It won't get stolen--I can't remove my Tailgate?
Discussion in '1st Gen. Tacomas (1995-2004)' started by mkowitz, Aug 24, 2015.
  1. Aug 24, 2015 at 7:23 PM
    mkowitz
    mkowitz [OP] Member
    2004 Silver Tacom TRD
    It has the typical rust from rubbing on the plastic bumper cover. I would like to repair it. What is the best process for removing it to clean it up? I was able to loosen the right hinge bolt (but it won't slide out). Left one, broke the head off :mad:, but still acting as a pin to hold the hinge. Any guidance will be much appreciated.
  2. Aug 24, 2015 at 7:31 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Welcome to TW! Someone should pop in with some help in a little bit.
  3. Aug 24, 2015 at 11:34 PM
    552Jrider
    552Jrider Well-Known Member
    Jeremy
    Norcal
    2002 DC 4x4
    Can you remove the hinge to get the tailgate outta the way then remove the hinge?
  4. Aug 25, 2015 at 6:11 PM
    mkowitz
    mkowitz [OP] Member
    Started going there . . . but those torx screws are really in there, and I'm concerned about more breakage--this time the torx bit in the screw head!
  5. Aug 25, 2015 at 6:12 PM
    Bennett707
    Bennett707 Station707
    Oregon
    No more taco life for me
    Use some penetrating oil
  6. Aug 26, 2015 at 6:14 PM
    552Jrider
    Jeremy
    Norcal
    2002 DC 4x4
    x2 If ur dealing with rust. Ive read a mixture of ATF and paint thinner is the best penetrating oil.
  7. Aug 28, 2015 at 6:59 PM
    mkowitz
    mkowitz [OP] Member
    It looks like the screw heads are painted in tightly!
  8. Aug 29, 2015 at 5:18 AM
    deckeda
    deckeda Well-Known Member
    '04 Double Cab PreRunner SR5
    Use an impact socket for the torx head, and either a strong air wrench or breaker bar for leverage. The fact that the bolts are painted means they should be protected from corrosion and thus not need penetration by oil.
    There's also another tool, can't remember the name but you put it over a socket and hit it with a hammer instead of turning the socket.
    Or just take it to a body shop and they'll do one of the above.
  9. Aug 29, 2015 at 9:53 AM
    Indy
    Indy Master of all I survey.
    Impact screwdriver?
    Id try an impact wrenchif possible. Lots of little hits usually works.
  10. Aug 29, 2015 at 5:30 PM
    mkowitz
    mkowitz [OP] Member
    I'm gonna try air-impact, if they make a 3/8" torx T40 bit. Thanks, everyone, for the advice so far.
    BTW: My current bicycle's bed doesn't carry much!
    ElScorcho likes this.
  11. Sep 2, 2015 at 7:51 PM
    mkowitz
    mkowitz [OP] Member
    So the screws are in so tight, the bit rounded the screw heads. I pushed it in as tight as I could. Anyone ever drill em out and replace 'em (this is getting way too involved for what it's worth).
  12. Sep 3, 2015 at 11:43 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    3/8" torx driver =
  13. Sep 3, 2015 at 11:55 AM
    HAVVOKK
    HAVVOKK Well-Known Member
    2014 DGAF Long Bed
    Fucking look it up
    :sawzall::itllbuffout:
  14. Sep 3, 2015 at 11:56 AM
    Nirvana
    Nirvana Tesla Auto
    Kris
    Morgan Hill, U.S.A
    2006 Off Road 4X4
    Icon ext. travel 2.5RR in front, Icon ext. travel 2.0RR in rear, BuiltRight uniball UCAs, Wheelers Superbumps, Goodridge steel braided brake lines, BruteForce front plate bumper w/ Warn M9000+synth line, American Auto Horns ACDF, Pelfrey Bussman mount+Sandman bussman fuse block (soon), 255/75R16s on painted stockers...because I'm not paying $800 to rock rash new wheels you scrubs. Shok Industries 2/0 big 4 upgrade and sound deadener.
    This. Let the tool do the work, amazing what a good smack or two will loosen up.
  15. Sep 3, 2015 at 2:47 PM
    mkowitz
    mkowitz [OP] Member
    Actually, used the driver first, and it wouldn't budge (and appeared to be messing the head), so I went to the air driver. Maybe it just ain't meant to be?
  16. Sep 3, 2015 at 2:50 PM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    Do you have any pics of what you're doing?
  17. Sep 3, 2015 at 2:52 PM
    mkowitz
    mkowitz [OP] Member
    I will (why didn't I think of that?)
  18. Oct 27, 2015 at 6:50 PM
    mkowitz
    mkowitz [OP] Member
    OK. Sorry this took so long. I was finally successful! I used my sawzall to cut the bolt on the left--between the tailgate hinge and the truck. That left a rusted stud and the bushing for the tailgate to ride on. Using PB Blaster and heat and a vise-grip, was able to get the stud out. Cut the bushing into pieces to remove it. Bought new bolts and bushings from the dealer, painted the gate, and put it back on. However the plastic covers on the bumper still rub--I can't get the bumper mounting bolts loose. Have an appointment with a body shop to loosen them and push the bumper forward, maybe lower it also (there's a hitch that may prevent lowering).
    Needless to say, the hinge bolts are now gooped up with Never-Seeze, but hopefully won't have to do this again!
    Thanks for everyone's suggestions. And again, sorry for the delay for this post.
  19. Oct 28, 2015 at 11:39 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    those bumper covers are held in by clips and screws. clips may be broken, they are attached to the plastic piece so can't replace
  20. Oct 28, 2015 at 5:58 PM
    mkowitz
    mkowitz [OP] Member
    Yes, I'm aware. The right side is missing most (I used construction adhesive to hold it down. The left side is better, I spread the plastic clips by cramming foam between the sides, to hold them spread. Screws? Not aware of any . . .
