It's about time I do something to it.
Discussion in 'New Members' started by TheBruce, May 3, 2013.
  1. May 3, 2013 at 8:18 AM
    TheBruce
    TheBruce [OP] New Member
    Bruce
    Olympic Penninsula
    07 TRD
    K&N intake, MBRP exhaust
    Hey all! Bought my Tacoma a few years ago and haven't been overly impressed. After a trade show last weekend, the "mod bug," got me and I'm getting excited about it. My little brother and I recently took over a shop selling and installing aftermarket and bolt on performance stuff.
    It's hard to explain how great the products are when my truck is sitting right outside the window bone stock. Unfortunately, my truck will remain mostly a pavement princess but I do want the ability and the aftermarket look.
    Just installed a K&N cold air intake and waiting for a MBRP exhaust and a Prolift 3" lift to show up.
    I'm here hoping to collaborate with people who know and understand what they got going on with technical issues and keep up with some very creative ideas that I'm seeing out there!
    Cheers!
  2. May 3, 2013 at 12:03 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    You would have been better served by an AFE Pro Dry filter. K&N lets in too much sand and dust. Don't believe me? Run it for awhile and check after the filter. You will find dirt. Still don't believe me? Do a before and after test with your engine oil samples. Watch the silicates climb with the K&N.
    Spacer lifts are dangerous. They allow the strut to compress fully without hitting the bump stop. This will eventually cause the strut to fail. They also make for a very stiff ride due to short suspension travel.
    Sorry to burst your bubble. Stick with OME or better. Just keep in mind that you'll need upper control arms to get proper camber. You will also need to get the slip joint legnthened on the driveshaft, use a spacer on the carrier bearing, and probably clock the rear diff. Without doing this, you will wear out the outside of the tires, have driveshaft vibration problems, and shorten the life of your u-joints and bearings.
  3. May 3, 2013 at 12:32 PM
    skidooman
    skidooman I'm your huckleberry
    TJ
    Northern Nevada
    19 Taco
    Kings, JBA, BAMF, C4, Deaver, Prinsu, TJM, SnugTop, 5.29s
    What a way to welcome a new person to the board...:rolleyes:
    Welcome OP, we're not all as grumpy as this guy.
  4. May 3, 2013 at 12:33 PM
    Toyotacrawler
    Toyotacrawler She's got the jimmy legs
    Cusseta/Opelika AL
    2010 Tacoma DC TRD Sport
    5100's set to 1.75" Wheelers 3 leaf progressive AAL & 5100's for the rear Konig Countersteer Offroads K&N Drop in WeatherTech's Bed Mat Blacked out Badges Rear leaf TSB
    Welcome to TW Bruce!
  5. May 3, 2013 at 12:42 PM
    AlphaEcho2k5
    AlphaEcho2k5 Well-Known Member
    Adam
    Hurlburt Field, FL
    '02 4Runner
    Welcome, Bruce.
    The great thing about this site is just when you think you've run out of ways to separate yourself from your money someone drops a great idea on you.:D You've come to the right place, there are plenty Guys/Gals with tons of experience, advice and are willing to help.
  6. May 4, 2013 at 1:40 AM
    TheBruce
    Bruce
    Olympic Penninsula
    07 TRD
    Sky tower, I appreciate your input but am not phased terribly. AFE has a huge following right now and that's great, honestly, their products sell like hot cakes and I won't argue for a second that they've got a great system. My motorcycle and my quad both run...better that sat on K&N and I want to see what it does for the truck. Spacers are dangerous but the Prolift looks pretty legit for what it is and I'm all about supporting young companies as long as they back it up. Nothing negative about MBRP exhaust though?!? I'll be back in VA soon brother, let's drink a beer. I thank you for the input on the technical issues. Some of it is going to be trial and error.
    Everyone else, appreciate the welcomes and hope to BS about important stuff soon.
  7. May 4, 2013 at 2:59 AM
    Ballz
    Ballz Well-Known Member
    Bfe SF Bay
    2023 Ice Cap Taco TRD Pro
    Bruce welcome!
    K&N will work great on your bike and quad because they are carbureted. On a modern vehicle, not so well, you'll have to check and clean your MAF sensor often because it will leave a coat of oil on it and cause the engine to run lean. Go with the dry filter like someone else said, your engine will love you more.
  8. May 4, 2013 at 6:22 AM
    RLDTACO
    RLDTACO Well-Known Member
    Bob
    Houston Tx.
    2010 DCLB PreRunner SR5
    Debadged,Tailgate theft mod,Extra D-rings,OEM bed mat,TRD exhaust, 5100 Billys@ 4 corners set@ 0 with Eibach springs, rear TSB springs.N-Fab tube Steps. TRD FJ SE wheels and Michelin LTX A/T 2's
    Welcome!
  9. May 4, 2013 at 10:15 PM
    TheBruce
    Bruce
    Olympic Penninsula
    07 TRD
    Ballz - K&N did a huge research project. Better than a million dollars spent in an independent testing facility to find out about that. Results showed that it was the MAF that failed or more specifically, a seal in the MAF that caused the problems. I don't have the proper verbiage at the moment to fully describe the results and the conditions that lead to the conclusion. I party like a rock star and this time of night on a Friday or Saturday is not the time to get into a debate that requires facts and proof isn't beneficial to my point. I'm giving it a try. We'll see what happens. I'm not a people person and I can't sell a dang thing if I don't actually believe in it so I need the expirence. Interesting though that you made that point. My motorcycle is injected also and it is very sensitive to temperature and mixtures. Interesting point. I'll have to look into it further. Appreciate it.
