Issues with first gear when cold?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Mallcrawler20, May 18, 2025.
  1. May 18, 2025 at 9:16 AM
    Mallcrawler20
    Mallcrawler20 [OP] Well-Known Member
    Trd off-road 4x4 Manual
    Just wondering anyone else have issues with first gear when cold . Feels like I’m fighting it when it’s cold .
    Reference …20 off road with 66k miles on it . Recent drain and fill on the transmission with oem fluid .
    Seems I’m noticing it more since the drain . No weird shifting . Once it warms up seems to be smooth .
  2. May 18, 2025 at 9:19 AM
    JuniorVarsity
    JuniorVarsity I'm not a pickup truck guy. I have two.
    PacNW
    1999 Tacoma SR5 4x4, 2021 TRD Sport Access Cab
    I find this to be the case in many MT cars - to varying degrees. Always better once warm. The standard "solution" is to shift into 2nd, then into 1st; sometimes helps. Or, if you can let the truck roll a couple of inches, that might ease the entry into 1st.
    OZ TRD, RicerRabbit, Irons and 4 others like this.
  3. May 18, 2025 at 9:21 AM
    Speedbird
    Speedbird Well-Known Member
    Fort Couch
    2017 TRD-OR
    A LITTLE, but not really any different from the other MT vehicles I've owned. I changed to that Ford [crazy weird name eludes me] MT fluid ~24k and it improved (But not sure also if that was related to breaking in).
    Mallcrawler20[OP] likes this.
  4. May 18, 2025 at 10:39 AM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    What do you mean by “cold” and “feels like I’m fighting it”?
    Oil (as long as being the right type) will in no way affect shifting.
  5. May 18, 2025 at 3:45 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    I will respectfully disagree.
    Motorcraft XT-M5-QS, it meets the Toyota specifications and has a reputation as a "problem solver" fluid for balky manual transmissions in sports car groups.
    I don't shift (or drive) very fast and had experienced occasional first gear blocking and also a "crunchy" second gear shift. I was also frequently conscious of the syncromesh "working" when shifting, I could feel it in the stick, it wouldn't grind but you knew it was there.
    The first trip around the block with the Motrocraft fluid was a stunning improvement.
    I changed at 30K, now at 80K and it still shifts perfectly.
    Motorcraft data sheet:
    https://fcsdchemicalsandlubricants.com/products/transmission-fluid/productdetails?id=1
    Rock Auto had the best price.
    https://www.rockauto.com/en/parts/motorcraft,XTM5QS,transmission+fluid,13630
    Irons, joba27n, mtip and 3 others like this.
  6. May 18, 2025 at 4:09 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Never driven a 3rd gen Tacoma, but slightly over 1/2 of the trucks/SUV's I've owned since 1976 had manuals. The gear oil is much thicker than engine oil and when it's cold it's even thicker. It's always taken a little more muscle to shift gears in cold weather until the oil warms up.
  7. May 18, 2025 at 4:52 PM
    Mallcrawler20
    Resistance to put in gear almost like you didn’t press the clutch all the way in or position the fork properly . So u have it to give it a little more pressure to drop into 1st …maybe the new fluid needs time to break in to get a little thinner for less resistance .
    I don’t know …hopefully it gets better .
  8. May 18, 2025 at 4:55 PM
    Mallcrawler20
    Gonna have to try this stuff on the next change …if the current fluid doesn’t get better .
    Speedbird likes this.
  9. May 20, 2025 at 5:52 PM
    gudujarlson
    Minnesota
    Oil reduces wear on the transmission over long time periods. It has little or no effect on shifting performance.
  10. May 20, 2025 at 6:50 PM
    Blueberry.Taco
    Blueberry.Taco blueberry.taco (IG)
    Ryo
    Fulltime Overlanding
    Long travel house on 35s with a custom aluminum utility bed and FWC
    some welding required
    Synchros can be sensitive to oil and modifiers so shift feel (you can arguably call that performance) can definitely change depending on the oil.
    I switched to MT90 and felt no difference from the original oil but I didn’t have any complaints either.
  11. May 20, 2025 at 7:33 PM
    gudujarlson
    Minnesota
    Yes because I believe the synchro clutches require enough friction to work. Any oil of the correct spec should do.
    When the synchro is not working efficiently, it results in a grinding sound as the gear shafts are forced to rotate at the same rate by the banging steel cogs together. This happens frequently when shifting fast in 4lo.
    Willy Lump Lump likes this.
  12. May 21, 2025 at 9:05 AM
    Willy Lump Lump
    Willy Lump Lump Well-Known Member
    21’ dcsbmt
    This and that
    Unicorn tears
    Speedbird[QUOTED] likes this.
  13. May 21, 2025 at 9:12 AM
    Willy Lump Lump
    21’ dcsbmt
    This and that
    After my first trans change, I think I went to amsoil mt 90, downshifts up a grade felt much smoother, not so clunky. The next one I’d did just the valvoline easy to find squeeze bottle. Honestly the amsoil felt better. Mildly better.
    I’ve ground my gears most in 4 lo, so I try to double clutch in 4lo.
    also just have to say 4 lo is too much fun. People get all up ina huff about only using 4lo for like seconds and then shifting back out of it. But uphill/downhill in some rutty and rocky stuff, it’s just nice.
    joba27n and Speedbird like this.
  14. May 21, 2025 at 10:06 AM
    Mac62989
    Mac62989 Well-Known Member
    2020 Quicksand Sport AC MT
    I changed to the Ford fluid around 31k and I don't know if I felt much of a difference. The clutch and trans seem much smoother when warm, it could be a pain in the ass leaving work in the morning in the winter when its in the teens or single digits. I don't know if there is a magic fluid, I just plan to stay on top of changes every 30k or so..
  15. May 21, 2025 at 10:58 AM
    6MTPro
    6MTPro Well-Known Member
    HI -> CA
    2018 TRD Pro 6MT | 2004 4Runner 4.7 V8
    Tune, 285/75/16, Diode Dynamics, PPF, Bakflip Mx4, Meso, Cali Raised, TJM
    When I switched to ford motorcraft it helped with the notchiness of the shifting a lot.
    amyracecar, Speedbird and shakerhood like this.
  16. May 21, 2025 at 11:08 AM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    Every manual trans I have ever owned shifted sluggish until warm it’s the nature of the beast mainly when temps were below freezing.
    Speedbird and doublethebass like this.
  17. May 22, 2025 at 5:46 AM
    Mookinator
    Mookinator Member
    2017 TuRD Sport ACLB 6MT
    My 2017 has been very difficult to shift into 1st at anything above 2mph since I drove it off the dealers lot. 84Kmi later and a fluid change and there's no difference. I've gotten good at double clutching into 1st but I wish I didn't need to drive the truck like it's 80 years older than it's build date. Yes, cold fluid causes the synchro's to work harder. But this will happen in 90*F heat as well and independent of the temps 2st - 6th never have much resistance going into gear. The almost 2:1 gear reduction from 2nd to 1st doesn't help but with the number of people who experience the same driving experience makes me believe Toyota did this intentionally to save <insert part here> from failing. Such as stopping people accidentally shifting into 1st too soon and causing the internals to no longer be internals any longer.
    I cannot think of a MTX car I've ever owned that was this difficult to shift into 1st gear that didn't have a trans with worn-out synchros. (and they were beaten the crap out of)
  18. May 22, 2025 at 5:54 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission 5.29 R&P FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Bed Light Kit VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Customized 2WD Low Operable (Switched) Clutch Safety Bypass
    Don’t know what’s up with yours, but I’ve had two different transmissions in my truck, and both are cake to shift into 1st, even up to 10-15 mph. I’ve seen a number of people here relay the same experience, with many even saying they shift into it at higher speeds than I do.
    gudujarlson likes this.
  19. May 22, 2025 at 6:40 AM
    TacoGranny
    TacoGranny Well-Known Member
    2020 TRDOR DCSB Cement 6MT
    33's, Sliders, Skid Plates, Softopper, ATH rear bumper
    I also downshift to 1st at ~15 mph every weekday coming into my work driveway entrance, rev matches pretty easily. I would say it's one of the more compliant 2nd to 1st gear downshifts I've had in any of my manuals, and I've had a few. The 2:1 gear ratio from 2nd to 1st makes judging the RPM's easy. The shifter is a little stiffer dropping it into 1st, but that's the nature of the beast in my experience.
  20. May 22, 2025 at 6:48 AM
    Cement_wheels
    Cement_wheels Well-Known Member
    2020 Cement TRDOR DCSB 6M
    ^^ This ^^ With my Taco it's reverse after first start up. What I do is never force it, put trans in neutral, slight rev, then it goes right into reverse no problem. And it's not temperature dependent.
