It's not the Battery
Discussion in 'General Automotive' started by MunchTIME, Mar 16, 2021.
  1. Mar 16, 2021 at 6:26 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    Voltage across the battery terminals should be 12-13 when the car is off and 14-15 when it’s running. Cheap easy test.
    MunchTIME[OP] likes this.
  2. Mar 17, 2021 at 10:11 PM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    Yes and no. Technically the alternator is running the vehicle and charging the battery so in theory, it shouldn't affect anything unless the vehicle shuts off. That is, unless the alternator is also bad (not withstanding bad wiring or anything). Having a multimeter is kind of irrelevant in OP's case by the sounds of it since it only runs with the jump pack. I wouldn't doubt if one issue affected the other, though.
