Issues with Morimoto XB taillights
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SconnieTaco60, Sep 9, 2025 at 12:19 PM.
  1. Sep 9, 2025 at 12:19 PM
    SconnieTaco60
    SconnieTaco60 [OP] Well-Known Member
    2021 Tacoma TRD Off Road
    Stock
    Just bought a set of Morimoto XB LED tailllights for my 2021 Tacoma (TRD Off Road Pkg w/LED headlights). When the vehicle is running the left/driver's side turn signal won't work. Not only that but the front left turn signal and the left dashboard turn signal indicator doesn't work either. Called a Tech @ Morimoto and he suggested I check the resistor in the taillight assembly to see if it's hot. It wasn't. He also told me to switch the Morimoto XB taillights and see if the problem followed the left tailllight. It didn't. Both the left and right XB taillights wouldn't work when plugged into my left/driver's side taillight plugs. Called and spoke to a different tech who said it sounds like the problem is in my truck not their XB taillights. I responded that I didn't think so because the alpha rex tailllights I was replacing with the Morimotos worked fine with my truck running when I reinstalled them. The tech said to send the XBs back for a refund and that them sending me a new set probably wouldn't solve the issue. So I bummed b/c I really like the look of the 3rd Gen. Tacoma Morimoto XB taillights. Any suggestions on how to make em work?
  2. Sep 9, 2025 at 12:25 PM
    303tacoma
    303tacoma Bad Karma is a Bitch
    Rebecca
    Sw Denver Concrete Jungle
    2008 TRD AC 4th gen Rav4 Platinum
    ICONS Front & extended Rears DAKARS LR UCAS Wheelers Super Bumps F/R Homersoshi & Bumper insert, Ultra Gauge, Wet Okole seat covers, AFE air filter, Truxedo tonneau cover, LED White Cluster swap by yosh2000, Audio upgrade, ECGS Bushing, rcbs204 Lighted 4x4switch, Bullaculla trailer harness relocate bracket SOS Concepts IFS skid & sliders Anti- Dark RedLine Hood Struts Matt Gecko Bed Lights BHLM Depo Tailights Fog light anytime mod ABS cancel mod Rear diff breather mod Brake light 35watt mod Relentless u bolt flip Mobtown Recovery Bar Sound deadener doors rear wall
    Curious do the alpha rex lights work now?
  3. Sep 9, 2025 at 12:31 PM
    SconnieTaco60
    Stock
    Yes. When I reinstalled my AlphaRex Nova Series Tails they both work fine.
  4. Sep 9, 2025 at 12:34 PM
    BabyBilly
    BabyBilly Well-Known Member
    Billy
    2020 Pro
    Did you add resistors when you installed the Alpha Rex tails? Maybe there's too much resistance in the circuit now?
  5. Sep 9, 2025 at 12:42 PM
    SconnieTaco60
    Stock
    No I didn't. Just installed them right outta the box. FYI-I do have Morimoto fogs and their 30" SS light bar installed in my front bumper. I also installed their (Morimoto X3B 3rd brake light with flashing module) none of which caused any issues with Alpha Rex tails.
    BabyBilly likes this.
  6. Sep 9, 2025 at 12:43 PM
    K9tacoma
    K9tacoma Well-Known Member
    Austin
    Central Ohio
    2023 Tacoma TRD Off Road - Lunar Rock
    Do you by chance still have your OEM taillights? I'd personally test how those work as well in addition to the AlphaRex so you could maybe show to them it's isolated to their taillight
  7. Sep 9, 2025 at 12:58 PM
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    I'd put the OEM tails back on and be done with it. You could trouble shoot and try different resistor as mentioned before, but these threads about aftermarket LED turn signal lamps come up often enough for me to stick with OEM lightning. Yourself, and other folks are probably more adventurous than I am whennit comes to getting aftermarket and custom lighting to work.
  8. Sep 9, 2025 at 1:01 PM
    SconnieTaco60
    Stock
    Unfortunately I already sold my OEM taillights after I bought my Alpha Rex tails. I've got the Alpha Rex reinstalled and they're working fine. (Just wish the Morimoto XBs would've worked also.)
  9. Sep 9, 2025 at 1:27 PM
    4x4junkie
    4x4junkie Well-Known Member
    So Calif. (SFV)
    2018 TRD Sport ACLB MT
    If one side of your truck works with both Morimotos and the other side works with neither, that says to me it is something with your truck (maybe the Alpharex doesn't draw enough current for the problem to reveal itself).
    I'll 3rd putting some stock bulbs back in so you can troubleshoot it.
    You only need the bulbs plugged into the sockets for troubleshooting (don't need the whole housings).
