Issues with taillight replacement
Discussion in '1st Gen. Tacomas (1995-2004)' started by Kazuboy79, May 12, 2024.
  1. May 12, 2024 at 5:23 PM
    Kazuboy79
    Kazuboy79 [OP] New Member
    Clayton
    2004 Tacoma ext cab 4x4
    6” rough country lift
    I have a 2004 Tacoma 4x4 ext cab that has been passed down from my dad. I replaced the tail lights for a euro looking light housing with normal bulbs but it melted the housing. I ordered a more expensive euro light with led lights and didn’t pay attention to the year being the gen right before my truck.
    I’ve been on forums and saw that some of the wiring doesn’t match and that passenger tail powers thru the driver side. ive bought a OEM set and cut the harness and wired to my new lights.
    I got em to work now for the most part. Tail running lights up, brakes work reverse lights work. But now the issue is only on my driver side the blinker lights up the reverse light. But without blinker the reverse lights up fine. I can’t figure out why the blinker is sending power to the reverse light bulb. any help or advise is greatly appreciated.
  2. May 12, 2024 at 5:59 PM
    Clearwater Bill
    Billy
    Largo Florida
    Off topic, but did your dad do that lift in your profile?
  3. May 12, 2024 at 9:22 PM
    Kazuboy79
    Clayton
    No I did. Got it bone stock when my dad passed away.
  4. May 20, 2024 at 7:57 PM
    Kazuboy79
    Clayton
    Nobody got any ideas about this???
  5. Apr 27, 2025 at 6:00 AM
    Killem_saufley45
    Killem_saufley45 Member
    2004 Tacoma sr5 4wd
    Having a similar issue on my truck right not putting LED trailer lights on. Somehow the right running light is hooked to the reverse light. Did you ever figure it out?
    ControlCar likes this.
  6. Apr 29, 2025 at 8:29 AM
    Youreekaa
    Youreekaa Member
    Bloomfield, MI
    1996 LX Extracab 5spd 4x4; 2001 SR5 Extracab Auto 4x4; 2001 SR5 Singlecab 5spd 4x4 Flareside
    All running and driving, mostly stock, all in various states of rust rehab from Michigan winters
    I found the connector to be corroded and loose in my own taillight replacement journey. higher resistance does manifest itself as heat, but not sure the 10A would allow for enough to melt anything. it may be worth looking into it, as I only had to de-pin the connector, wire wheel the individual pins, and tighten them up with a pair of needle-nose pliers.
    Killem_saufley45 likes this.
  7. Apr 29, 2025 at 4:37 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    It’s the LED bulbs
    I went through same thing
    Real strange/exorcist stuff happening
    -reverse lamps work but one brake lite on
    -blinker would flash then opo side running lamp stays on
    the housings (that came with leds) looked/fit fine
    I ditched all leds, replaced with conventional bulbs…..all is well
    Youreekaa likes this.
