It's f'n cold out --- weird sound coming from front end
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PoweredBySoy, Dec 13, 2016.
  1. Dec 13, 2016 at 3:23 PM
    PoweredBySoy
    PoweredBySoy [OP] Well-Known Member
    Jesse
    Minnesota
    2013 DCSB SR5
    I'm not sure if it's cold related, but it would seem like it.
    For the past couple days I've been getting this sound from the front end - both wheels. It's hard to explain, but it sounds like a cross between popcorn popping and someone twisting balloon animals. And it only seems to happen during turning. When I turn passenger, the sound comes from the passenger wheel. When I turn driver, it comes from driver. It happens with fairly hard turns at slow speed.
    For the most part that's when I hear it.... and it kind of comes and goes.
    It's loud enough to hear over the stereo.
    At first I thought it was snow/ice shooting up from the tire, but I'm pretty sure that isn't it. The sound doesn't really match.
    At one point I turned hard, heard the noise, then stopped to do a visual inspection. I'm not seeing any ice build-up or anything rubbing, and I never had this noise a week ago.
    Any thoughts??
  2. Dec 13, 2016 at 3:24 PM
    LunaticConcepts
    LunaticConcepts Well-Known Member
    Georgetown, TX
    2015 Tacoma TSS
    TC LT, Kings, OME, Billies, ARB, stuff
    CV boot stiff and rubbing?
  3. Dec 13, 2016 at 3:28 PM
    PoweredBySoy
    Jesse
    Minnesota
    2013 DCSB SR5
    Is that a thing? It definitely has a rubber quality to the sound.
  4. Dec 13, 2016 at 4:06 PM
    08tacobear
    08tacobear Well-Known Member
    08 taco DCSB pre runner V-6 SR5
    12v accessory plug right rear bed bin,1gallon air compressor setup in left rear bed bin, 3-window bed topper.
    Yup! It is definitely high probability of being cv boots if not the joint themselves. My wife's '15 Camry hybrid make the same noise on the passenger side. Irritating as heck,,,,but dealer says nothing rubbing.
  5. Dec 13, 2016 at 4:11 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Ice trapped behind the mud gaurds is a common noise maker
    Edit : just re-read your post that you didn't see any ice build up
    Nevermind , as you were , nothing to see here
  6. Dec 13, 2016 at 4:54 PM
    Pigpen
    Dan
    Northwest Montana
    Tires squeaking on snow :notsure:
    landphil likes this.
  7. Dec 13, 2016 at 5:27 PM
    PoweredBySoy
    Jesse
    Minnesota
    2013 DCSB SR5
    C'mon, give me a little credit.... :smack:
    CV boot sounds like a possible culprit. I just wonder if that means something is starting to go. I don't remember hearing this sound at all the past 2 winters.
    Pigpen[QUOTED] likes this.
  8. Dec 13, 2016 at 7:38 PM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    Never heard cv's make that kind of noise,
    but if you want to find out if it is, spray the boots with some silicone and see if it goes away.
  9. Dec 14, 2016 at 6:37 AM
    Woundedyak
    Woundedyak Well-Known Member
    Indy
    With 2nd Gens, who really knows? I have a 14 and every 10degrees it drops in temps I pick up a few new rattles,pops, and vibration. it's crazy for a new vehicle.
