Issues With Leveled '07 4x4
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Izzapac, Aug 10, 2011.
  1. Aug 10, 2011 at 1:14 PM
    Izzapac
    Izzapac [OP] Member
    St. Robert, MO
    2007 TRD Sport Silver Streak
    Bilstein 5100s front (1.75") & rear
    I recently leveled my 2007 TRD 4x4 Taco, and now am having some issues with front end vibrations. Nothing major, but I can feel it in the floor, pedals and steering wheel. Someone told me that anything lifted above 1.5" should have a differential drop kit installed. I see that I can get this kit from Toytec for about 30 bucks. Is this the one I would need for an 07 4x4? Also...Should I purchase a driveshaft carrier bearing drop kit?
  2. Aug 10, 2011 at 3:19 PM
    06RadiantRed
    06RadiantRed Well-Known Member
    CA-Bay Area
    2006 Tacoma 4x4 TRD Off Road - RadRed!!
    ICON ext. Travel Coilovers, TC UCAs, Fox 2.0 FJ Rear Shox + 2"AAL rear
    If you didnt touch the rear end, you probably dont need the drive shaft carrier bearing drop.
    As for your front end, sounds like you have the front diff needle bearing issue that many people complain about after lifting their vehicles. To test this, go test drive it. Flip it into 4 wheel drive (dont turn a bunch or drive in circles..) while driving and see if it magically stops vibrating after the 4 wheel drive light turns on. Then turn off 4 wheel drive and watch it come back. If this happens, you can either live with the vibration that will slowly get worse, or fight your dealer to replace you front Diff, or try and replace this bearing yourself. Its not easy, but not impossible either depending on your mechanical knowledge and tools.
    You can try a diff drop first, but it didn't help me. Although I was at 2.5 inches.
  3. Aug 10, 2011 at 3:23 PM
    98tacoma27
    Ben
    Not Beech Creek
    Did you happen to get an alignment afterwards?
  4. Aug 10, 2011 at 4:57 PM
    Izzapac
    Izzapac [OP] Member
    St. Robert, MO
    Yes, actually got TWO alignments. Once when I got the 5100's and new tires installed. Then again about a week later after I noticed the vibration.
  5. Aug 10, 2011 at 4:58 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    The wheels are balanced correctly ?
  6. Aug 10, 2011 at 5:05 PM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Do you just have the 5100's in the front and no lift in the rear? If you are 100% on a diff drop, I have one I could sell you.
  7. Aug 10, 2011 at 6:57 PM
    BenWA
    BenWA Well-Known Member
    Boston burbs
    '06 Double Cab TRD Off Road 4X4
    Diff drop kit made my front end vibes worse with 1.75" lift.
    OP, it's worth doing a search on this topic -- there's a lot of good info that you should read up on related to this. Search for my "Official front differential bearing vibe" thread -- I have all the most relevant threads on this topic linked from that thread.
    This is assuming that it is in fact your front diff and the vibes go away when switched into 4hi, as radiantred indicated above.
  8. Aug 10, 2011 at 7:04 PM
    thebigk
    thebigk 6 Double 5 3 2 1
    Ken....
    Odessa, TX
    When I put my lift on I had the same problem. My wheels were WAY off balance.
  9. Aug 10, 2011 at 8:37 PM
    kessler89
    kessler89 Well-Known Member
    OH
    12' Pro4x 6MT
    TBA
    diff drop eliminated my vibes with 5100's set at 1.75
  10. Aug 11, 2011 at 6:07 AM
    Izzapac
    Izzapac [OP] Member
    St. Robert, MO
    Good to hear. I think I'm going to try it, given that it's not too expensive. The kit is $30, which is totally doable. However, I'm not very mechanically inclined, and will have to pay to get this done professionally. Any idea how much that might run me? Estimate?
  11. Aug 11, 2011 at 4:25 PM
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    Buy mine, I'll send instructions, and can offer tech support. It will take you longer to get the skid plate off than it will to install the diff drop.
  12. Sep 23, 2011 at 12:57 PM
    dayNnite4
    dayNnite4 We can't stop here, this is bat country.
    Nick
    Southern NH
    '11 4x4 5-speed AC
    subbed. theres g2 be a way to lift it without needing a new front axle
  13. Sep 23, 2011 at 1:18 PM
    ace96
    ace96 Well-Known Member
    Western KY
    '11 SWB DC TRD SPORT
    AVS bug deflector, Weathertech digital fit floor mats, TRD skid plate w/ Sockmonkey decal, SOS Cocept sliders w/ Line-x, Pioneer 3500, Hybrid Audio Technology Mirus 6X9s & 6.5s, back up cam mod, Wet Okoles-front & rear, TRD exhaust, 17X9 XD Spy w/ Falken Wildpeaks, Avid light bar
    New tires...could have a balance issue. I would balance them again.
  14. Sep 23, 2011 at 7:41 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    Sounds like the needle bearing... I had the same issue, and I was lucky I still have the 100k mile warrenty.. Dealer fixed it.
    Try the CB Drop first though, it should help it with such a small lift...
    If it doesnt, then check to see if it is the needle bearing.
    Put it in 4x4 and if the noise and vibe goes away, the you know its indeed the needle bearing.
    there a thread on here somewhere were some people have changed it them self's...
    good Luck!
