I've got a scanner, now I need help diagnosing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by smeagle, Apr 7, 2022.
  1. Apr 16, 2022 at 4:08 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    No you don't need to drain the oil to do valve cover gaskets, if you are close to being due for an oil change do the gaskets and seals, run it a bit, then change it.
    smeagle[QUOTED][OP] likes this.
  2. Apr 16, 2022 at 4:11 PM
    mlcc
    mlcc Well-Known Member
    Oregon
    2002 DC TRD/ 1995 4runner
    Mid travel, armour all around
    Just be aware of when you remove the spark plug the oil will drain into the cylinder and when you start it up it might smoke a little.
    Dm93 likes this.
  3. Apr 16, 2022 at 4:49 PM
    smeagle
    smeagle [OP] Well-Known Member
    Justin
    Chicago, IL
    2006 2.7l 2TR-FE Tacoma
    Good to know.. ill do my best to soak up the oil before I pull the plugs.
  4. Apr 16, 2022 at 5:18 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    If you have access to an air compressor and blow gun you can spray some brake clean down the hole, stick the blow gun nozzle down, hold a rag over the top, and blow most of it out, that's how I clean them at the shop just wear safety glasses, brake clean burns if you get it in your eye;)
  5. Apr 16, 2022 at 5:44 PM
    smeagle
    Justin
    Chicago, IL
    Cool, thanks for this.. and just to confirm with you since I know you've been following along to all this nonsense. lol
    ..I'm replacing the inner and outer valve cover gasket, spark plugs, and coils right? Is there anything else I should look for while I'm in there?
  6. Apr 16, 2022 at 5:50 PM
    mlcc
    Oregon
    Cold beer
  7. Apr 16, 2022 at 5:51 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    If the coil boots are replaceable your coils may be fine but for sure replace the boots.
    You may want to glance at the timing chain and guides while your there, not a common failure point on Toyotas but it wouldn't hurt to give it a lookover.
