It's okay to complain about your 3rd gen thread
Discussion in '3rd Gen. Tacomas (2016-2023)' started by KevinC, Jan 29, 2019.
Thread Status:
Not open for further replies.
  1. Jan 29, 2019 at 12:43 PM
    #121
    stun gun
    stun gun Well-Known Member
    Aaronski
    Tacomas.
    17 4X4 sr5spd/01 LT sr5spd
    You have the automatic?
    shakerhood and tcjacado like this.
  2. Jan 29, 2019 at 12:46 PM
    #122
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Sometimes when I read these threads, I cant decide if its a genuine problem, or if its someone who doesn't remember what vehicles used to be like.
    I used to drive a 78 Bronco - 3 speed automatic, 351 V8. I just looked it up, 156 hp when new, three fewer ponies than the four-banger taco with 2.5 times the displacement, five bajillion times the weight. (It was a steel mammoth, you needed to press the brake pedal yesterday to get it to stop.) It could do 65mph most days, but it damn sure wasn't happy about it. It could also climb hills all day long, as long as you were ok with being the last person to reach the top.
    The problem is that speed limits are higher than ever, we are going ever faster, and the environmental mandates demand that the engines be ever more efficient. 75mph is damn fast in terms of resistance. As in, the amount of power needed to go 75 is exponentially higher than what was needed at 55 mph. And the manufacturers need to find a way to do it without spewing a thick blue haze out of the tailpipe to boot. That's some engineering voodoo to pull that off.
    At 75 you'd be surprised how much a gentle breeze can penalize the truck. A 5 mph intermittent headwind can cause the truck to kick down a gear to keep speed. (It's like instantly accelerating to 80 mph, again exponentially increasing power to maintain.) So can half-a-percent grade, almost too small to feel. The constant gear hunting is uncomfortable, yes, but some of us old farts are just happy that it can keep speed. My 2000 frontier couldn't even do that. Instead of downshifting, the speedo would slowly inch down to 70, then 65, then 60... all those people I just passed would get pissed and pass me on the uphill. Then I'd pass them right back on the down. I'll take gear hunting over road rage any day.
    You might be having a genuine issue, but then again its possible that it might be part of the design. If you can't sacrifice speed, and you can't sacrifice emissions, something in the equation has to give. That something is low-end torque. If you want comfort, drive it like it was a truck of the older generations - allow it to slow down when the weather or hills pop up.
    JNG, IRISHFAN, tcjacado and 4 others like this.
  3. Jan 29, 2019 at 12:48 PM
    #123
    Paul631
    Paul631 Well-Known Member
    2016 4x4 5-spd Utility Package
    Bilstein 6112/5160 Grabber X3's
    Maybe take off the lift and/or 33" tires?...
    JNG likes this.
  4. Jan 29, 2019 at 1:03 PM
    #124
    JayRolla
    JayRolla Well-Known Member
    Colorado Springs
    Wife's 2012 DCSB Tacoma Sr5
    Trd stickers for 10whp 32s on MK6 17s
    I had an 1986 bronco with 351w. Even with the low hp rating that v8 put out 250tq at 2000rpms making it feel like it had more power than my wifes 2nd gen. Low end tq is key.
    JNG and shakerhood like this.
  5. Jan 29, 2019 at 1:08 PM
    #125
    BBPSR54X4
    BBPSR54X4 Well-Known Member
    2017 SR5 DCSB 4x4
    Not normal. Just take it to the dealership and take a service advisor for a ride. If your truck is continuously banging back and forth through the gears at 66mph something is wrong.
    JNG, WarrenG, StayinStock and 3 others like this.
  6. Jan 29, 2019 at 1:38 PM
    #126
    KevinC
    KevinC [OP] Well-Known Member
    Kevin
    2017 SR5 Quicksand Tacoma
    Finally somebody sane who isn't a total condescending dick fanboy. Thank you for existing.
    I did take it back to the dealership, had them run every test possible, look for any freshly released ECU, and finally after dealing with front house people I spoke to the tech manager who himself told me and I quote, "I'm not really supposed to tell you this, but the newer tacomas are underpowered, and that's why they're behaving this way. The 4.0's had the right amount of torque but Toyota wanted their trucks to get better gas mileage and this is the result. Only advice I can give you is to call corporate and file a complaint"
    I'm actually mad at myself for not bringing this up earlier.
    Yes these tucks are underpowered.
    Yes the tech manager at Toyota knows more than all of you.
    brny67 likes this.
  7. Jan 29, 2019 at 1:40 PM
    #127
    StayinStock
    Bob
    Missouri
    Yes I do
    Some
    JNG, melikeymy beer and boynoyce like this.
  8. Jan 29, 2019 at 1:45 PM
    #128
    JCOOR
    JCOOR Well-Known Member
    TRD Burglar
    Calling someone a condescending dick fanboy makes you a condescending dick
    JNG, tcjacado and Rock Lobster like this.
  9. Jan 29, 2019 at 1:48 PM
    #129
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    That's because he said what you wanted to, no, NEEDED to hear so you could justify your total lack of how things work into fact.
    I took time out of my day to patiently explain simple physics to you. My explanation was correct. You apparently do not want to hear fact, you would rather hear fiction as long as it jibes with that fantasy going on inside your head.
    Good luck bro. Test drive next time.
  10. Jan 29, 2019 at 2:02 PM
    #130
    KevinC
    Kevin
    First you said
    Then I said
    Then you said
    Are you fucking dizzy? The tech manager basically echoed your first comment, and now you wanna speculate what went on in his mind.
  11. Jan 29, 2019 at 2:04 PM
    #131
    KevinC
    Kevin
    So....whatcha wearin?
    brny67 likes this.
  12. Jan 29, 2019 at 2:04 PM
    #132
    Nunya Bizness
    I have had my issues with my 3rd gen... but It actually got fixed finally... after 5500 miles of frustration...
    Better late than never eh
    brny67 and tcjacado like this.
  13. Jan 29, 2019 at 2:06 PM
    #133
    KevinC
    Kevin
    How? ECU flash? 3.5 or 2.7?
  14. Jan 29, 2019 at 2:07 PM
    #134
    tcjacado
    tcjacado Well-Known Member
    Apparently a dick and a fan:confused:
    hiPSI, JayRolla and Nunya Bizness like this.
  15. Jan 29, 2019 at 2:09 PM
    #135
    KevinC
    Kevin
    You doing the helicockter again?
  16. Jan 29, 2019 at 2:10 PM
    #136
    Rock Lobster
    Dee Eff Dub
    I drive a Miata.
  17. Jan 29, 2019 at 2:11 PM
    #137
    tcjacado
    More like a weed whacker :anonymous:
  18. Jan 29, 2019 at 2:19 PM
    #138
    KevinC
    Kevin
    Affirmative.
  19. Jan 29, 2019 at 2:23 PM
    #139
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
  20. Jan 29, 2019 at 2:52 PM
    #140
    woodshampoo
    woodshampoo Well-Known Member
    VA
    2018 DC OR 4x4
    Cant say I am enjoying my first 20k.
    Hood replaced (ongoing issue)
    Pass Front Bearing \ Hub replaced
    Radio Replaced
    ECU reprogram
    Blindspot Sensor
    And I feel like it stumbles on cruising throttle
Thread Status:
