I've got an issue that is stumping most everyone.
Discussion in 'Technical Chat' started by Cooper2003Limited, Apr 6, 2017.
  1. Apr 12, 2017 at 9:05 AM
    Seabass
    Seabass Give it to me. I'll break it for you
    Adam
    AZ
    '06 Sport 4x4
    Just a bunch of old crap
    Look at your relay wiring diagram and see if there are relays and possibly fuses that put these two functions close to each other. Maybe a frayed wire is touching something just right so that when you energize that left turn signal circuit, it's arcing or shorting over to the wiring for the shift position sensor or something like that. Same could also be happening in a bundle of wires from the main harness where there are tons of wires bundled together. Wires age, connections are spliced, things happen.
  2. Apr 15, 2017 at 8:13 AM
    Glamisman
    Glamisman Well-Known Member
    I looked at the wiring diagram and an "off the wall" test would be to remove the 10 amp Guage fuse in the fuse/relay box by your left knee. This fuse powers up a quite a few circuits in the combination fuse relay. This combination fuse relay box has a pretty complicated internal circuitry, pluse it is a free simple test.
  3. May 10, 2017 at 6:34 PM
    Dragons Taco
    Dragons Taco Well-Known Member
    Derek
    Cary/Raleigh NC
    06 Black TRD-S 4WD 4D 6SPD and MINE!
    Can ya spell Tonneau
    OP Status?
  4. May 10, 2017 at 6:48 PM
    07regtacoman
    07regtacoman Well-Known Member
    Davis Ca
    07 Silver REG Cab
    Painted arm rests, 2011 front grille,Readylift for 5lug.
    Don't know but does Toyota use flashers that control the lights near the fuses.Had an old truck n had to replace from time to time.
  5. May 10, 2017 at 7:08 PM
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    These electrical problems can be a real pain to track down but there have been lots of good suggestions so far. Start at the battery, clean terminals, good cables, good ground, then isolate circuits by pulling fuses, and working through one by one. Yuck!!!
  6. May 23, 2017 at 8:40 PM
    Nfarrall
    Nfarrall Well-Known Member
    Chester county, PA
    2017 QS DCSB SR5
    Sounds like a short to power somewhere in one of the harnesses.
