Issues with first gear when cold?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Mallcrawler20, May 18, 2025.
  1. May 25, 2025 at 5:26 PM
    #41
    photodoc
    photodoc Of the paths u take in life make sure a few r dirt
    Northern Kentucky
    '23 TRD PRO 6MT
    Just because you have done it several times doesn't make it a good idea. I could drive on pavement in 4wd many times before it would destroy things...just because something doesn't happen immediately doesn't mean it's not bad.
    Yes second gear is tall but shifting into first should not be a common practice.
  2. May 25, 2025 at 5:41 PM
    #42
    Clearwater Bill
    Billy
    Largo Florida
    https://www.tacomaworld.com/threads/3rd-gen-manual-transmission-drain-and-fill.858474/#post-30620360
    Post 4 and 11 which you chose to ignore :D
    Cold cold 1st gear 'may' not improve much, but other shifts, up and down, will. Not instantly, but within a modest amount of use.
    All I can offer is reports from fellow solo Il users in cold climates who felt great overall improvement.
  3. May 25, 2025 at 5:53 PM
    #43
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    4wd is obviously inherently bad because of the binding that occurs due to the different in front and rear different speeds on turns. There is no such obvious downside to downshifting to 1st gear in this truck. It is no different than downshifting to any other gear. The friction of the synchros spins it up to speed. In other vehicles I would agree. My old jeep does not like to be dropped into 1st if I’m rolling. The truck is fine, as have been all my other trucks (Ford Ranger and Nissan frontier). I’m not worried about it.
    That said, with my 4th gen transmission I’m running and the correspondingly 23% lower 2nd gear it has, I don’t need to do that near as often as I used to.
    gudujarlson likes this.
  4. May 25, 2025 at 5:56 PM
    #44
    Mallcrawler20
    Mallcrawler20 [OP] Well-Known Member
    Trd off-road 4x4 Manual
    Update the shifting is getting better with more milage maybe with new fluid it needed to break in . Thanks all for the info .
  5. May 25, 2025 at 7:43 PM
    #45
    photodoc
    Northern Kentucky
    '23 TRD PRO 6MT
    Wait you swapped to a 4th gen trans?
  6. May 25, 2025 at 8:10 PM
    #46
    BLtheP
    Plano, TX
    Yes.
    photodoc[QUOTED] likes this.
  7. May 25, 2025 at 10:27 PM
    #47
    Cement_wheels
    Cement_wheels Well-Known Member
    2020 Cement TRDOR DCSB 6M
    I learned to drive a manual (vehicle not motorcycle) in a '69 F250 with 3 speed column shifter i.e. '3 on the tree'. 300CI I-6. My Dad's. Loved that truck. The only time it rode decent was when the bed was loaded with gravel,cinder blocks,etc. . And no it didn't have a bedliner.
  8. May 26, 2025 at 4:46 AM
    #48
    photodoc
    Northern Kentucky
    '23 TRD PRO 6MT
    Nice. Difficult? How's the gearing difference?
  9. May 26, 2025 at 4:52 AM
    #49
    BLtheP
    Plano, TX
    Not difficult at all, just a transmission swap. It is 100% bolt in and externally, the transmissions are almost identical. Dimensionally, they are 100% the same.
    Overall drives pretty good, R/1/2 are 23% lower, 3rd about 10% lower, and 5th and 6th are 10% taller. Overall I’m happy with it.
    Here’s the link to my long thread about it if interested.
    https://www.tacomaworld.com/threads...nsmission-for-the-rc60f.849671/#post-30359650
    RustyGreen likes this.
