issues with digital clock changing its time. no longer shows correct time
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JUJtacoma2010, Feb 18, 2015.
  1. Feb 18, 2015 at 1:06 PM
    JUJtacoma2010
    JUJtacoma2010 [OP] Well-Known Member
    Fresno
    Tacoma 2010 Dbl Cab. OFF Road Package
    This just started recently. the time on the clock has been acting weird. it changes drastically to another time not even close to what its supposed to be. I update the time on it and I have done this several times since this issue started and each time when I go start the truck in the morning to go to work, the time is way off.
    any one had this issue.
    The battery is good and no issues with it. I have no problems with the radio. its just the clock loosing its time. the clock is not dim as some has mentioned.
  2. Feb 18, 2015 at 1:12 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
  3. Feb 18, 2015 at 1:13 PM
    Taco Dan
    Taco Dan Well-Known Member
    Dan
    Tuscaloosa, AL
    07 FJ Cruiser auto 4X4
    Snorkel, Cooper ST Maxx 255/80/17, diff breather relocate, Cobra ultra III cb radio set up Warrior Products front bumper
  4. Feb 18, 2015 at 1:14 PM
    JUJtacoma2010
    Fresno
    THis has happened like 10 times already. we update the time on it and then it might stay correct for a few days and then something happens and its showing the wrong time.
  5. Feb 18, 2015 at 1:15 PM
    JBecker
    JBecker Well-Known Member
    Virginia
    2015 AC SR 4X4 2.7 Manual
    Loose battery terminal?
  6. Feb 18, 2015 at 1:25 PM
    JUJtacoma2010
    Fresno
    I will check the battery terminal today. that could be the issue.
  7. Feb 19, 2015 at 7:57 AM
    JUJtacoma2010
    Fresno
    I checked the battery terminal and its tight and good. I updated the time on the clock yesterday and its still correct time this morning. but probably will change soon
