It’s official, the 2023 is the Tacoma to have
Discussion in '4th Gen. Tacomas (2024+)' started by Wwjvd, May 19, 2023.
  1. Nov 13, 2023 at 7:03 PM
    #261
    Horseshoez
    Horseshoez Well-Known Member
    Dale
    Maryland
    You are wrong, I've had a number of turbocharged cars over the years and all of them have made it well past 150,000 miles with zero engine issues; two of them made it over 200,000 miles, and all of them were still running great when I sold them. That said, my experience is irrelevant; what is relevant is the modern metallurgy, modern engine design, modern engine controls, and high quality synthetic oils; with all of those things working in Toyota's favor, the only reason why the new engine will have long term reliability issues if they screw up big time.
  2. Nov 13, 2023 at 9:19 PM
    #262
    OpeCity
    OpeCity Well-Known Member
    Long Beach, CA
    Higher internal pressure, oil temp, water temp, and those dangerous low friction rings for mpgs have led us to…*checks notes* far better reliability than when we had engines without those things?
    And by this i mean: We’re running high compression 6cyls at extremely lean mixtures with super thin oil and low tension rings at higher than ever temperatures and all the other things our parents were afraid of…and here we are proudly proclaiming our 3rd gens to be god’s gift. Maybe we can just let the thing even come out before condemning it to the scrap heap of history.
    Junkhead and DRAWN like this.
  3. Nov 14, 2023 at 6:20 AM
    #263
    jaxyaks
    jaxyaks Well-Known Member
    2020 Silver Tacoma TRD Off Road
    If referencing the video he did not say that the turbos were bad, he did not relegate it to the scrap heap of history, actually it had a few tips for those interested in ways that you can help extend the life of the turbo. He also said that the reliability gap is narrowing because of the some of the same things you mentioned.
    tneynop likes this.
  4. Nov 14, 2023 at 6:35 AM
    #264
    Horseshoez
    Dale
    Maryland
    I think the point you missed is the advice he is giving on extending the life of the turbo is about 40 years out of date.
    OpeCity likes this.
  5. Nov 14, 2023 at 9:03 AM
    #265
    jaxyaks
    So your saying more frequent oil changes (5K intervals) instead of the 10K recommendation that is spec'd for every toyota no matter what engine configuration it has will do nothing to help extending the life of the turbo charger? You are saying fresh oil does nothing for a turbo charger?
    You are saying its not a good idea to let a turbo cool a bit before shutting it off since it doesn't matter anymore? It's interesting that manufactures actually include technology with some turbos to do just that, to keep ignorant customers from cooking their turbo's prematurely. I guess they don't need to do that anymore.
    Interesting...
  6. Nov 14, 2023 at 9:10 AM
    #266
    Horseshoez
    Dale
    Maryland
    You do understand we're talking about using high quality synthetic oil and a turbocharger which features water cooled bearings, right?
  7. Nov 14, 2023 at 9:46 AM
    #267
    jaxyaks
    You sure its not both water and oil cooled?....water cooled coming into play more for the after you shut it down cooling.
  8. Nov 14, 2023 at 9:48 AM
    #268
    GBR
    GBR Well-Known Member
    19 TRD OR
    I'm not saying the guy was wrong about everything he said, but some of it was misguided or downright bad advice imo.
    Change the oil however much you want, it won't hurt anything. But you can never know if changing out perfectly good oil actually contributed to longevity. Having an engine go the distance (200k+) is such a crapshoot. You could change the oil every 3k miles and an unknowable microscopic manufacturing defect can grenade the whole engine at any time.
    As far as cool down goes, sure if you just pulled a heavy load up a grade and immediately came into a rest stop, might be a good idea to let it idle a bit. That would be true for a NA engine as well. For the other 99% of your driving, you don't need to be idling in the grocery store parking lot waiting for your turbo to "cool down".
    In a manual transmission, I'd argue digging deep into the throttle to maintain speed vs a downshift is going to put more stress on your engine.
    Bottom line is everything that was good operating practice for NA engines is also true for turbo engines and vice-versa. There really isn't anything special going on.
    Junkhead and jaxyaks like this.
  9. Nov 14, 2023 at 11:24 AM
    #269
    Horseshoez
    Dale
    Maryland
    Argh, you are taking it too literally, ALL bearings of ALL turbosuperchargers since the very beginning are lubricated and cooled by oil while the engine is running, that is a given. What I'm talking about is the water cooled bearing feature added to commercially available units by Garrett Airesearch back in the early 1980s; the water cooling addition was designed specifically to keep the bearings cool (and prevent coking) after the engine was shut down and the flow of oil stopped. Like I said, the advice from the dude who made that video was easily 40 years out of date.
  10. Nov 14, 2023 at 11:38 AM
    #270
    jaxyaks
    So the oil is still used, and I would assume higher temps and more strain on the oil therefore the advice to change the oil at 5K intervals is not that outrageous at all. He recommends 5k OCI on normal Toyota engines so not surprising that the turbo motor gets the same advice. He covers the water cooling on normal operation with the new technology, I don't think its bad advice to mention if you are wringing the motors neck that its not a terrible idea to give it a minute or two before shutting off the motor.
    Seems to be pretty familiar with this new motor to me, This model should be pretty similar.
    https://youtu.be/DqJJ5juYwGg?si=UMzHbEPRIduDNYQm
  11. Nov 14, 2023 at 11:49 AM
    #271
    Williston
    Williston Well-Known Member
    New England
    2014 Tacoma 040 SR5 4x4 DC SB V6 AT5 Tow Pkg Entune+ Mostly stock with a few OEM mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter) OEM All-Weather floor mats (summer).
    Volvo has been making turbo-charged engines since the early '80's and added water-cooled turbo bearings early on. This eliminated the need to allow them to spin down and idle the engine engine so the oil wouldn't cook in the bearing after shutdown and ruin it. They had oil jets under the pistons to cool the skirts, sodium-filled valves and other goodies specific to the turbo engines. All you really had to do was change the oil and filter religiously as per spec and just drive them. Turbo problems were rare.
    Many aircraft engines are Turbo and Super charged (going all the way back to WWII in military aircraft) and I don't worry about a turbo exploding in flight. I worry more about bird strikes than just about anything else.
    Horseshoez[QUOTED] likes this.
  12. Nov 14, 2023 at 11:49 AM
    #272
    Horseshoez
    Dale
    Maryland
    All of your assumptions are based upon urban legend and are utterly irrelevant. The fact is, assuming an appropriate oil capacity, the oil in a a turbocharged engine will not run any hotter than a normally aspirated engine.
  13. Nov 14, 2023 at 11:56 AM
    #273
    OpeCity
    Long Beach, CA
    How many people pull a hill at full throttle and then shut down immediately? Just the time spent coming into your neighborhood or into a parking lot is more than enough to cool down the turbo. It’s almost never an issue at all
  14. Nov 14, 2023 at 11:58 AM
    #274
    jaxyaks
    Do you think you need to keep a closer eye on oil level
  15. Nov 14, 2023 at 12:08 PM
    #275
    jaxyaks
    Ok
  16. Nov 14, 2023 at 12:37 PM
    #276
    Horseshoez
    Dale
    Maryland
    Why; turbocharged engines don't use anymore oil than a normally aspirated engine.
  17. Nov 14, 2023 at 12:40 PM
    #277
    jaxyaks
  18. Nov 14, 2023 at 1:10 PM
    #278
    Williston
    New England
    Might be true for BMW. dunno. But my current 5 cyl turbocharged inter-cooled Volvo S70 uses no oil between changes and it's currently sitting at 175k miles. Oil changes have been between 3-5 thousand miles it's whole life. I put 300k + on two Volvo 245's and 240k on a 745. None of them burned any oil. My Tacoma uses no oil either.
    jaxyaks[QUOTED] likes this.
  19. Nov 14, 2023 at 1:12 PM
    #279
    Hogleg918
    Hogleg918 Well-Known Member
    Oklahoma
    Ranger Raptor, sorry TW
  20. Nov 14, 2023 at 1:31 PM
    #280
    OpeCity
    Long Beach, CA
    Same with our cx5. Zero oil consumption between changes. Can’t say the same about my 3rz
