Its not about the size, but how you use it...
Discussion in 'Suspension' started by StormTroopinTaco, May 19, 2011.
  1. May 19, 2011 at 10:56 AM
    StormTroopinTaco
    StormTroopinTaco [OP] Member
    Dan
    Pensacola, FL
    2016 Inferno Red TRD Sport DCSB
    Im fairly new to this forum and recently purchased my first Taco last fall and was needing some input and suggestions for a 3" lift. I have a 2011 Prerunner 2wd 4.0 and need to know what brand and what type of 3" lift will benefit my taco for a lil while until I go with a 6". I've never owned a truck before so I know very little to nothing about lifts.
  2. May 19, 2011 at 10:57 AM
    Unknown
    Unknown He who angers you conquers you
    Brian
    Los Angeles
    Unknown
    Unknown
    why would want to go 6"?
  3. May 19, 2011 at 11:00 AM
    Unknown
    Brian
    Los Angeles
    Unknown
    Unknown
    x2
  4. May 19, 2011 at 11:03 AM
    StormTroopinTaco
    Dan
    Pensacola, FL
    Ok scratch the 6 inch. I just want a 3" with 32s
  5. May 19, 2011 at 11:12 AM
    Underdog777
    Underdog777 Well-Known Member
    Gilberz
    '06 Stuckrunner
    Camburg LT.
    IMO you should invest in some adjustable nitrogen coil overs. Icon, King, Fox, Camburg, ect. You will also want to consider after market upper control arms from Camburg, total chaos, light racing, toytec, ect. For the rear an add a leaf set up, and nitrogen shocks as well. You get what you pay for as with anything, and you will want to take into consideration how much off reading you will be doing. Most go the 3" bilstien route and call it a day on a budget build. Hope this helps, good luck :)
  6. May 19, 2011 at 11:19 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    OP: You have a prerunner.
    The answer is spindles. End of thread.
  7. May 19, 2011 at 11:50 AM
    StormTroopinTaco
    Dan
    Pensacola, FL
    cool thanks!
  8. Jun 29, 2011 at 10:59 PM
    mwestin72
    mwestin72 Well-Known Member
    california
    07 preRunner Tacoma
    off-road wheels with beadlock 17in tire tube steps smoked taillights
    I was thinking fox racing or kings front and rear ...spindles not sure ....rear add a leaf? Tsb will not cover me no more :(
  9. Jun 29, 2011 at 11:02 PM
    rcfreak201
    rcfreak201 Well-Known Member
    total chaos or camburg spindles, OEM replacement kings set at lowest setting, rear, all pro 3 or 4 leaf pack, with king OEMs replacements, all pro u bolt flip kit, your set!
  10. Jun 29, 2011 at 11:05 PM
    kinkrider101
    kinkrider101 Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
    Spindles! End...lock thread
