it can't start...
Discussion in 'Technical Chat' started by erbalux, Jan 11, 2013.
  1. Jan 11, 2013 at 10:56 AM
    erbalux
    erbalux [OP] New Member
    Houston
    03 4x4 SR5
    Hey, guys i have a 2003 4x4 3.4l it can't start the engine turn very strong and have clicking sound by the fuse box,,, this problem start yesterday i was installing a new alarm getting old alarm out but did not cut any cables just unplug the alarm (non factory alarm) put a new alarm and was staring well and them nothing and a clicking sound start... i don't know if is the fuel pump just need some advise here... thanks...
  2. Jan 11, 2013 at 10:59 AM
    Cbass38
    Cbass38 Well-Known Member
    sebastian
    scottsdale
    07 pre runner
    projector hids,wheels,small lift,flowmaster
    rapid clicking sounds more like a battery
  3. Jan 11, 2013 at 11:05 AM
    Roneyj
    Roneyj Well-Known Member
    Chandler, AZ
    06 Tacoma/05 4Runner
    If it turns over strong its not the battery. Clicking in the fuse box sounds like a relay to me.
  4. Jan 11, 2013 at 11:16 AM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    Clicking typically means the battery is dead.
  5. Jan 11, 2013 at 11:19 AM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    Battery or starter
  6. Jan 12, 2013 at 8:27 AM
    Roneyj
    Chandler, AZ
    Again if the engine is turning over strong it is not the battery or the starter. Also according to the original post the clicking is coming from the fuse box, not the starter.
    Open the fuse box, lay you hand across the relays, try to start and feel which one is clicking. Try swapping it with an identical working relay and see it it solves problem, just remember which one you swapped it with. Or just replace relay.
  7. Jan 12, 2013 at 2:49 PM
    Vstrom30
    Vstrom30 Well-Known Member
    Midwest
    Tacoma Access Cab 4x4
    Are there any circuit opening relays that are part of the old alarm? It may need to be energized depending on the setup in order for the truck to start.
  8. Jan 12, 2013 at 11:42 PM
    erbalux
    Houston
    03 4x4 SR5
    Well... was not a battery cuz engine turn over strong, what it was is a ecm bad, was wet and that produce all kind of problems inside... need to get new one... will post back when i get it and the problem is resolve... Thanks yall.
  9. Jan 27, 2013 at 11:05 PM
    erbalux
    Houston
    03 4x4 SR5
    yeah ecm... get a used one and done... thanks...
