It Begins: Miss Blue
Discussion in '2nd Gen. Builds (2005-2015)' started by jandrews, Jul 7, 2009.
  1. Aug 14, 2012 at 2:51 PM
    #661
    jandrews
    jandrews [OP] Hootin' and Hollerin'
    '09 FourDubDee TRD OR
    Why not?
    Real answer: Build time. Icon was currently out of stock of the smooth bodies. If I'd gone smooth, it would've taken about 4 weeks to get the new bodies in and get the shocks built. They had threaded bodies in the shop and could have my shocks built and shipped in 4 days.
    You can make the argument the threads act like radiator fins and allow for better cooling [​IMG]
    Incorrect. Cutting through the bed is what I'm trying to avoid.
    Edit: Also worth noting: Straight up and down mounting is not a 1:1 ratio with travel, as the axle moves in an arc when stuffing or drooping. That said, it's probably close enough it wouldn't throw your measurements off too much as long as you build a little (.5" or so at either end) error into the shock travel.
  2. Aug 14, 2012 at 3:02 PM
    #662
    theduck911
    theduck911 Max's Canadian Twin
    Max
    Northwestern Ontario, Canada
    Locked and Geared!
    Really, interested to see that then, as It seems as with other members' trucks that anything greater then a 12" Shock is too tall to avoid cutting or ridiculously wide spacers to avoid contact with the shock body,:notsure:
    I understand that, just for the sake of simplicity it is to be considered 1:1 when mounted vertical orientation, but it is worth noting :thumbsup:
  3. Aug 14, 2012 at 3:04 PM
    #663
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    Glad to see you skipped over shock warehouse for those :D
  4. Aug 14, 2012 at 3:11 PM
    #664
    jandrews
    I've had some input from some crackerjack motherfuckers on how to pull this off...I think everyone'll find the final result very interesting :)
    Do they even carry Icon? :laugh:
  5. Aug 14, 2012 at 5:12 PM
    #665
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    Looking forward to seeing what happens... :popcorn:
  6. Aug 14, 2012 at 6:52 PM
    #666
    tacoman15
    tacoman15 Boobies
    Northeast Georgia
    2015 Tacoma TRD OR & 1985 SR5 4Runner
    Someone has to prove everyone else wrong.
    Looks good man hope to see them in action soon.
  7. Aug 14, 2012 at 7:27 PM
    #667
    jandrews
    Not really proving anyone wrong, just think things can be done in a different way from how they have been and it will suit my preferences better.
  8. Aug 20, 2012 at 8:29 PM
    #668
    FrustrationFabTaco
    FrustrationFabTaco Well-Known Member
    Luke
    Lexington, VA
    11 Duramax Grandpa Truck Special
    :spy:
    can you post some pics of how the bars mount into the rails?
  9. Aug 20, 2012 at 11:46 PM
    #669
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    Great build. I can't wait to see the new wheels on there all scratched up:D.
  10. Aug 21, 2012 at 4:40 AM
    #670
    jandrews
    Nothing special...the bars have a flange on each end that mounts flat against the bedrail track, each with two bolt holes. T-nuts in the bedrail track, bolt/washer through the drilled flange, mounted bed rack.
    :cool:
    And they will be!
  11. Aug 21, 2012 at 4:46 AM
    #671
    Namyo
    Namyo -
    Bout ten pages of ketchup, good stuff John :bowdown:
  12. Aug 21, 2012 at 5:00 AM
    #672
    Slimwood Shady
    Slimwood Shady I love your mom!
    Linwood
    San Antonio, TX
    '23 TRD Pro Tundra; 996TT; '16 Odyssey
    #nomods
    Which wheels you going with John
    EDIT: Never mind...a little stalking and I found out for myself...:spy:
  13. Aug 21, 2012 at 8:37 AM
    #673
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    Hmm my rear shocks are 36" ext and 24" collapsed, no cutting of my bed either, you should be very similar to my set up :thumbsup:
  14. Aug 21, 2012 at 2:05 PM
    #674
    jandrews
    Yeah, but yours are way up high. Get any wheel contact with the shock body?
  15. Aug 21, 2012 at 2:31 PM
    #675
    Warhorseforever
    Warhorseforever Will The Thrill
    Will
    Sand Lapper
    2001 Toyota Tacoma Pre-Runner SR5
    Kenwood KDC-348U HU Kicker DS65 Front Doors Only 2 Polk Audio MM840 Kenwood KAC 8105D for subs SuperCrewSound.com behind rear seat sub box
    Why would you have to cut the bed, and where, if you were to do it that way?
  16. Aug 21, 2012 at 2:37 PM
    #676
    jandrews
    The longer the travel of the shock, the longer the compressed length of the shock. Once you get to a certain length, you have to go into the bed to fit it on the truck at all.
    You see this a lot on long travel setups.
  17. Aug 21, 2012 at 2:50 PM
    #677
    NYCO
    NYCO go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    i must have missed it, but how are you planning on fitting those monsters under your truck?
    you getting some shock hoops or new mounts made?
    without shocks in and lifted via shop lift, my eye to eye extended was only 26"...
    :popcorn:
  18. Aug 21, 2012 at 3:06 PM
    #678
    jandrews
    You're not going to fit anything larger than about 10in travel in the stock mounting locations.
  19. Aug 21, 2012 at 3:11 PM
    #679
    tacoman15
    tacoman15 Boobies
    Northeast Georgia
    Is it possible to mount them like /\? Never seen resis mounted like that before (probably because the hoses aren't long enough?)?
  20. Aug 21, 2012 at 3:15 PM
    #680
    XXXX
    sKiP
    05 Prius
    I had to drop this in here for you buddy
