It goes click and then doesn't start...
Discussion in '4 Cylinder' started by Leadgolem, Sep 14, 2010.
  1. Sep 14, 2010 at 11:12 PM
    Leadgolem
    Leadgolem [OP] Well-Known Member
    Greg
    Littleton, CO
    98 Tacoma SR5 2.7L 4x4 stick
    Herculiner bed liner, White LED instrument lights, Custom painted hood, Homemade leather steering wheel wrap, Avic u310bt gps stereo, 1.5" bushwacker fender flares, 1.25" bilstein lift front, 1" shackle lift rear, rear bilstein 5100 shocks, ridiculous helper spring lift rear, wet okole seat covers, mutilated exhaust, boom mat under hood
    Ok, so my truck was doing the "click" and not starting thing. Did some research and it sounded like the starter was worn out. So, I bought and installed a new starter. Problem, the other day the same thing happened again. I did check all the connections when I put the new starter in, and none of them are loose or anything...
    My brother suggested a worn out clutch sensor, but if that was the case I would expect the same symptoms with the clutch not pushed in at all. Now, of course it doesn't start without the clutch pushed in. However, it also doesn't click.
    Ideas/suggestions?
    1998 2.7l 4wd, 5sp manual
    EDIT: Solved. Replacing the ground fixed the issue.
  2. Sep 14, 2010 at 11:26 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Have the battery tested? Does it start with a jump? We have an old 86 toyota at work that will do this when the battery is run down or needs to be replaced.
    You can also check battery voltage at the starter main cable with someone else holding the key in the start position. If you have a bad cable or connection, that would be a way of finding it.
    Edit: Are you sure it's the starter that's clicking? There is a relay somewhere I believe. You should have positive 12 volts at the small wire on the starter with the key in start.
  3. Sep 14, 2010 at 11:32 PM
    Leadgolem
    Greg
    Littleton, CO
    Sorry, I guess I should have given a little more info. I can start my truck. If I rock it back a forth a few times when it does this. This is only a problem about 1/20 times I try to start it.
    I can check the battery, but since it does actually start I don't think that's the problem. I'll try checking the lines and relay like you suggested next weekend and see what I find.
  4. Sep 14, 2010 at 11:34 PM
    SoCalBlack08
    SoCalBlack08 Well-Known Member
    CA
    08 PreRunner DC
    first thing that popped in my head was the alternator
  5. Sep 14, 2010 at 11:36 PM
    efmugen
    efmugen Well-Known Member
    Pasadena,CA
    06 4-banger
    maybe its just the starter.. where did you get it from?
  6. Sep 14, 2010 at 11:40 PM
    Leadgolem
    Greg
    Littleton, CO
    http://www.mean-green.com/
    I don't really think so though, the problem predates the new starter.
    Correct me if I'm wrong, but if the alternator was bad wouldn't I just end up with a dead battery after starting it the first time?
    EDIT: On the other hand, I can use this as an excuse to buy the high output alternator I want...
  7. Sep 14, 2010 at 11:45 PM
    efmugen
    Pasadena,CA
    06 4-banger
    yes, but from your first post it sounds like your car isnt starting at all
  8. Sep 14, 2010 at 11:55 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Check some of the 'ground' wires that may be connected to the engine block or other major areas. These will probably be BIG fat black wires similar in size to the cable on the battery.
  9. Sep 15, 2010 at 2:24 AM
    84Hilux
    84Hilux Well-Known Member
    Gary
    Vancouver, Canada
    09 SR5 Access Cab V6 4X4
    Stock Fog Lights, Camera Mirror, Arrow Canopy, Lighted 4x4switch, Weathertech Mats (Black), Wet Okoles- Black/Charcoal, Alpine CDA117 Headunit/ Alpine PDX4150 Amp/Alpine PDX M6 Amp/ Hybrid Legatia SE Components/ JL 10W6V2 Subwoofer/ Prototype MR Marv Sub Enclosure
    Yeah, it sounds like your starter solenoid is trying to engage the Bendix gear, but does not have quite enough power to force its way in if the gears don't mesh exactly. Clean the battery terminals, make sure they're tight and check your grounds. Load testing the battery would be a good idea too.
  10. Sep 15, 2010 at 5:31 AM
    Barnone
    Barnone Guest
    When you have this failure can you hear the starter motor run?
    By rocking the truck in gear your are turning the engine a little so the starter can engage the teeth on the flywheel. You might be missing some teeth on the flywheel.
  11. Sep 19, 2010 at 8:10 PM
    Leadgolem
    Greg
    Littleton, CO
    When I have this issue the only sound I'm getting is the "click". No starter motor running.
    I found and replaced a definitely faulty ground wire running from the engine to the body. Since this is so intermittent of an issue I do not know yet if this fixed it.
    Thanks for the feedback everybody. If the new ground doesn't fix the problem I have some other things to look for. I'll post back in a couple weeks and let you all know if that was the problem. Since this is happening only once or twice a week it will take me 2 to be sure if that was it.
  12. Sep 19, 2010 at 8:21 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Tell me about this "new" starter? If it's a rebuilt, then who knows what you actually have. If it were me, I would pull it out and take a look at the solenoid contacts. Very common issue on nippondenso starters.
  13. Sep 19, 2010 at 8:41 PM
    Leadgolem
    Greg
    Littleton, CO
  14. Sep 19, 2010 at 9:10 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Maybe you are hearing a relay click and not the starter itself? Not sure of the exact layout on these trucks, the old toyota trucks had a relay mounted on the fender that would click pretty loud even with the starter itself disconnected. It could be that you have a worn ignition switch or relay that is not giving high enough voltage to the starter itself to engage the starter.
    Not sure how comfortable you are with wiring, but you might consider wiring in another relay. You could use the existing small wire going to the starter to activate the coil of the new relay. Then run a dedicated wire from the battery through a fuse, through the new relay and down to the starter itself. The new relay only takes a little bit of power to activate and should not be a problem to turn on with a marginal factory switch, relay or wiring. Just an idea, I have seen it done on other vehicles to solve similar issues. Can't really explain why rocking the truck will cause it to start.
  15. Sep 29, 2010 at 4:26 PM
    TacoNinja12
    TacoNinja12 Well-Known Member
    Boone NC
    99 2.7L SR5
    3 inch lift
    starter it happened to me once! click and nothing, but if you keep on doing it over and over you might get lucky
  16. Sep 29, 2010 at 4:30 PM
    Eman5pt0
    Eman5pt0 Well-Known Member
    E
    NY
    yeah sounds like the starter ... are u sure its bolted in tight ? and its meshing with the flywheel ?
  17. Sep 29, 2010 at 4:31 PM
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    same thing just happen to my moms 03 4runner the otherday. the connection on the negative terminal of the battery was a little bit to loose. put some baking soda on it to clean it then squished it with a pair of channel locks to give it a 0 shape isntead of a O shape. gave it a tighter connection and it started right up
  18. Sep 29, 2010 at 4:31 PM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2012 DCLB
    Grillcraft mx black upper and lower BHLM with Gloss black 265 70 17 bfg a/t center console light mini mag mounted in center console debadged bed lights 35W 5000k HID's
    clean your battery terminals and connections, MY bet is that your not getting enough power from the battery, due to a shitty connection.
    also, follow the battery cables and make sure everything is snug.
    also, try to start it, if it clicks, go pull the battery cables (ground and hot) in some random directions and see if anything changes. this is happening with my mustang too, and seems to be the issue
  19. Sep 30, 2010 at 12:30 AM
    Leadgolem
    Greg
    Littleton, CO
    I was going to wait longer to update this, but since it floated to the top...
    After replacing the faulty ground I haven't had the problem again. Since this is only an issue once or twice a week it hasn't been long enough for me to be sure, but I do think that was it.
    I replaced the battery terminals with good brass ones when I got the truck almost a year ago. I'd already checked the connections between the battery and the starter, as well as the battery connections themselves.
  20. Sep 30, 2010 at 1:15 AM
    MaTt98
    MaTt98 Well-Known Member
    Medford Or.
    96 4Runner SR5 V6
    Runner SR5, xeon headlights, 6inch kc spotlights, cb in ashtray mod, roof rack, 2.5 inch lift in front with dodge 1500 coils in the rear and skyjacker shocks
    mine was doing that last week it turned out to be the starter sillinoid i took it to a local shop and it cost me 35 bucks (sorry for the bad spelling)
