It Begins: Miss Blue
Discussion in '2nd Gen. Builds (2005-2015)' started by jandrews, Jul 7, 2009.
  1. Mar 31, 2013 at 10:36 AM
    #981
    jandrews
    jandrews [OP] Hootin' and Hollerin'
    '09 FourDubDee TRD OR
    Maybe, but unlikely. Have to work Saturday. Is this another lunch?
  2. Mar 31, 2013 at 10:46 AM
    #982
    Chad
    Chad Well-Known Member
    Chad
    Cary, NC
    09 V6 Access Cab TRD Sport
    Kenwood DMX-7704S Headunit -- Blackvue DR-470 Dashcam -- Pioneer TS-A1685R Speakers in Front -- Suntek CXP 40 Front Tint -- Access Vanish Roll-up Tonneau -- Wet Okole Seat Covers -- Fog Lights on Anytime -- PnL Powered Tailgate Lock -- DTRL "Stealth Mode" -- LED Footwell and Cup Holder Lights -- Map Lights ON with Dome Light -- Shorty Antenna -- AC Line Extension Mod -- Access Cab Rear Headrest Removal
    Yeah lunch at 1pm.
  3. Mar 31, 2013 at 11:46 AM
    #983
    jandrews
    I'll be workin.
  4. Mar 31, 2013 at 12:10 PM
    #984
    jerretxx
    jerretxx Some do, others talk
    Jerret
    North Carolina
    2017 DCSB Tacoma TRD Sport 4x4
    I really like that sPod, that things nice! Ill have to incorporate that on my next build, hopefully ill be bringing it home tomorrow
  5. Mar 31, 2013 at 1:30 PM
    #985
    jandrews
    It'll work in any vehicle. The only item on it that's really Tacoma specific is the mounting bracket and the switch wire harness is designed to use the factory blank locations.
    It'd be super easy to re-do the switch wiring harness if it wasn't set up the way you want.
  6. Apr 2, 2013 at 3:35 PM
    #986
    whiteboy
    whiteboy Well-Known Member
    Cody
    Glendale, AZ
    '06 TRD sport
    Kings, alcans, 33's blah blah read my build thread in sig
    WILSON ANTENNAS 1000 Series Roof Top Mount Mobile CB Antenna Kit 880-900802B
    Is this the mount you went with? So you just had to cut a hole in the roof and you ran the wire through your headliner? How do you like your CB radio? I'm trying looking around at different options as I need one in my truck. I'm trying to decide if it's worth it to get what you have or just a Uniden PRO520XL 40-Channel CB Radio with a firestik or something. I only really plan on using it when on trails during meets with other TW members. I'm thinking what you have, as nice as it is, might be a tad bit overkill :p
  7. Apr 2, 2013 at 4:39 PM
    #987
    tacoman15
    tacoman15 Boobies
    Northeast Georgia
    2015 Tacoma TRD OR & 1985 SR5 4Runner
    If you are just planning on using it for trails, I would go the Firestick route. The Wilson 1000 maybe "overkill", but I like his approach to doing everything right the first time. Overkill is underrated IMO, but not all of us can afford it :laugh:
  8. Apr 2, 2013 at 4:53 PM
    #988
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    i agree with this part. im normally just talkin to the dood in front of me or behind me while on a trail
  9. Apr 2, 2013 at 5:00 PM
    #989
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    Wilson 1000's on low trails will not last IMO. I got multiple dents in my roof - would of ripped one of them off by now for sure. BGR lasted all of 5 minutes in my local trails with his roof mounted antenna before it broke off [​IMG]
    Moral of the story is ......Each antenna has it's pro's and con's and everyone has different needs. Tailor your mods to your needs with research and common sense and you should be good to go.
    My antenna is under my bed rack mounted on my rear bumper and I can still hear someone literally 4 miles away through trees.
  10. Apr 2, 2013 at 5:22 PM
    #990
    ckeene9
    ckeene9 Well-Known Member
    Chesterfield, VA
    '12 DCSB Supercharged 4x4 TRD Sport
    See Build Thread
  11. Apr 2, 2013 at 5:55 PM
    #991
    jerretxx
    Jerret
    North Carolina
    finally got myself another ride, ill check out adding one of these to it
  12. Apr 2, 2013 at 7:46 PM
    #992
    jandrews
    You might not be wrong. My philosophy is do it best possible within the application.
    I wanted my CB to reach Mars. For CB function, you can't beat using the roof metal as a ground plane. You simply won't find another location on this truck with that much metal in the same place. Bed mounts work well in most pickups because the bed is steel. Not here.
    Regardless of what setup you go with, take the radio/antenna to a CB shop prior to install and get them peaked and tuned. It makes a world of difference. And invest in a quality antenna. CBs are 60 year old technology...they're all pretty much the same. The stick they're firing out through is what matters most.
    As for trail clearance, I've taken mine under stuff within 10" of the roof without issue. The whip is extremely flexible. Makes a lot of noise up there hitting low branches though.
    It is expensive :(
    And I've still had a few do-overs, like the leaf springs and PIAA lights, and two god damn factory ring and pinions :mad:
    Word. Be careful. If you get addicted (like me) you're never gonna settle for regular wiring methods ever again.
  13. Apr 2, 2013 at 8:03 PM
    #993
    FrustrationFabTaco
    FrustrationFabTaco Well-Known Member
    Luke
    Lexington, VA
    11 Duramax Grandpa Truck Special
    :spy:
    Dents from trees or what?
  14. Apr 2, 2013 at 8:32 PM
    #994
    whiteboy
    Cody
    Glendale, AZ
    '06 TRD sport
    Hmm. I'm very tempted to do what you did but I think it's overboard for the very little use it will end up seeing. Do those brackets that you mount under your hood and they pop out the side work well? I've seen them mounted to that and the bed rails with the wire ran and grounded to the frame somewhere. I'm not sure on what antenna to get still but I need a removable one as I don't want it on my truck 24/7 where someone can steal it.
  15. Apr 3, 2013 at 6:52 PM
    #995
    jerretxx
    Jerret
    North Carolina
    I agree. I still haven't made a decision if I am going to build this one or not. There are several built trucks around that wouldn't cost much more then doing this one. Decisions decisions
  16. Apr 3, 2013 at 7:17 PM
    #996
    jandrews
    Building 'em is more fun, but after spending the last 2.5 years on this thing...I am sorta ready for it to be "done". All that's really left is the winch stuff and dual battery.
  17. Apr 3, 2013 at 8:35 PM
    #997
    superwhite10
    superwhite10 Well-Known Member
    Garner, NC
    Shit first time i saw the price of the sPod I did a :eek: it costs THAT much for that?!...but after wiring my first minor accesory and with the thought of one day adding more it all makes since to me now. That price doesnt look so bad anymore :cool:
  18. Apr 4, 2013 at 6:29 AM
    #998
    tacoman15
    tacoman15 Boobies
    Northeast Georgia
    You should do a slammin' Sammy build!
  19. Apr 4, 2013 at 9:07 AM
    #999
    jandrews
    Too tippy.
    Next project will probably be a beater yota build. I like the idea of putting a third gen 4runner on a trailer.
  20. Apr 4, 2013 at 9:14 AM
    #1000
    WTFaulkner
    WTFaulkner Well-Known Member
    Kris
    SLC
    Tacoma
    Stuff
    Sick truck man great job! :thumbsup:
