even the new Tundra does not - Dodge, Chevy, Ford all have the option so dry pavement is allowed. Those guys also have a neutral position on the transfer case so you can disconnect the transmission from the driveshaft and tow it. Go figure why Toyota never did this.
  11. Apr 1, 2022 at 4:31 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Not supposed to be in 4X4 on anything other than a surface with poor traction. Not supposed to lock front diff except in extremely rough situations and usually only when in a straight line. If you haven't already done so you're going to break the new diff.
    blu92in99 and Key-Rei like this.
  12. Apr 1, 2022 at 4:46 PM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    April Fools!! JK :anonymous:
  13. Apr 1, 2022 at 4:56 PM
    buntcake
    Booboo
    2020 TRD OR Cement
    Well the road was pretty dusty, like some dirt from construction and stuff but it was still hopping around when I pushed the locker button, maybe it just wasn't turning on all the way? It was pretty close to most of the dirt roads I go off roading on honestly
    JustJon likes this.
  14. Apr 1, 2022 at 5:04 PM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    https://www.tacomaworld.com/threads/front-locker-question.728950/page-3#post-25978612
    Jul 16, 2021 at 2:49 PM Post #59 -- perhaps you should follow your own advice.
    "Getting 4.88s and ARB RD111 locker installed as we speak. I was squeamish due to the price tag, but it only adds like another hour of labor so it just made more sense especially since I already have the ARB twin compressor so I went ahead and did it. I'm thinking what the guys in here are saying about it being a tool to use sparingly to help you keep from getting stuck seems to be what most people are saying. I think @EatSleepTacos 's videos pretty well speak for themselves with the utility of it.
    I'm super pumped, I'll let you know how it goes once I've had a chance to try it out. Shop is taking their sweet ass time getting it installed, but better than rushing it I guess."
    TnShooter, Key-Rei and EatSleepTacos like this.
  15. Apr 1, 2022 at 5:07 PM
    MaverickT883
    MaverickT883 Paintless
    Maverick
    Ontario, Canada
    2021 Tacoma TRD Off-road Access Cab
    Check build thread!
    This has to be an April fools day thread.
    please.
    for the love of god.
    If it isn't
    oh no
    grogie, 44-16 Taco, wilcam47 and 3 others like this.
  16. Apr 1, 2022 at 5:23 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Oh boy
  17. Apr 1, 2022 at 5:26 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
  18. Apr 1, 2022 at 5:31 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Always understand what you are paying for.
    Murd3rd and Chew like this.
  19. Apr 1, 2022 at 5:35 PM
    Mark77
    Mark77 Well-Known Member
    Mark
    2021 White TRD Off-road
    Nothing yet
    They installed the canuter valve incorrectly. This is obvious because of the centrifugal vaginal rotation of the duche nozzle.
    Easy fix, drive it on some chocolate frosting, must be home made, not that shit in a cardboard can from the prison annex.
    Then just toss its salad with jelly, spin three times in upward brown.
    Done.
    Im joking because i dont know wtf a lockdown diff is. Unless thats like a revolver diff. You know, 6 front diffs.
  20. Apr 1, 2022 at 5:37 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    Say goodbye to your CVs
