I've got an issue that is stumping most everyone.
Discussion in 'Technical Chat' started by Cooper2003Limited, Apr 6, 2017.
  1. Apr 6, 2017 at 11:17 AM
    Cooper2003Limited
    Cooper2003Limited [OP] Member
    Kyle
    Long Beach CA
    2003 3.4L Limited - 2wd
    I joined the forum in hopes that someone can give me some insight to the issue that my beloved Tacoma is having recently.
    Every time I make a left hand turn, with the blinker on (fast blink like the bulb needs to be changed), and with any amount of acceleration, the transmission will not upshift. This also happens when changing lanes to the left. As soon as I turn the blinker off, it shifts as normal.
    If I do not use a blinker at all, it shifts appropriately.
    I feel like it's an electrical or a computer issue because of the dependency of the blinker, but I don't really know enough to be sure.
    The guy at the shop where I was getting my smog test done said that was a new one for him and that with 187k miles on it, it probably wasn't worth looking into it because the chip was in the trans and they would have to break it down to get at it just to see what the problem is. I called a dealership to see if they have ever heard of this, they haven't, and it would cost $100 just to get it in the bay.
    Has anyone heard of such a situation?
  2. Apr 6, 2017 at 11:21 AM
    Bishop2Queens6
    Bishop2Queens6 Well-Known Member
    SoCal
    2009 DCSB SR5 4x4
    Icon 2.5 RR/w CDCV 700# springs Front Shocks JBA UCA's Wheeler's Offroad Superbump Front Bump Stops Icon 2.5 RR/w CDCV 4"+ Rear Shocks AllPro Expo Rear Leaf Pack Timbren Rear Bump Stops ARB Front Bumper @Shmellmopwho Rock Sliders w/ Kickout RCI Aluminum Front Skid Plate Prinsu Roof Rack Roll-N-Lock Tonneau Cover CBI Ditch Light Brackets Cali-Raised LED Ditch Lights Cali-Raised Amber Fogs Cali-Raised Flush Mount LED Pods
    Did you change your blinker blub, or any accessory bulbs to LED?
    If I remember correctly, some older vehicles need the resistance in incandescent bulbs to for the voltage to remain consistent in the circuitry. We had some issues with a Peterbuilt on my ranch when we changed the accessory and blinker bulbs to LED, and the issue was resolved when we switched back to incandescent.
    big_jarv and MadDaddy like this.
  3. Apr 6, 2017 at 11:24 AM
    Cooper2003Limited
    Kyle
    Long Beach CA
    Last time I changed them was in 2015 and didn't have this issue until about a month ago.
  4. Apr 6, 2017 at 11:29 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    I had a weird anomaly with one of my toyotas, When you turned the wipers on and headlights on the lights would decrease/flash/dim with movement of the wipers. Turn signals also affected the lights. Turned out to be a bad connection at the battery negative cable grounding. I cleaned off the ground and it worked great/no problems after that.
  5. Apr 6, 2017 at 11:34 AM
    Joe D
    Joe D .
    At the very least I'd see if a bulb fixed the turn signal (could be a relay??). That would eliminate that portion of what may be a larger fault. Gotta say it's an odd one to see tied together.
  6. Apr 6, 2017 at 11:36 AM
    Lord Humongous
    Lord Humongous The Ayatolah Of RockNRolla
    AZ
    Inferno 3rd gen trd offroad 4x4
    https://www.tacomaworld.com/threads/lord-humongous-gigahorse-build.436524/
    I have a buddy that had this Durango. It needed an exorcism more than a mechanic. His turn signals, radio, lights ect would come on randomly with or without the key in it. He also had to pull the starter relay to turn the engine off lol. It was the the TIPM causing all the problems.
    Good luck.
  7. Apr 6, 2017 at 11:36 AM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    did you change the LEDs in your shifter console as well? P_N_R_D
  8. Apr 6, 2017 at 11:39 AM
    nDub
    nDub Kan kun være malet af en gal mand
    Central Sierras - NorCal
    ‘17 TRD OR DCLB and a dǝǝſ
    Lead Free Gasoline
    Changed what to what?
    Like mentioned, I'd check all your grounds. And wiggle some wires.
    Joe D likes this.
  9. Apr 6, 2017 at 11:44 AM
    Clearwater Bill
    Billy
    Largo Florida
    Fix the 'fast blinker' issue first, and see what happens to the collateral nonsense that is going on.
    G.T. and ramonortiz55 like this.
  10. Apr 6, 2017 at 11:46 AM
    Cooper2003Limited
    Kyle
    Long Beach CA
    Ill try this first and report back.
    Joe D[QUOTED] likes this.
  11. Apr 6, 2017 at 11:48 AM
    Cooper2003Limited
    Kyle
    Long Beach CA
    I didn't mess with anything prior to this issue. When I changed the bulb I just replaced a spent one with a new one. (this is probably frustrating for folks that know what they are talking about)
    ramonortiz55[QUOTED] likes this.
  12. Apr 6, 2017 at 12:38 PM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Time to change your blinker fluid... Kidding
    Check body/frame grounds, Fix your fast blink like Bama said
  13. Apr 6, 2017 at 4:48 PM
    DVexile
    DVexile Exiled to the East
    Ken
    2015 DCSB V6 TRD OR 4X4
    As others have suggested weird behaviors like this are usually the result of a bad ground someplace. These can be a real pain to find. One that commonly corrodes or gets loose over time is attached to the frame just by the rear driver side wheel. That would be the return path for all the tail lights including the signal lights back there. If it is flaky that current will find some other path to get back to the battery and can freak out anything along the way.
    Like everyone else is saying fix the fast blinker issue. That is easier to diagnose because you can do it with the truck stopped while you poke around! Hopefully fixing the blinker will result in finding the electrical or grounding issue that is also freaking out the AT.
    Good luck!
  14. Apr 12, 2017 at 4:33 AM
    Clearwater Bill
    Billy
    Largo Florida
    And????????????
  15. Apr 12, 2017 at 5:36 AM
    Sandman614
    Tim
    '06 SR5 Off Road
  16. Apr 12, 2017 at 5:40 AM
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    Pull the bulb out of the fast blinking turn signal and see if it does it then. Just leave the bulb out completely
  17. Apr 12, 2017 at 8:26 AM
    Cooper2003Limited
    Kyle
    Long Beach CA
    Sorry folks. Got distracted with the Grand Prix in town this past weekend and then life.
    I pulled the bulb from the fast blinking light and replaced with a good one and it did not fix the fast blink or the shifting problem. It might have made it less drastic but that could have also been hope.
    Ill give updates as I get them. So far, sounds like an electrical issue -- hopefully something easy like a loose ground wire -- but either way, I'll have to so some serious learning to identify the problem. Any tips on where to learn more about the electrical system?
    TXpro4X4 likes this.
  18. Apr 12, 2017 at 8:40 AM
    MadDaddy
    MadDaddy Pork Rind Extraordinaire
    53 Miles West of Venus
    Many & varied
    Reminds me of my '82 Firebird. When I pressed the rear window wiper/washer button, the radio would switch to an AM static frequency. Then, as I accelerated, there was on overtone in the AM static frequency that raised in pitch as the engine RPMs increased. The whole cacauphony came through the stereo speakers.
  19. Apr 12, 2017 at 8:47 AM
    Glamisman
    Glamisman Well-Known Member
    there should be a ground from the firewall to the back of the engine block or intake manifold depending on motor. Another from the battery to the body, easy ones first.
    nDub likes this.
  20. Apr 12, 2017 at 9:00 AM
    nDub
    Lead Free Gasoline
    And clean your battery terminals.
