Issues with service at dealer - 2018 Offroad
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Gundersniff, Mar 29, 2019.
  1. Mar 31, 2019 at 2:51 PM
    NYCTaco52
    NYCTaco52 Half man, half goat
    Somehow known as Stewart, but named Ben
    Ft Lauderdale, FL
    2022 Subaru Ascent
    It’s respones like this, that make people wonder why they ask legitimate questions for help. :facepalm:
    Taco1.1, Flash1034 and rzgkane like this.
  2. Mar 31, 2019 at 2:51 PM
    ferntr33
    ferntr33 Well-Known Member
    So do they say the airbags blow up and kill people on several vehicles so that is normal as well? Bring stuff back in and make sure to get print outs of paperwork. Paper trail is always good to have should things escalate to lemon law stuff.
  3. Apr 1, 2019 at 12:44 PM
    chaotic_taco
    chaotic_taco Well-Known Member
    ATX
    2017 DCSB TRD OR MT
    Have you read the TSB or heard from people who get the fix for the diff whine? The fix is to add spacers to the rear springs or some such (I read it on Tacoma World, it must be true), so the sound isn't transmitted along metal components. They don't actually change anything about the way the differential operates, it's an "auditory" cosmetic problem.
  4. Apr 1, 2019 at 1:35 PM
    Dom Mazzetti
    Dom Mazzetti Well-Known Member
    Dom
    when does the diff make noise? My truck has a noise i can hear at 1200 or so RPM and i can't tell if its exhaust noise which seems unlikely or the diff.
  5. Apr 1, 2019 at 1:50 PM
    rzgkane
    rzgkane Well-Known Member
    Huntington Beach, CA
    2019 Tacoma TDR Sport 4WD DCLB - Cement - Tech and Premium
    4Runner Trail wheels and Toyo Open Country ATII tires 265-70-17. Cosmetic stuff like Pro grille and OffRoad black bumper trim, vinyl delete on side, added hood graphic, OEM tube steps.
    Let me see if I have this straight. Those water droplets are from the 3rd brake light, but they are normal because you have a vehicle with a sunroof that will carry the water through the sunroof tray and down to the ground via the sunroof drain lines? If you had a vehicle that lacked a sunroof, those drops would be on your headliner and then the floor of your truck because there is no way for them to find the ground? That's almost the dumbest thing I've ever heard. Almost.
  6. Apr 1, 2019 at 3:02 PM
    Hinder
    Hinder Active Member
    19 DCLB OR
    I had a new Tundra that leaked bad. Sold the truck, luckily I paid $6.5k under msrp. After avoiding Toyota’s for a few years, a couple of years ago bought a new Tacoma ext cab that leaked from day 1. It was the rear door. Dealer could not fix it so I sold it. I recently bought new Tacoma double cab against my better judgement. So far no leaky cab problems. New vehicles should not leak at all, ever.
  7. Apr 1, 2019 at 7:56 PM
    NYCTaco52
    Ft Lauderdale, FL
    2022 Subaru Ascent
    I’ve also been in many brand new Tacoma’s that had zero whine or vibrations. So my point is, if they come without those sounds from the factory, then they shouldn’t have that kind of sound being semi new, and complaining about it is Completely fair. If he was referring to a Tacoma with 80k miles, different story.
  8. Apr 1, 2019 at 8:12 PM
    stun gun
    stun gun Well-Known Member
    Aaronski
    Tacomas.
    17 4X4 sr5spd/01 LT sr5spd
    Your diff should be ok for now. It looks to be dripping @ 2 DPC (drips per century)
    By the time it gets critically low we will have colonized yeranus
    elduder and erics like this.
  9. May 7, 2019 at 7:13 AM
    jrshaw91450
    jrshaw91450 Well-Known Member
    Maui
    2019 Cement Tacoma TRD OR 4x4
    TRD Cat back & Skid plate
    I’ve been to hell and back with the differential whine. Had a 2017 OR 4x4 AT of which I made the dealership do all TSBs regarding the whine and replace the differential. The TSB did nothing. Whine was just as bad after all parts were replaced and insulation installed. After the differential replacement, the whine seem to be less noticeable, but marginal.
    I have a 2019 OR 4x4 AT now and the noise is just as bad, if not worse. After much frustration I do believe your options are to accept it as a tacoma trait and just enjoy the truck or get some tires that hum just enough that you won’t notice it anymore.
    I haven’t seen any TSBs for the 2019 yet, but when I do, it will be hard for me justify the effort again for such a minimal improvement. After the differential swap the jackasses at the dealership left my driveline baring carrier hanging on by a thread or two. Don't know how it didn’t come off on my way home.
    ryan760 likes this.
  10. May 30, 2019 at 1:57 AM
    Panda2
    Panda2 Well-Known Member
    2019 Silver Tacoma TRD Off-Road 4DSB
    Grrr...that’s frustrating. I understand how upsetting that would be. Whenever I have an issue with my truck I have to weigh how big of a deal the issue is vs. some “clown” jumping in my truck to fix the issue and screwing up something else.
  11. May 30, 2019 at 2:50 AM
    Aldo98229
    Aldo98229 Well-Known Member
    Aldo
    Bellingham, Washington
    2019 Tacoma TRD Off-Road
    FWIW, when I test drove a 2019 TRDOR manual, it did have a very noticeable whine coming from the driveline. To me it seemed normal, based on the fact that the gearing on manual transmission Tacomas is much lower. The lower gearing on manual transmission Tacomas is pretty obvious when you pull out in first gear.
    My Rubicons all whined pretty loudly when I engaged its super low transfer case. I considered it part of the experience.
    Personally I like that whine: it reminds me of a sound characteristic of strong, low-geared trucks.
  12. May 30, 2019 at 4:32 AM
    Burro09
    Burro09 Well-Known Member
    Miami, FL
    2017 Tacoma TRD Pro Cement MT
    My 2017 turd pro MT whines too. I have decided that its not bad enough to have the interior ripped apart for the tsb. There is enough evidence that the noise persists with the TSB and replacememt diffs.
    My diff also has seepage on both sides. This I need to address.
  13. May 30, 2019 at 5:38 AM
    Panda2
    I agree that the whine is something I have heard on almost every manual transmission vehicle I have ever used. From a large tractor to a school bus, etc. obviously this isn’t desirable, but seems normal enough and not something that will hurt the vehicle or effect is longevity. Fortunately I don’t have the 3rd brake light issue or the rear differential leak on my 2019 TRD OR.
  14. May 30, 2019 at 7:20 AM
    TriniPhantom
    TriniPhantom Well-Known Member
    Bay Area, California
    2018 Tacoma TRD Off Road DCSB
    Prinsu roof rack, Budbuilt Sliders, Avid Bumper Guard, MESO Ultimate Turn Signals, Door sill decals, Raptor Lights, Tailgate inserts, Mudflaps, Tri-fold Tonneau, DC Motorsports Muffler Tip, TVD Vinyl Decals, Many Interior Mods.
    I also have a 2018 TRD OR M/T I agree with the general responses here. I have the diff howl. Took it into the dealer, and the master tech confirmed the issue. After they contact Toyota, Toyota informed them that my truck already has the parts per the TSB, and that the noise is a normal characteristic of the truck. Honestly it's just a resonance issue, and there is no effect on performance of the truck, and it causes no damage. There are tons of threads on here about it.
    I also had the diff leak, the simple fix is to have them retorque the bolts and ensure the fluid is up.
    The other stuff is not characteristic. Water in there is a big no no. Either try another dealer or contact Toyota corporate and open up a case with them. Cheers and good luck
  15. May 30, 2019 at 7:43 AM
    #35
    Panda2
    I also changed out my front and rear differential oil to Amsoil. There was a large piece of metal, about 1/4” around that looked like it was from a drill point as it pushed through making a hole. Also, a fair amount of shavings. I highly recommend dumping your rear differential oil.
  16. May 30, 2019 at 10:54 AM
    #36
    95GLH
    95GLH 4WD Noob
    Nick
    Westminster, MD
    1995 Tacoma SR5 4x4, the bottom bitch. 2018 Tacoma 4x4 DCSB OR, wife's truck.
    95 - Rust 2018 - '19 Pro grille, Westin HDX drop steps, Spidertrax 1.5" spacers
    When I bought my 95 SR5 it made a whine, but only when in gear or idling in neutral. It's a high pitch. I put a new clutch/TOB in at 170k and it went away for maybe 10 minutes, then was right back. The 4 dealers I drove up to the techs and asked said all 1st gen MTs do that. The only way to fix it is to move to a 2nd gen or swap to a T56.
  17. May 30, 2019 at 11:09 AM
    #37
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    I have the same truck and options as you. I just had the TSB 0013-18 performed and it reduced the diff whine about 50%. For me, that is acceptable. However, if you want to argue the point, ask them how a MT has anything to do with diff whine (since they specifically told you that). Also, I had some similar oil weeping on the diff. The tech retorqued the nuts and cleaned the oil off. I will continue to monitor that and am good with that as well if it fixes it. Regarding your sunroof, I have a hard time understanding how a 3rd brake light leak would even show up there. If you had a 3rd brake light leak, you would have water leaking down the back window as well. Your truck would smell moldy for sure. I think what you are seeing is the sunroof leaking. A small amount of leaking (dripping) in a car wash scenario is perfectly normal as long as the water makes it out of the truck via the drain tubes. If you see it leaking in a rain storm, I would have they look at it further.
  18. May 30, 2019 at 11:19 AM
    #38
    TacoBella
    TacoBella Well-Known Member
    Tom
    2016 Tacoma (SOLD) leased RTL-E Ridgeline
    AVS Bug Deflector. TruXedo Lo Pro
    The definition of insanity...... doing the exact same fucking thing over and over again, expecting shit to change. That. Is. Crazy. Maybe try the 2020 ?
  19. May 30, 2019 at 11:37 AM
    #39
    btcca4
    btcca4 Well-Known Member
    IMO, the diff isn't even CLOSE to leaking! It is not wet, it is not even damp! Not enough to make one single drop appear on the bottom of the pumpkin. That is probably 2 drops of oil that migrated during assembly at the factory. Do you really want them tearing apart your diff for that? Just tryin' to help but if you are going to do battle with the dealership, choose your battles wisely.
  20. May 30, 2019 at 12:41 PM
    #40
    Bleep100
    Bleep100 TOYOTA 4 LIFE
    17 Sport
    Those rain drops inside the truck is totally unacceptable and would piss me off and drive me nuts , they need to fix that BS . I have a sunroof too .
