it is bad if I put oil 10w 30 in my 2009 toyota Tacoma
Discussion in '4 Cylinder' started by elfuerte, Mar 31, 2009.
  1. Mar 31, 2009 at 8:03 AM
    elfuerte
    elfuerte [OP] Member
    09 PreRunner SR5
    K&N Magnaflow Jet Mass Air Flow Sensor
    you recommend the royal purple
  2. Mar 31, 2009 at 11:16 AM
    JDCPA
    JDCPA Well-Known Member
    Jim
    SW FL
    09 5 Lug Access Cab SR5
    Curt Hitch and etrailer.com wiring harness.
    It will depend to a large extent on where you are located and how cold it gets where you are. The 0w-20 rating is designed to cover the entire spectrum of locations from north to south. In the north where it is quite cold I wouldn't do it. In the south where it never gets very cold you are probably OK.
    I put 5W-20 in mine.
  3. Mar 31, 2009 at 11:35 AM
    Toyota Truck
    Toyota Truck Well-Known Member
    JT
    Texas
    2008 Prerunnner
    Magnaflow Muffler-TSB springs-Nuvi 265wt-aFe pro dry s filter-Husky Liners-Blue dome light-extra d-rings-OME 90000 sport struts-885 coils-N182 shocks-TSB AAL-LR UCAs-procomp black alloy rims- nitto terra grapplers-20% tint
    No I don't think so, but it will make engine work harder cuz its a thicker oil resulting in lower MPG. royal purple is a great oil and just a fyi they make a filter now too. Just curious why do you want to run a thicker oil.
  4. Mar 31, 2009 at 2:06 PM
    elfuerte
    09 PreRunner SR5
    I want to put an thicker oil because where I am is very hot , I say that an thicker oil help me very much
  5. Mar 31, 2009 at 2:21 PM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    I wouls still run 5W-20 or 0W-20. Either way the engine is going to be hot at operating temperature. If you leave it in for change interval it wont hurt anything
  6. Mar 31, 2009 at 2:25 PM
    A_Ninja_Racer
    A_Ninja_Racer Well-Known Member
    Tampa, FL
    08 PreRunner TRD Debadged
    Yeah I would say if your rocking it out in Florida, texas, oklahoma, new mexico, and arizona, area's you are pretty safe using the 10w30. I actuall alternate for the seasons.
  7. Mar 31, 2009 at 2:52 PM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    In my 2.7 I run 5w20 all year. Our summers in Northern Nevada get over 100 and in the winter it gets below freezing. I have no problems. 10w30 might be a little thick for an engine that requires 0w20. I wouldn't take the chance if I were you. JMO.
  8. Mar 31, 2009 at 8:42 PM
    neslerrah
    neslerrah Taco lovin'
    Harrelsen
    Tucson
    5 lug BEAST!
    Secondary air filter removed, elbow mod, BFG T/A KO (31x10.5R15), 15" American Racing Mojaves, BHLM, Dome Light MOD (Blue), Pioneer headunit, Sockmonkey 'TACOMA' Decals, Readylift 5-lug SST, Rear Shocks - Bilstein TRD, Dynomax Super Turbo #17748, DDM Slim Ballast HID Kit H4 Hi/Lo -35W 6000K in headlights, Apexcone Raptor HID Kit H3 - 35W 6000K in Hella 500s, aFe CAI #51-10762, WeatherTech Floorliner, 200W Smart AC Inverter
    I have been using the recommend oil weight, 5W-30. I run Mobil 1 in my Tacoma. It makes my Taco happy.:mudding:
  9. Apr 1, 2009 at 9:36 PM
    wawireguy
    wawireguy Well-Known Member
    Ambient temp only affects the starting viscosit of the oil. That engine runs a lot hotter than wherever you hail from. Just use the 5w20 like Toyota wants you to.
  10. Apr 2, 2009 at 1:50 PM
    Bakemono
    Bakemono Wrath of the runbird
    Southern Wisconsin, USA
    '09 Toyota Tacoma regular cab 4x2
    You will get more wear at startup (because it takes a thicker oil longer to flow up to the valvetrain), harder starting in cold temps (which may or may not be an issue depending upon how cold it gets where you live) and lower fuel economy (thicker oil makes the engine have to work harder to pump the oil around, so its less efficient).
    While you COULD use 10w-30, I really dont see why you would want to. Id suggest using 5w-20, as Toyota suggests.
    Unless you are always driving in extreme heat and under heavy load, their is no reason why you need to be using a thicker oil.
  11. Apr 2, 2009 at 5:03 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Being as the VVT-i is opperated via oil pressure, use the recomended oil wieght.
  12. Apr 2, 2009 at 6:43 PM
    Bakemono
    Good point. However, it wasnt all that long ago that Toyota recommended using 5w-30 in these engines, so Im not convinced that oil viscosity has all that much of an impact on VVT-i operation.
    Look at how much the viscosity of dino oil and synthetic oil changes with temperature.
    If the thickness of the oil were such a huge factor, it would effect how the VVT-i system works in different temperature extremes.
    I do agree with you to a certain point (and that you should stick with the oil that Toyota recommends), Im just not convinced that it effects the operaton of the VVT-i system...
  13. Apr 2, 2009 at 6:45 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    5w-30 was the recomended oil for the NON VVT-i 2.7. Granted, it may not have adverse affects on the VVT-i system, but why take the chance?
  14. Apr 2, 2009 at 6:47 PM
    Bakemono
    True and like I said, unless you are operating in extreme heat (120*+) or under heavy load all the time, there is really no reason to run a thicker oil.
  15. Apr 3, 2009 at 9:40 AM
    wawireguy
    Even if you are running in over 120 degree heat you still don't need to go to a heavier oil. How hot do you think you're engine is running? Lot hotter than that. 20 weight oil is 20 at running temp. 30 is 30 at running temp. Engine is designed for 20.
  16. Apr 3, 2009 at 9:44 AM
    bobwilson1977
    bobwilson1977 Well-Known Member
    KaliFORN-I-A
    96 Tacoma 2WD ( pizza delivery model)
    none except for crappy hub caps and floor mats.
    Won't hurt it at all. I've run nothing but 10-30 in everything for years, and two of my vehicles have over 200,000 miles. That's in all climates and temps.
  17. Apr 3, 2009 at 5:26 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You have an 96. He has an 09. On the second gens, the VVT-i is opperated via oil pressure. Everything I have read dictats that the 5w-20 or 0w-20 is required for the system to run as designed. On your 96, yes 10w-30 will be no issue.
  18. Apr 5, 2009 at 3:18 AM
    The Shape
    The Shape Well-Known Member
    Forrest City, AR
    '09 Access Cab A/T 4banger
    Back when I was an officer at the local PD the city shop ran 10W-30 on evrything with a gasoline engine and even though the 4.6 crown vics call for 5w20 we never had any oiling problems that I know of. That being said I run 5W20 in my Tacom because that is what it says to use on the oil cap.
  19. Apr 6, 2009 at 8:15 AM
    bryanc
    bryanc Well-Known Member
    ottawa ontario canada
    09 access 4cyl 2wd
    home made diamond tonneau with flip up and canoe racks
    :)wawireguy has it right and clear as far as I'm concerned. You also avoid warranty issues should problems arise. There was an excellent posting here at Tacoma world on oils in the past that should also be consulted if your not sure. bryanc
  20. Apr 8, 2009 at 11:48 AM
    Alvaro Guerrero
    Alvaro Guerrero Member
    thanks guys
