Issues with 5.29 Gears
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ashtonrosenzweig, Jan 18, 2023.
  1. Jan 18, 2023 at 8:21 PM
    #41
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    If lugging and low rpm were the key to great fuel mileage, then 50 mph in 6th gear at 1740 rpm would generate fantastic fuel mileage. It typically doesn’t.
    Shellshock likes this.
  2. Jan 18, 2023 at 8:27 PM
    #42
    Taco X
    Taco X Man of almost frightening genius
    James
    Midwest and Southwest
    2022 SR 4x4 V6
    lift, 255/85r16, 5.29 gears
    I don't think your example is wrong, that cruising down the highway in a stock vehicle with tall gears isn't gonna get the best mpg, but you're ignoring the fact that a modified vehicle has the possibility of gaining mpg. A lifted truck with large tires can be similar to a trailer in that it has much more resistance. As I said, I actually get lower rpm with the regear because the truck needed torque on highway, and the stock gears were so tall that it had to choose between about 2.5k or 4k, but the shorter gears lets me cruise at about 3k rpm. It's possible I'm actually getting much better mpg, but I'd have to have done way more trips with each gear set to know the difference. I just fill up and don't worry about gas
  3. Jan 18, 2023 at 8:34 PM
    #43
    YotaFAB
    YotaFAB Well-Known Member
    what size tire? I'm 285x75x16 and spinning 2500rpm at 65mph
  4. Jan 18, 2023 at 8:38 PM
    #44
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    AT vs MT. Different overdrives.
    71tattooguy and YotaFAB[QUOTED] like this.
  5. Jan 18, 2023 at 8:42 PM
    #45
    YotaFAB
    Noted, Wish I had a MT
  6. Jan 18, 2023 at 9:48 PM
    #46
    Terraj66
    Terraj66 Well-Known Member
    las vegas
    2016 DCSB 4x4 sport. super white
    How does one cough up 3000 dollars with no research?
    auskip07, rzathagza and na8rboy like this.
  7. Jan 18, 2023 at 10:30 PM
    #47
    kodiakisland
    kodiakisland Well-Known Member
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    5100s/1.6in eibachs, wheelers AAL, OME N182 rear shocks, 4.56s, Detroit truetrac, 255/75/17, SOSConcepts sliders
    Unfortunately, modern vehicles can't just have a gear swap and away you go. You also have to address the computer, as it's reading a lot of different things that changing gears affects. The CPU has to be updated with the new gear ratio.
    GilbertOz likes this.
  8. Jan 18, 2023 at 11:22 PM
    #48
    DD619
    DD619 Active Member
    Don
    San Diego, CA
    2020 White TRD OR
    OP what shop did you go to for the installation?
  9. Jan 19, 2023 at 8:50 AM
    #49
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    dirtnsmores likes this.
  10. Jan 22, 2023 at 11:20 PM
    #50
    jamie_aug
    jamie_aug Active Member
    James
    2021 Toyota Tacoma
    Accutune Offroad 05+ Tacoma Mid Travel Suspension Kit, Stage 5A – Fox SKU: AOR-3000-0021 Adventure tune -Front Coilovers: Fox 2.5 Performance Elite Series, DSC -Sway bar relocation brackets included with shocks -Front UCA: AccuTune Offroad -Rear Shocks: Fox 2.5 x 12″ DSC – Modified -Rear Archive Garage Shock Relocation Brackets -Rear Springs: Icon RXT Pack -Archive Garage Rear Shock Relocation Brackets -Archive Garage Hammer Hangers -Rear U-Bolt: AccuTune Offroad -Rear +4″ Crown Performance Brake Lines Remove: Front UCA - Icon Delta Joint Add: Camburg Kinetik Series Billet Upper Control Arm, Uniball, 05+ Tacoma, 03+ 4Runner SKU: CAM-310103 Add: CAMBURG TOYOTA TACOMA PRE/4WD 05-20 PERFORMANCE SPINDLE KIT SKU: CAM-310114 Add: CAMBURG TOYOTA TACOMA PRE/4WD 16-20 PERFORMANCE LOWER ARM KIT Code: CAM-310126 Add: '05-CURRENT TOYOTA TACOMA CAMBURG FRONT BYPASS SHOCK MOUNT KIT add recommended FOX 2.5 bypass shock PART#: CAM-310052 Durpbumps - 3rd Gen Tacoma Front Off Road Bump Stops (2016-2023) DBF212 DRT Fab TACOMA CAB MOUNT RELOCATION DRT Fab UNIVERSAL HITCH SKID PLATE Fuel Offroad - Block Model D752 - 17x9 Matte Anthracite w/ Black Ring Negative -12 offset Nitto Ridge Grappler 285/70r17 Nitro Gear and Axle '16-CURRENT TOYOTA TACOMA W/8.75 INCH REAR 4.88 RATIO FRONT AND REAR GEAR PACKAGE KIT VENDOR: Nitro Gear and Axle PART#: GPTACO2016-4.88-8.75 Yes to REM gear polish OV Tune Tacoma 3.5L vF Tune Pack Get right tune for gearing of 4.88 Vftuner.com Nitro Gear and Axle '05-CURRENT TOYOTA TACOMA 8" CLAMSHELL STUB AXLE BUSHING VENDOR: Nitro Gear and Axle PART#: NITRO-AKT8S S.O.S Performance Stoptech 6 PISTON FRONT BIG BRAKE KIT fits 2005-21 TOYOTA TACOMA TR340.6TA SOS PERFORMANCE 4x4 Black Slotted rotors Paint fender flares cement gray to match Custom Viper Cut Front bumper. Seibon Carbon - TR-STYLE CARBON FIBER HOOD FOR 2016-2021 TOYOTA TACOMA, custom painting to look like a TRD Pro. C4 Fab - TACOMA ROCK SLIDERS / 3RD GEN / 2016+, shipped raw, line-x by local shop TACOMA BED STIFFENERS - 3RD GEN, 2016-2023 TOYOTA TACOMA ACCESSORIES,REAR CHANNEL BED STIFFENERS, PART #48676 Wet Okole Seat Covers WeatherTech Floor Liners Full Custom Stereo with 2x8” subs behind the seat, Kenwood head unit. Taco Garage - Dashtop Multi Mount (DMM) for RAM mount system Toyota - TRD Pro Skid Plate Toyota – Bed Mount Step
    I’m running 285/75r17’s with 4.88s and a tune, and my mileage still sucks
    With bigger tires, it was totally worth it though. Goes up hills and shifts so much better
    auskip07 and 71tattooguy like this.
  11. Sep 23, 2023 at 10:06 AM
    #51
    Waabaah
    Waabaah Active Member
    .:R32
    Was this a gas saving video or just general engine efficiency? I can see an engine being “power” efficient but not gas savings efficiency
    if constant rpms stay the same…a lower load vs a high load can be compared. Low load will always net less gas usage then high load.
    In Tacoma fuel usage the Tacoma engine is horrible on low torque under 2k rpms. So if you had to increase speed to 65…low torque would be pushing the gas pedal down further and longer. This would be higher load. If Tacoma’s had fat torque numbers down low under 2k….you would barely need to touch gas pedal and for much shorter duration.
    Think of your gas pedal as your fuel meter. The more you push, more fuel. The longer you push, more fuel. Ideally it all comes down to whoever can push the gas pedal the least amount of times.
    In gearing, higher gears would increase torque per gear. So shorter gas presses to increase speed would be the gas savings part.
  12. Sep 23, 2023 at 10:31 AM
    #52
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    auskip07 likes this.
