its a sad evening for my tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by quackhead03, Sep 20, 2010.
  1. Sep 20, 2010 at 7:05 PM
    quackhead03
    quackhead03 [OP] Active Member
    cody
    03 ex. cab
    K&N filter flowmaster exaust w/ chrome tip
    so i was changin my oil earlier this afternoon, up underneath her when i saw some grease on my front left inside boot, i had a badd felling at this point, so i put my figers on it and figured out that it was busted. son of a buck. rekon i ought to listen to dads ole famous words, muddin does nothin but tear stuff up. but once i get if fixed ill be right bak out there hittin holes again.:mudding:
  2. Sep 20, 2010 at 7:13 PM
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    That's similar to an old saying my dad always said to me, "Anal sex makes your nut sack act like mud flaps."
  3. Sep 20, 2010 at 7:15 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    :eek:
  4. Sep 20, 2010 at 7:18 PM
    johnw
    johnw Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue 5.3l v8 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 37/12.5/17 mickey thompson baja atz Allpro hybrid bumper grill craft grill wicked flow muffler inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
    lol thats horrible
  5. Sep 20, 2010 at 7:23 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    cv's aint hard to change..Pretty cheap too
  6. Sep 20, 2010 at 7:25 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    Some damned good post in here!
  7. Sep 20, 2010 at 7:26 PM
    SACTOWN
    SACTOWN Well-Known Member
    Greg
    Said the wife, "that's just wrong on way too many levels!!"
  8. Sep 20, 2010 at 7:27 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    but what if you have small flaps or no flaps at all:confused:
  9. Sep 20, 2010 at 7:29 PM
    98_Mud_bug
    98_Mud_bug 98_mud_bug
    lucedale Ms.
    98 tacoma sr5/ 06 x-runner
    3 inch suspension lift, night shades corner and blinkers projector headlights with halos and 3 led's 18 inch kmc xd rockstar wheels,275/65/18 kelly safari tsr's, bush whacker fender flares 7 inch touch screen, 2 kenwood 12's, Magnaflow exaust single in dual out,
    you can get some from auto zone for about 60 or 70 bucks with a lifetime warranty.. if you tear a boot then pull them and take em back..
  10. Sep 20, 2010 at 7:34 PM
    rex99
    rex99 Well-Known Member
    TArdCOMAWORLD
    Proton Cruiser
    Rocket Boosters, Flux Capacitor, Escape Pod, Throttle Body Spacer, Homeroshi, ATRAC disable
    :D:D
  11. Sep 20, 2010 at 7:56 PM
    98_Mud_bug
    lucedale Ms.
  12. Sep 20, 2010 at 10:26 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Lol , :rofl::rofl::rofl: fuuuuuck man !!
    My Grandpappy used to say the same thing when I was a boy
