Issues with Keys and Locking the Doors
Discussion in 'General Tacoma Talk' started by sflegends, Apr 17, 2025.
  1. Apr 17, 2025 at 2:00 PM
    sflegends
    sflegends [OP] Active Member
    Colorado
    2012 Gray Tacoma Access 5 lug 2wd
    I only have two copy keys for my Tacoma. I bought it used and the original keys are lost to the sands of time.
    Both copies turn the ignition just fine. Locking/Unlocking the doors is a different story.
    Both copies unlock the driver door every time, but only one copy unlocks the passenger every time. The other has to be inserted in a particular way.
    Neither copy can lock either door. The previous owner informed me that he just got in the habit of hitting the door lock button and ensuring the keys were not in the car when he closed the door.
    What are my options? Do I have to go get the thing rekeyed at the dealership?
  2. Apr 27, 2025 at 4:11 PM
    Williston
    Williston Well-Known Member
    New England
    2014 Tacoma SR5 4x4 DC SB V6 AT Tow Pkg Entune+ Mostly stock with a few OEM mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. OEM All-Weather floor mats (summer).
    The door lock pins in the cylinders themselves may be worn out to the point where the keys won't work on them. Work on the locking issue and if you decide to go with using the inside lock button to get around it: hide the extra key outside on the truck somewhere.
    Using the lock button is a very hard habit to break once you start doing it and very it's likely you'll lock yourself out miles from nowhere. I'm lucky: I have a 2014 that will not allow a door button lock if the key is in the ignition. The button just pops up again on it's own. It's only a partial safeguard though. I also discovered after having it for a while where the truck will also lock itself again in about 30 seconds if you unlock with the remote but then don't open the door. I think there is a work-around sequence where you can intentionally lock yourself out with the key in the ignition, but I'm not experimenting to confirm. Sorry! :proposetoast:
    sflegends[OP] likes this.
  3. Apr 27, 2025 at 4:20 PM
    sflegends
    Colorado
    Thanks. I just solved it today. Called a locksmith and he suggested I pull the cylinders out to take a look. They were covered in crud. Cleaned them up and now it’s working just fine.
    Point well made about bad habits. Good idea on having a spare somewhere if needed.
    For anyone who’s reading with a similar issue I put the play by play in my build thread.
    Williston and soundman98 like this.
  4. Apr 27, 2025 at 4:29 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Have the locksmith make you 1-2 more unchipped copies that only unlock the doors. Maybe one more chipped key. An unchipped key is under $5. A locksmith can make and program a chipped key. Last one I had done cost me about $65, but that's been a few years.
    I keep a chipped key hidden inside the truck and an unchipped key hidden somewhere on the outside. If I get locked out, or lose my keys while hunting, fishing, biking etc. I can use the unchipped key to get in the door. If a thief finds it they can get in the truck, but that key won't start the engine and hopefully they won't also find the chipped key.
    $5 for an unchipped key hidden outside the truck is a lot better than paying a locksmith $200 to come out and unlock your doors.
