Issues with 5.29 Gears
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ashtonrosenzweig, Jan 18, 2023.
  1. Jan 18, 2023 at 2:07 PM
    aturk
    aturk Well-Known Member
    Tony
    Charlotte, NC
    As many people have said, these are all normal things.
    1. Get a tune, it will fix your top speed governor, and make the shifting much better.
    2. Mileage will improve once you get a tune to take advantage of the gears.
    I had the OTT tune, and am on 34's. Got 529s and while it felt a little better in certain areas, it really didn't come together until I had the tune updated to the 529 gear tune.
    Mileage won't ever be great, accept that now. I get basically the same highway mpg going from stock to 529s. Around town the 529 MPG is a little worse.
    cryptolime likes this.
  2. Jan 18, 2023 at 2:07 PM
    GoodDogRUGER
    GoodDogRUGER 2021 SR ACCESS V6 4x4
    Heath
    SOCAL
    2021 SR Access Cab V6 4x4
    6112/5160, 285/75/17 BFG KO2 , SPC, Method 703s, BMC/CMC, ARE DCU,
    1. Speed limit. Tune will cure this!
    2. MPG. Seems very close to correct to me. My best MPG is 63 MPH. I can get 17-18MPG here if I am super careful and DO NOT use cruise. This is actual not indicated speed. Per calibrated Scanguage
    3. Shifting. Tune will cure this too! Or at least make it WAY better.
    I love my 5.29s. I can cruise at just less than 2K RPM @~65MPH and can cruise about 80MPH at about 2500 RPM. Horrible MPH at 80 but it does it very easily...
  3. Jan 18, 2023 at 2:20 PM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    Not 5.29’s but 4.88’s here at 65 -70 rpm’s are 2000
    mpgs I don’t care
  4. Jan 18, 2023 at 2:28 PM
    TacoDinner
    TacoDinner Well-Known Member
    I can do that with the stock setup too. Just put it in S5.
  5. Jan 18, 2023 at 2:29 PM
    dirtnsmores
    dirtnsmores A camping truck
    Southern California
    06 DCLB Prerunner
    OME885/5100, DAKAR MED-DUTY, SOFTOPPER
    You're overgeared. Taller tires might feel better. But your mpg is fucked. Maybe try a tune and running some skinnies. 255/80/17 is a great size on these trucks.
  6. Jan 18, 2023 at 2:31 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Why would you like to hear your truck screaming for mercy at 65?
    71tattooguy likes this.
  7. Jan 18, 2023 at 2:51 PM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    guess he needs bigger tires to balance it out
  8. Jan 18, 2023 at 3:12 PM
    Taco X
    Taco X Man of almost frightening genius
    James
    Midwest and Southwest
    2022 SR 4x4 V6
    lift, 255/85r16, 5.29 gears
    If your truck is screaming at 65 it's best to take it out of 4lo
    Toyko Joe and MR E30 like this.
  9. Jan 18, 2023 at 3:17 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Yes I did and nowhere in the OP it mentions 80 mph. You can assume anything you want, sure.
    Toyko Joe and cryptolime like this.
  10. Jan 18, 2023 at 3:38 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Why do people think that lower gears and thus higher rpm on the hiway results in better fuel economy?
    whatstcp, Chew and Junkhead like this.
  11. Jan 18, 2023 at 3:43 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    :notsure:
  12. Jan 18, 2023 at 4:00 PM
    Taco X
    James
    2022 SR 4x4 V6
    In defense of that pov, it's definitely possible.
    Have you ever hit a yellow light in a MT and don't downshift? You can push the gas to the floor and barely increase speed.
    If you have enough weight and large enough tires, you will waste fuel.
  13. Jan 18, 2023 at 4:03 PM
    gudujarlson
    Minnesota
    There is not a 1-1 relationship between throttle pedal displacement and the amount of fuel being used by the engine. There are many reasons, but the biggest one is that the ECU will inject gas dependent on the amount of air entering the engine and that is dependent on the engine rpm (and throttle setting).
    Also I think this is a real edge case. Who drives like that on a regular basis?
    Chew likes this.
  14. Jan 18, 2023 at 4:23 PM
    ashtonrosenzweig
    ashtonrosenzweig [OP] New Member
    Ashton
    Haha no I'm not cruising at speeds like that, however it is nice to be able to speed up to pass semis. This highway I'm talking about is one lane in each direction so being throttled at that speed makes it difficult to safely get around trucks.
  15. Jan 18, 2023 at 4:29 PM
    #35
    mcmcolem
    mcmcolem Google Search Mechanic
    Texas
    '18 Cement Taco
    no effin way
  16. Jan 18, 2023 at 4:51 PM
    #36
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    Because higher rpm doesn’t always hurt mileage and sometimes helps. That said, I would never regear hoping to boost my mpg. Do it for the performance benefits and hope for the best on the mpg department.
  17. Jan 18, 2023 at 6:15 PM
    #37
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    OP didn’t read the mega thread
  18. Jan 18, 2023 at 6:28 PM
    #38
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    3 post in and he regeared
    ToyoTaco25 and JoeCOVA[QUOTED] like this.
  19. Jan 18, 2023 at 6:56 PM
    #39
    Taco X
    James
    2022 SR 4x4 V6
    You can try it in an old vehicle without computer assistance, and still waste gas because you don't have enough torque. Personally I don't think any tacoma is gonna experience that unless they've gone very large on tires.
    I have 33s and have crossed country with it once at factory and again with 5.29s. I didn't notice any mpg difference, but I towed a trailer that's a wind sail. Though my rpm actually stayed much lower with 5.29s because there's so much distance between gears that it was able to find a sweet spot. instead of 4k I ran about 3k rpm when going west with the typical headwind.
  20. Jan 18, 2023 at 7:39 PM
    #40
    gudujarlson
    Minnesota
    Everything I said is true of carbureted engines as well. There’s a good Engineering Explained video that explains under what conditions an internal combustion engine is most efficient that can’t find right now. The gist of it is that engines are most efficient at low rpm and high load. This is why modern cars have very high gears for cruising down the hiway.
    Towing a “wind sail” causes fuel economy to decrease primarily because of the aerodynamic losses. Any difference in engine rpm is likely negligible in comparison.
    Fuel economy is affected by engine efficiency, amount of brake use, aerodynamics, tire rolling resistance, drivetrain friction, driver behavior, and perhaps a few other things.
    Junkhead likes this.
