It Begins: Miss Blue
Discussion in '2nd Gen. Builds (2005-2015)' started by jandrews, Jul 7, 2009.
  1. Apr 23, 2013 at 2:59 PM
    #1101
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    u do know that there are a few compentent mechanics that work at dealerships right? maybe not all, but some actually do have them. shocking i know
  2. Apr 23, 2013 at 3:12 PM
    #1102
    jandrews
    jandrews [OP] Hootin' and Hollerin'
    '09 FourDubDee TRD OR
    Yeah, but the markup man...the markup.
  3. Apr 23, 2013 at 3:22 PM
    #1103
    jbmccul
    jbmccul Well-Known Member
    2021 GMC Sierra AT4, 2019 Audi A5, 2017 Audi Q5
    I get parts and labor at cost
  4. Apr 23, 2013 at 3:29 PM
    #1104
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    phewww breaker bar and 1/2" drive extension and those nuts finally came off.
  5. Apr 23, 2013 at 3:31 PM
    #1105
    jandrews
    That makes it more bearable. Still not great, but I can tolerate it.
  6. Apr 23, 2013 at 3:43 PM
    #1106
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    Even good shops have scrubs from time to time. I interviewed my Firestone by asking questions and telling them up front what I had and what I wanted. It helps if you drive the truck there so you can show them what they need to do. First one was a success so now I schedule my appointments so I have the same guy do the alignments each and every time. All it takes is a little planning, scheduling, and luck on the first try.
    Same place butchered my last tire job I gave them though. Ended up walking out after an argument with the dip shit I spoke to because they used rim weights when I explicitly told them not to. They also never shifted the wheel and tire so some of them had massive amounts of weight on them. I now have a new tire place because of that scrub, but I will gladly take my truck there for another alignment. I actually need one now :D
  7. Apr 23, 2013 at 3:49 PM
    #1107
    jandrews
    I had the best shop in the goddamn world in my last town. It was two mechanics and 3 techs, and the guy who owned the place was like 30+ years of experience. Had done everything from gear setups in funny cars to full on custom coil-link suspensions for rock buggies and every street vehicle you can imagine in between. Transmission rebuilds, fabrication, exhaust, engine rebuilds, regular maintenance, tire work...everything you could want under one roof and super competent.
    I miss the place like no other.
  8. Apr 23, 2013 at 3:54 PM
    #1108
    XXXX
    sKiP
    05 Prius
    How far away did you move?
  9. Apr 23, 2013 at 3:59 PM
    #1109
    jandrews
  10. Apr 23, 2013 at 4:07 PM
    #1110
    jbmccul
    I wheel with the guys so I trust them to do it
  11. Apr 23, 2013 at 4:08 PM
    #1111
    jbmccul
    You lived in Salisbury?
  12. Apr 23, 2013 at 4:10 PM
    #1112
    jandrews
    I did. Really liked it there. May go back one day.
  13. Apr 23, 2013 at 4:39 PM
    #1113
    jbmccul
    Love that area. Almost went to school in Davidson
  14. Apr 23, 2013 at 6:33 PM
    #1114
    NCTacoma
    NCTacoma Rather be in the mtns
    Caleb
    CLT, NC
    Sold- Searching for 1st gen
    Salisbury is a nice town. That muffler shop good or bad? Can't tell by the smiley.
  15. Apr 24, 2013 at 6:53 PM
    #1115
    ajohnson
    ajohnson Glamour Shot
    Andy
    Charlotte, NC
    07 DCLB TRD Sport Prerunner 4x4
    Things and stuff and such
    So your spindle is good? You just knocked the LCA out of alignment?
    Is there a reason you don't gusset your spindles?
  16. Apr 24, 2013 at 7:13 PM
    #1116
    jandrews
    If it's bent, it's not bent enough that it can't be compensated for with alignment. FWIW they look symmetrical.
    Honestly, I haven't bothered with spindle gussets because I've had no reason to tear the front end apart. If I ever bend one enough to cause a problem and need to get them replaced (I have a spare set), I'll gusset the spares before they go on.
    Honestly, I think my superbump bumpstops will save a lot of headache in that department though. They really cushion the blow when you bottom the suspension.
  17. Apr 24, 2013 at 7:16 PM
    #1117
    ajohnson
    Andy
    Charlotte, NC
    Heard that. I guess you should be fine since you don't desert-romp through URE and what not.
  18. Apr 24, 2013 at 7:17 PM
    #1118
    jandrews
    Yeah. If I was out west and hucking it I'd have gusseted them long ago. It's required equipment, kind of like sliders are here.
  19. Apr 24, 2013 at 7:20 PM
    #1119
    jandrews
    I'll deal with it when it happens. 3 years and no problems yet.
    I've had friends do it, but they've had to really thump the truck to do so. I've had a couple "unexpected stops" when something jumps in front of the tire, but it's only ever caused alignment changes.
    I think I'm gonna continue to run the torque on my alignment cam bolts loose-ish to use them as a fuse :)
  20. Apr 24, 2013 at 7:25 PM
    #1120
    ajohnson
    Andy
    Charlotte, NC
    This was my thinking as well.
