issues with the transmission maybe??
Discussion in 'Technical Chat' started by tacoshin, Oct 13, 2016.
  1. Oct 13, 2016 at 6:39 AM
    tacoshin
    tacoshin [OP] Well-Known Member
    Brian
    the name of my truck, WA
    2008 Lexus IS250 AWD/2014 Tacoma SR5 4x4 short bed
    Smittybilt step bars, Toyota skid plate, All Pro bed rack w/ tonno pro retrofitted thanks to pushingcasket for helping, trd exhaust 14019 miles
    so here is my issue with my truck, when I accelerate like normal driving, its ok but after I let off the gas and let it just cruise, you can hear this whomp....... whomp....... whomp....... seems like after every rotation. but also lets say I step on the gas a little bit, like going on the on ramp to the freeway, it will stay on 3rd for a little bit and shift 4th kind of like a jump to 4th. Auto Trans by the way. and on the street when it shifts to 5th at 40mph it sounds like a diesel truck while cruising at 40 mph the rpm is about 1100 on 5th at 40 mph. could it be the transmission fluid being low that it makes the whomp sound?? or is it that the carrier bearing needs spacers? cause when its on 4wd hi, it doesn't make any whomp sounds or all the above. I only have 19700 miles on my truck but I am also gona take it to the dealer tomorrow to see whats up or if the trans fluid is low. plus its still under warrenty.
  2. Oct 13, 2016 at 6:05 PM
    nuphysalis
    nuphysalis New Member
    TJ
    I would start off by checking the tranny fluid. Auto trans can get wonky when they are low on fluid. Its a good place to start and is a cheap and quick fix if it is the issue.
    tacoshin[OP] likes this.
  3. Oct 13, 2016 at 7:23 PM
    tacoshin
    Brian
    Thanks yeah gonna takeep it to the dealer since it's under warranty and ask them to grease up the u joints and etc while they doing the Trans check
  4. Oct 14, 2016 at 11:28 AM
    tacoshin
    Brian
    Tranny is good told them to rotate the tires the driver side front must have a flat spot on it. Damn dunflops
  5. Nov 4, 2016 at 8:59 AM
    tacoshin
    Brian
    well after driving a few...... its not the flat spot. I can move the cv axle about half inch upwards so im guessing its the bushing inside the diff that connects to the cv uuggghhhhh im guessing get the ecgs bushing??
  6. Nov 8, 2016 at 5:55 AM
    98tacoma27
    Ben
    Not Beech Creek
    Are you moving the axle or the cup? The cup should not move vertically but the axle will have some play.
    If you still have warranty left, I'd milk it for what's it worth.
  7. Nov 8, 2016 at 6:04 AM
    tacoshin
    Brian
    yeah it is move vertically about 1/2inch up but dealer cant replicate the sound so SOL until it comes back well it does come back when I warm up but after driving it for awhile it goes away. its a hit and miss. im thinking of getting the ecgs clamshell to counter that
  8. Nov 17, 2016 at 7:08 PM
    Watson662
    Watson662 Member
    chris
    north MS
    01, 3.4Lv6, SR5, TRD, 4:10 gears. avid duck killer
    cv joint bad. idk about your tranny noises. could be am million different things.
  9. Nov 18, 2016 at 6:38 AM
    tacoshin
    Brian
    it is the cv. just ordered the ecgs bushing so when I get it hopefully find time to install. I swear whats the point of having warranty if they are not gonna let you use it. dealers find ways to by pass shit like this
