Issues With Brake Lights and Backup Camera
Discussion in 'Lighting' started by Planotacoma, Sep 23, 2013.
  1. Sep 23, 2013 at 5:55 PM
    Planotacoma
    Planotacoma [OP] New Member
    k
    Plano tx
    I just got my truck back from getting a bumper replaced.
    They had to take the bed off and paint the side panel as well.
    They also replaced the brake lights.
    2011 Toyota Tacoma double cab.
    Now when I press the brake petal the reverse dash light and the right signal dash light illuminate. It also turns the back up camera on when the brake petal is pressed.
    The sales guy told me the cause was a burned out brake bulb.
    I am not stupid I know that is not what is causing the issue.
    Has anyone had a similar issue?
    Thanks for the help.
  2. Sep 23, 2013 at 6:03 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    DId you check the bulbs?
  3. Sep 23, 2013 at 6:09 PM
    Planotacoma
    k
    Plano tx
    yes the right brake light on the back on the truck does light it is just dim.
    About half as bright as the left one.
  4. Sep 23, 2013 at 6:10 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Check it with the lights On, and have someone press the brake. There is a chance they wired it up wrong.
  5. Sep 24, 2013 at 3:12 PM
    stikle
    stikle Well-Known Member
    Seth
    The Sovereign State of Eastern Oregon
    1997 LX Xtracab 4x4 V6 3.4L
    Eh, see my Build Thread sig link. Too many mods to list.
    When I discovered my canopy brake light was disconnected, I figured it was an easy fix and wired it how I thought it should be. It did come on, but was very dim. Eventually I figured out that I had grounded it in the wrong place. Once I switched it to be grounded to the actual brake light ground instead of the truck constant ground, the light came on nice and bright. No idea why that made a difference, since in my mind a ground is a ground...but it did.
    So yeah..check your wiring.
