Issues with drive shaft/u-joints/wheel bearings...!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by flyboy718, Oct 31, 2016.
  1. Nov 15, 2016 at 1:20 PM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Do you know what the cost was to balance the drive shaft? If they didn't give you a breakdown of cost, what was your total cost? Thanks. Really want to know so I can shop around locally.
  2. Dec 3, 2016 at 11:30 AM
    A.T.
    A.T. Well-Known Member
    Toronto
    2007 Access Cab TRD Off Road
    Problem solved. After several visits to my dealership and a variety of guesses, "Your tires aren't balanced. It's your winter tires. It's because the rear leaf springs were replaced as part of a recall and one of your brackets was bent. Now that we've fixed that everything probably fits a bit looser so you may have some new vibrations." (WTF?) !!!! and one new U joint I finally found a drive line specialist. Not only did it need all the U joints replaced and the shaft balanced but the U joint Toyota sold me was not installed correctly. Apparently the clips that hold the joint together are colour coded to indicate varying thicknesses to enable finessing of the fit. But the colours should be the same on opposing sides of the joint to keeping thins aligned, centred and balanced. The new joint had a variety of coloured clips none of which matched.
    All rectified for reasonable $s. It drives perfectly smooth now.
  3. Dec 3, 2016 at 6:15 PM
    5150rock
    5150rock Member
    magico
    fresno ca
    2006 toyota tacoma 4
    4×4-2006 tacoma
    I got almost same issue changed had bearing charges driver side cv join but on this forum I find out is my needle bearing is located right driver side on front differential right ware cv joint connection the part is on is way hope my problem is finally fix not going to be easy but going to try to my self I will post additional information see how it goes.
