Issues with two sets of wheels and TPMS
Discussion in '3rd Gen. Tacomas (2016-2023)' started by phdog, Nov 29, 2022.
  1. Nov 29, 2022 at 1:03 PM
    phdog
    phdog [OP] Well-Known Member
    Jim
    Northern Colorado
    2017 TRD Off Road
    w/Super Terrific Happy Hour Mod
    I have two sets of wheels, winter/summer, with their own TPMS sensors. Every time I swap I have to go back a few days later for them re-sync the new sensors. I doubt they are just forgetting as it happens every time on two different vehicles. I suspect it might be because the currently synced wheels are in the back, but it doesn't make sense that if it's reprogrammed it wouldn't take.
    Any idea why this keeps happening and how to avoid it?
  2. Nov 29, 2022 at 1:16 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    vicali likes this.
  3. Nov 29, 2022 at 1:20 PM
    vicali
    vicali Touch my camera through the fence
    mike
    Kam,BC
    2017 TRD Sport 1D6
    Your options are:
    1) get a programmer to put in the new codes.
    2)clone the codes into the new TPMS so the truck 'sees' them as the same 4 after the swap.
    3)Ignore the light for half the year. <- I do this one!>
  4. Nov 29, 2022 at 1:25 PM
    ToyoTaco25
    ToyoTaco25 Well-Known Member
    North Carolina
    09 Super-White DCSB 6-Speed
    ProComp 4" D-Bag, I mean Drop Bracket Lift, AMP Research Powersteps, 285/70-R17’s, Magnaflow, AFE CAI, Dipped Badges
    Who needs a sensor to tell them their tire is flat anyways lol
    9th, Barrydd and vicali like this.
  5. Nov 29, 2022 at 1:50 PM
    phdog
    Jim
    Northern Colorado
    2017 TRD Off Road
    Just to clarify, it's not that I need to program it, Discount Tire does that when they swap. The problem is that it doesn't work and I have to go back and have it done again. I'm wondering why it doesn't work. They scan the new sensors and hook up the gizmo to reprogram but it doesn't take. Happens every time. I can't be the only this happens to as it happens every single time. No one at DT can explain it nor do they have a fix.
    After the second trip it always works.
  6. Nov 29, 2022 at 1:53 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Like you mentioned, it's probably something to do with other set in back of truck. Just a wild guess.
  7. Nov 29, 2022 at 2:05 PM
    phdog
    Jim
    Northern Colorado
    2017 TRD Off Road
    I suspect that's the cause, but I don't understand why. They scan the new codes and reprogram via the OBD port so why doesn't it take.
  8. Nov 29, 2022 at 2:19 PM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    when they reprogram each set of sensors...verify what 4 sets of ID numbers where programmed and check the ID#'s in the tpms system data list
    sometimes when programming sensors they can detect other sensors up to 10 feet away
    na8rboy likes this.
  9. Nov 29, 2022 at 2:52 PM
    eurowner
    eurowner Duke Sky
    Scoty
    The Easiest setup is to have your second, third, etc, set of wheels have Clone sensors, (Autel 315MX is what I use), installed with the OEM TPMS sensor ID#s added to the new sensor. The truck sees the same 4 ID#s so it's bolt em on, TPMS button activation, and go!
    No programming the truck! Then you can swap all four at your own convenience.
    I have three sets and only 4 sensor ID#s.
    zacinnc78 and na8rboy like this.
  10. Nov 29, 2022 at 3:11 PM
    phdog
    Jim
    Northern Colorado
    2017 TRD Off Road
    Thanks. I already have the sensors and not sure if they can be cloned. I'll have to see what I can find out. I "think" they are OEM sensors not aftermarket so maybe that means they can't be cloned.
