Its all fixed!!!
Discussion in 'Performance and Tuning' started by ETaco23, Aug 15, 2009.
  1. Aug 22, 2009 at 2:59 PM
    ETaco23
    ETaco23 [OP] Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    Well I dont think its leaking. But It still sounds like it is. :(
    I will check it again later, but If it is still leaking, I think Im ganna have to take it off again and put rtv on the Head side of the gasket. But I just dont understand why it would still be leaking? The new gasket is thicker. Inless the flange isnt flushing up to the head?
  2. Aug 22, 2009 at 3:05 PM
    ETaco23
    Evan
    PNW
    Well I dont think its leaking... But it still sounds like it is.:(
    I will check it again later, but I cant see why it would be leaking still, with a new thicker gasket. Maybe the flange isnt flushing up with the head? I just dont know... If it is leaking still I geuss im ganna have to put some rtv on the head side of the gasket.:(
  3. Aug 22, 2009 at 3:48 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Make sure you are not hearing the normal Ticking associated with the Tacoma engines. As long as you tightened everything up evenly, there should be no leaks..NONE. :confused:
  4. Aug 22, 2009 at 7:16 PM
    ETaco23
    Evan
    PNW
    I can hear the ticking. I know that sound.... But when I put my hand down by the header I can feel warm air coming out. Im pretty sure its the exhaust. Inless there's something else on the drivers side blowing warm air.
  5. Aug 22, 2009 at 7:22 PM
    ETaco23
    Evan
    PNW
    If the flange isnt contacting the head perfectly flush, could this cause a leak?
    I dont think its the problem, but maybe?
  6. Aug 22, 2009 at 7:47 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    :frusty: I wish I could see it in person....
  7. Aug 22, 2009 at 7:55 PM
    ETaco23
    Evan
    PNW
    I know! Maybe Im just parranoid and its really ok! :)
    i dont know....
    I might take it down to my exhaust shop and get there appinion.
  8. Aug 22, 2009 at 7:58 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    YES! Do that. What you are feeling MAY be from the engine fan...:pray:
  9. Aug 22, 2009 at 8:08 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    you put your hand by the exhaust, and feel warm air? Hmm wow, and I thought I was anal about stuff..HAHA
  10. Aug 22, 2009 at 8:12 PM
    ETaco23
    Evan
    PNW
    ^^ Warm air blowing out! which is more then likely the exhaust...
  11. Aug 22, 2009 at 8:13 PM
    ETaco23
    Evan
    PNW
    I hope so! I will take it down first thing monday.
  12. Aug 22, 2009 at 8:40 PM
    ETaco23
    Evan
    PNW
  13. Aug 22, 2009 at 8:56 PM
    matthew5olson
    matthew5olson Well-Known Member
    matthew
    pittsburgh, PA
    04 ext cab 3.4L 5spd 4x4 sr5
    K&N cold air intake, doug thorley headers, rear sensor simulator, flowmaster 40 series, magnecor plug wires, Royal Purple synthetic gear lube, airaid throttle body spacer, Hyperground system, flex-a-lite elec fan.
    it stinks your still having problems with this. I hate when things don't go as they should. Just something I have heard but never experienced, maybe chris could chime in. Make sure all of your studs are rust free ( and the nuts too) This can affect torque readings. Not sure if these gaskets are that touchy but its worth a try if you have the manifold off again. Hopefully its just you being paranoid. It seem when something is wrong and makes I noise I hhear it long after its fixed. Try and feel the warm air when your engine is completely cold so as not to confuse it with your fan. Perhaps (I'm not out by my truck to check if this is possible but) take off the belt that runs the fan. Your engine should be ok running cold like that in your driveway. You may not have power steering, brakes, alt, etc. but the truck will run and that way there will be less noise and air moving in the engine bay.
  14. Aug 22, 2009 at 9:14 PM
    ETaco23
    Evan
    PNW
    Yeah, Im sure its not the fan. I check it when its cold. and the air I feel is still warm.
    It really sucks! I hate this crap... I hope my exhaust shop can find something or a solution if it is a leak.
  15. Aug 23, 2009 at 8:21 PM
    #35
    ETaco23
    Evan
    PNW
    Hey I was wondering if you hear a raspy hissing sound Inside the cab coming from your headers when eccelerating? It almost sounds like an exhaust leak... Bc thats what I can hear from mine. And thats why I think I have a leak. thanks!
