It had to happen sooner or later.... Paint Chip Damage on hood =/
Discussion in '3rd Gen. Tacomas (2016-2023)' started by vuTron, Nov 3, 2015.
  1. Nov 3, 2015 at 10:15 AM
    vuTron
    vuTron [OP] Well-Known Member
    SF Bay Area
    2016 Quicksand TRD O/R DCSB AT
    So yeah it happened... small rock chip on my hood. It's deep enough to see metal. :mad:
    My greatest concern is rust, so I'm doing research now on how to repair. My preference is a DIY solution, but if needed, i'll go professional. Never did anything like this before.
    After the repair, I'm considering the 3M clear bra protectant.
    If anyone has any recommendations or suggestion, I'm all ears...
  2. Nov 3, 2015 at 10:51 AM
    TacomaN8
    TacomaN8 Well-Known Member
    Nate
    tbd
    it's going to be along ownership if you sweat every single paint chip. I'd suggest, tape it off, a good ipa wipe down, get some touch up primer and paint color and clear and be done. once it dries. hit the area with a couple coats of wax and call it good. it's a truck... not an investment.
    TeamSarcasm, TacoBella and bobrown14 like this.
  3. Nov 3, 2015 at 10:56 AM
    kbiz3000
    kbiz3000 Active Member
    once you've had any chips you can't really add the clear bra as it'll bubble where any chips were... unless you filled it completely and wet sanded it perfectly...
    vuTron[OP] likes this.
  4. Nov 3, 2015 at 11:00 AM
    mountainwolfpup
    mountainwolfpup Ford Guy (Formerly known as a Toyota Guy)
    Vancouver, WA
    2015 Ford F150 Lariat FX4 3.5l Eco
    First month of ownership... This month I'm removing front air dam, and also Rhino lining the bed.
    Use a touch-up paint pen. Takes 2 minutes, no prep needed. I do this annually every fall to about 12-15 spots where my paint has chipped off. Holds up pretty well, but will need to reapply every 1-3 years as it wears off faster then the factory paint. Looks great though, can't even tell.
    I put a front hood "bug deflector" on mine. Easy DIY install. Your hood already has screw holes for them. They are just a strip of hard plastic bolted to your hood edge. They seem to do a great job deflecting rocks from hitting my hood.
    Now those rocks cause chips in my front window glass and long streaking scratches into the paint on my cab roof.
    Of course, if I didn't drive so close behind people I'd probably have less issues with these airborne rocks I guess.
  5. Nov 3, 2015 at 3:14 PM
    redbull9944
    redbull9944 Well-Known Member
    Southwestern PA
    ‘24 LC250 First Edition, ‘25 TRDOR 6MT, 2016 DCSBTRDOR Inferno 6MT, 2004 Double Cab 4WD Project
    Prinsu Rack, 275/70R17 Cooper ST MAXXs, TRD PRO 4Runner Wheels, 5100s
    If you want it to look near perfect again I'd take it to a reputable detailer. They should know how to tackle it. It really depends on how good you want it to look...
    If you want to do it yourself you can get some touch up paint and a toothpick and dab a tiny droplet to fill in the hole. That should protect it but the paint won't be exactly smooth again where you applied touchup. If you want it to be smooth, get some really fine grit sandpaper, a hole puncher, and a pencil with an eraser. Punch a hole out of the sandpaper with the hole punch, glue it to the pencil eraser, and after you apply the touchup, wetsand it down to the level of the factory paint. Then polish and wax to make it blend in.
    Here's a video of the process:
    https://www.youtube.com/watch?v=6xi3xmeO6C4
    TOMRR and vuTron[OP] like this.
  6. Nov 3, 2015 at 3:21 PM
    TacoBella
    TacoBella Well-Known Member
    Tom
    2016 Tacoma (SOLD) leased RTL-E Ridgeline
    AVS Bug Deflector. TruXedo Lo Pro
    Who is making Bug Deflectors for the Tacoma?
    I suggest the OP learn how to use the Dr Colorchip touch up system. We will all get chips if we drive the truck. Its not a show car.
    But learning how to properly repair chips is a good thing to know and so to decrease the anxiety of the probable
  7. Nov 3, 2015 at 4:39 PM
    Herniator
    Herniator Well-Known Member
    Edmonton
    2016 Toyota Tacoma TRD Sport
    chrome valve stems covers
    If you can get the Proform rather then the 3M. Better quality.
  8. Nov 3, 2015 at 5:22 PM
    Suxdsmdmr
    Suxdsmdmr Well-Known Member
    Iowa
    2016 Tacoma Limited DCSB 4x4 Super White
    Yeah, if anyone has put a bug deflector on the 2016, would like to see pictures. Checked Weathertech, but not showing any for the 2016 yet. Was considering one, but wasn't sure of how it would look on the new front. Used to put these on all of our trucks, but didn't on the last one and didn't have any issues. It was black though, this one is white. Have a white car and the chips seem to show up worse on it.
  9. Nov 3, 2015 at 5:30 PM
    LtTaco
    LtTaco Well-Known Member
    Tennessee
    2016 SuperWhite Limited 4X4
    I've not seen a deflector for a '16 yet.
  10. Nov 3, 2015 at 7:48 PM
    mountainwolfpup
    Vancouver, WA
  11. Nov 3, 2015 at 10:37 PM
    WSPtaco
    WSPtaco Well-Known Member
    Nick
    Vancouver, WA
    Magnetic Gray 2016 Tacoma TRD OR
    I had the clear bra installed at delivery. You can barely tell it is there. We had one installed on the wife's SUV, and not a single rock chip in over two years.
    vuTron[OP] and JHFMX like this.
  12. Nov 3, 2015 at 10:45 PM
    Corjc
    Corjc Well-Known Member
    Denver
    2016 TRD Sport
    N/a
    I live in Denver and you have to have a clear bra on your truck here. On my 14 Tacoma I had a huge paint chip that went right to the metal. My grandpa owns an auto body shop so we matched the paint and touched up the chip and then buffed the chip. After that the clear bra came on. Couldn't tell I had such a bad chip after that
    vuTron[QUOTED][OP] likes this.
  13. Nov 3, 2015 at 11:56 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    Thread cleaned up OP
    vuTron[OP], PNW-Taco and NMTrailRider like this.
  14. Nov 4, 2015 at 12:02 AM
    Texas T
    Texas T Well-Known Member
    TX
    '14 T Force
    Op hasn't been in since op.
  15. Nov 4, 2015 at 12:07 AM
    JimBeam
    JB
    2015 Tundra
    That doesn't make what ya'll posted ok
  16. Nov 4, 2015 at 12:09 AM
    Texas T
    TX
    '14 T Force
    Ok, didn't think any rules were broken but you go ahead on law man.
  17. Nov 4, 2015 at 12:26 AM
    Gingerbeard Man
    Gingerbeard Man Well-Known Member
    Jared
    North Dallas
    2016 MGM DCSB Sport 4x4
    Icon stage 3 tubular 285/70/17 Toyo ATII
    In all seriousness 90% of the threads end up like this. Hell, some started just for trolling purposes. Didn't know it was a no-no?
  18. Nov 4, 2015 at 12:30 AM
    JimBeam
    JB
    2015 Tundra
    I think it's pretty clear he's asking for legitimate answers...and ya'll took it WAY too far
  19. Nov 4, 2015 at 12:34 AM
    Gingerbeard Man
    Jared
    North Dallas
  20. Nov 4, 2015 at 12:34 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    http://www.langka.com/
    Now that you've got that over with.......relax. The rest will be easier to swallow!
