Itunes/ipod HELP!
Discussion in 'Technology' started by gorilla33, Dec 22, 2009.
  1. Dec 22, 2009 at 7:07 AM
    gorilla33
    gorilla33 [OP] Stock Radiant Red
    East Tennessee
    05 trd sport
    So I had to reformat my computer and lost everything. Last night I downloaded iTunes, and obviously it did not have any of my old music that are currently on my iPod. I do not want to lose the music that is on my iPod, however I do not care if it is on my computer in iTunes. The problem is when I download new music and put it in iTunes and then sync my iPod, the new stuff does not transfer to the iPod. Any ideas??
  2. Dec 22, 2009 at 7:09 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Use SharePod to get the music from the Ipod to the Computer...
  3. Dec 22, 2009 at 7:14 AM
    McJosh
    McJosh avidoffroad.com
    Josh
    Chandler
    2005 Reg. Cab 5 lug Tacoma
    Pioneer AVH-p2300DVD, 12" Memphis sub and Alpine MRP-M650 amp, 32" BFG AT tires and KMC wheels, tinted windows, satoshi grille w/ stainless steel mesh, Avid front & rear tube bumpers, Cobra wx75 CB with 3' firestik, GaragePro bucket seats, FlowMaster 40 series, aFe CAI, Black head lights, LoJack and Autopage alarm installed, Avid sliders.
    So you want to add music without erasing your old music off your iPod? Just click on manually manage music on the "summary screen" once your iPod is connected. Hopefully this helps. :)
  4. Dec 22, 2009 at 7:17 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    both of the above answers are correct. In order to get your music off of your ipod back onto your computer you will need some sort of software to get if off (there are many freeware programs available) and make sure you "manually manage music" so it doesn't erase everything like the guy above said.
    Itunes will not allow you to transfer from ipod to computer...only from computer to ipod. I suppose this helps prevent piracy to an extent.
  5. Dec 22, 2009 at 8:44 AM
    gorilla33
    East Tennessee
    05 trd sport
    Yeah from what I've read many people lose everything off of there iPod when they get a new computer because they don't take the time to read when it tells you that it will erase your iPod...luckily I avoided that! So if just manually manage music I can get my new stuff on there and keep the old as well, its just that the old will not be in my iTunes library...is that correct?
  6. Dec 22, 2009 at 8:47 AM
    hendooman
    hendooman The Stroker Ace
    Jeff
    KC
    2009 Tacoma OR (SOLD); 2015 TRD PRO 4Runner
    No that is not true. Don't download any new music yet. Use one of the freeware programs and get your ipod music back to the computer first. Then download your new tunes, and hit manage files manually from there on out. You need to get the music off you ipod to the computer first.
  7. Dec 22, 2009 at 8:55 AM
    gorilla33
    East Tennessee
    05 trd sport
    Do you suggest any freeware...i tried a few things but they were just trials and would only allow like 10 songs.
  8. Dec 22, 2009 at 8:58 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    SharePod should allow you to get all of it back for free.
  9. Dec 22, 2009 at 8:59 AM
    hendooman
    Jeff
    KC
    I have never had to use one, but I would trust Chris's recommendation...
  10. Dec 22, 2009 at 8:59 AM
    mrp192
    mrp192 REALLY!!
    Brent
    Cheney WA
    98 V6 4x4 limited
    Stereo, boobies
    idump is free and pretty good!!
  11. Dec 22, 2009 at 9:01 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    :) thanks. I have used it on my Wifes Ipod, and my Own, and it was painless. It gets all the songs onto the computer from the Ipod, and allows you to then, transfer them all to Itunes, and back to the Ipod along with anything else.
  12. Dec 22, 2009 at 9:29 AM
    McJosh
    Josh
    Chandler
    good luck Gorilla33 :)
  13. Dec 22, 2009 at 9:29 AM
    gorilla33
    East Tennessee
    05 trd sport
    awesome! will try this evening, thanks!
  14. Dec 22, 2009 at 9:32 AM
    elliott.estes
    elliott.estes Well-Known Member
    sacramento
    07 Black DC TRD Sport
    In Dash Avic-D3 / Blacked out headlights / Satoshi Grille / OME 90000 Front Shocks/ OME n182 Rear Shocks / OME 885 Coils / AAL with TSB's / 10MM lift Enhancer Kit / Light Racing UCA's / BFG AT KO's (285x70x17's) / Procomp 7089 Rims
    mac or pc?
  15. Dec 22, 2009 at 9:53 AM
    gorilla33
    East Tennessee
    05 trd sport
  16. Dec 22, 2009 at 10:03 AM
    warpwr
    warpwr Junior Senior Member
    Vaughn
    S.F. Bay Area
    09 Sport Access Cab
    DRL mod with switch, rear spring TSB, trans TSB, tailgate mod, snug-top shell.
    I snagged this from some forum somewhere and I have not tried it...yet..
    but it sounded good.
    if you have windows, connect your ipod to your pc. when itunes opens it will ask if you want erase and sync your ipod to your new library.. select no. go the ipod tab and select manually manage music on your ipod. after that close itunes.
    now open my computer. if you have windows vista at the top of the my computer window is a tab that says organize. select oraganize then select folder and search options. now at the top there will be three tabs-general,view and search. select the view tab.
    look for the option "hidden files and folders" and select "show hidden files and folders". now close that out only leaving my computer window open.
    now your ipod will show up as a disk drive. explorer your ipod, you'll find a transparent folder called "ipod control", open that ipod control and then open music. the music folder is all your files from your library however they are organized in apples structure which is useless to you. (F00,F01,F02).
    copy and paste all of the F(#) folders to your music folder on your pc. after its finished your new folders will still be transparent. select all of the fnumber folders and right click then select properties. there will be box marked hidden. unselect hidden but select read only. after that is done reopen itunes.
    now edit the itunes preferences to allow itunes to manage your music. after that just add the music folder by going to File-Add folder to library- and then point to your music folder. with itunes allowed to manage your music it will reorganize to artist and albums folders. after that you can go back and turn that off. enjoy.
    Good luck, I copied this tip so I could have my itunes on more than one computer but like I said, I haven't tried it yet.
  17. Dec 22, 2009 at 10:43 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Don't forget to backup your music!
    Depending on how much music you have - for larger amounts - you could buy an external hard drive pretty cheap these days and simply hook it up from one computer to the other without any fear of loosing your stuff (theoretically anyway).
    Or, if you have smaller amount of music - get a USB flash drive as a backup to your original files.
  18. Dec 22, 2009 at 1:38 PM
    McJosh
    Josh
    Chandler
    x2
  19. Dec 23, 2009 at 5:59 AM
    gorilla33
    East Tennessee
    05 trd sport
    used sharepod, worked perfectly! Thanks to all!
  20. Dec 23, 2009 at 6:02 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Good to hear! :)
