I've got around 1K to spend, what to do first...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Colt4587, Jul 21, 2016.
  1. Jul 22, 2016 at 7:40 AM
    #41
    MSU Taco
    MSU Taco More cowbell
    Roger
    Mississippi
    05 DCLB 4x4
    So in your opinion what's the max recommended notch for 5100 (already installed for leveling) to prevent cv/ball joint issues? Also do you think the OE uca and lca could be retrofitted with uniballs as an alternative to spending $1000 on arms. I intend on doing icon progressives in the rear and adding 5100s in the rear as well and going with some 265/75 open country R/T
  2. Jul 22, 2016 at 7:41 AM
    #42
    MSU Taco
    Roger
    Mississippi
    05 DCLB 4x4
    I have a company vehicle so my truck may get driven once or twice a week tops. My off-roading consists of hunting mostly but I do like to "play" a bit on the camp trails lol
  3. Jul 22, 2016 at 7:48 AM
    #43
    Pigpen
    Dan
    Northwest Montana
    If you want to use the stock coils, I wouldn't go past the 1.75" setting. After that you'll get poor ride characteristics from the stock spring. Adding a 1/4" plate to both sides will get you just over 2". Your CVs and steering components will be fine, but you will probably get the droning diff vibe and might want to do the ECGS bushing.
    I wouldn't do uniballs. They're high maintenance and you can get better articulation with the LR UCAs for that money (or less) and they have a grease fitting on the ball joint. The only thing I would do to the lowers is pull the alignment hardware (mark it and do one bolt at a time so you don't need to get a new alignment), and anti-seize the hell out of them. The main reason I just did a full refresh on my front suspension is that I had to cut out my LCAs due to being seized.
    MSU Taco[QUOTED] likes this.
  4. Jul 22, 2016 at 7:57 AM
    #44
    MSU Taco
    Roger
    Mississippi
    05 DCLB 4x4
    Wish I had the coin to do a SAS, 3/4 link and some icon/king shocks but mortgage, car notes, & kids say otherwise lol. Welcome to life, right haha
  5. Jul 22, 2016 at 8:39 AM
    #45
    Colt4587
    Colt4587 [OP] Well-Known Member
    Colt
    2015 Red Tacoma TRD Sport
    OK @58 Siesta
    To recap, hold off on the tires for now, get some 5100's to level it out, and once I've done that save get tires? What size do you think I should get, Currently at 265/65/r17.
    I apologize if I missed something, thread kind of blew up :)
  6. Jul 22, 2016 at 8:53 AM
    #46
    PoweredBySoy
    PoweredBySoy Well-Known Member
    Jesse
    Minnesota
    2013 DCSB SR5
    /thread
    IronPeak and Colt4587[OP] like this.
  7. Jul 22, 2016 at 9:07 AM
    #47
    Colt4587
    Colt
    4 5100's?
    Thanks bud ;)
  8. Jul 22, 2016 at 9:52 AM
    #48
    TacoRph
    TacoRph How 'bout them Dawgs
    2015 MGM TRD OR 4WD
    You're welcome. It gives me a lot more confidence in the tailgate. I have also been looking at various suspension lifts. For what it's worth, I'm leaning toward purchasing the entire TRD Pro suspension kit. This kit should raise the front about 1.75 inches. In addition, I would be installing an ICON aal to raise the rear and preserve rake. From what I've read on TW, this route is not the most cost effective solution, but I like this kit because it provides a mild lift up front, and it's an OEM package. Good luck, and have fun!
  9. Jul 22, 2016 at 5:28 PM
    #49
    Soflanick
    Soflanick Well-Known Member
    Nick
    FLORIDA
    2001 tacoma prerunner
    5100 front, 5125 rear, 2"all, old ARE topper, 16x8 XD enduro's on 265/75r16 KO2's
    how is that not first mod stuff? lift and tires? a little chop to make them fit if you'll really actually need it
  10. Jul 23, 2016 at 7:47 AM
    #50
    Pigpen
    Dan
    Northwest Montana
    Depending on the tires you choose, you might be able to do a set of load c 265/70/17and 5100s for the front for about $1K
    Colt4587[QUOTED][OP] likes this.
  11. Jul 23, 2016 at 7:53 AM
    #51
    Pigpen
    Dan
    Northwest Montana
    The OP doesn't really seem to know what direction the build is going. This isn't a " what's the largest tire..." thread.
    I'm glad I never went to wide tires. I like how they look, but I'm glad I never did any cutting. Many people are happy to do it. It's just not something I suggest for first mods when people aren't sure what they want.
  12. Jul 23, 2016 at 10:22 AM
    #52
    Pigpen
    Dan
    Northwest Montana
    Colt4587[OP] likes this.
  13. Jul 23, 2016 at 10:25 AM
    #53
    Greenbean
    Greenbean B.S. Goodwrench
    Zack
    Western NC
    2015 AC 2.7L 5-spd 4x4 Utility Package
    Billies on the front set at .75,
    Then BF Goodrich C-rated KO2s. 265/70/R17
    Use the left over to go get ice cream or beer!
    Pigpen and IronPeak like this.
  14. Jul 23, 2016 at 10:41 AM
    #54
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    I vote for A whole host of Mobtown Offroad products.
    1. Tailgate Reinforcements
    2. Skid plates
    3. Rock sliders
    4. Bumpers
    But I guess I'm a little bit biased.
    www.mobtownoffroad.com
  15. Jul 23, 2016 at 10:46 AM
    #55
    Soflanick
    Nick
    FLORIDA
    its not a big deal to cut some plastic, actually usually lifting and adding tires to any vehicle usually involves cutting at some point. its the norm. Modifying is modifying... buy once cry once.
    Colt4587[OP] and Pigpen[QUOTED] like this.
  16. Jul 24, 2016 at 5:28 PM
    #56
    rmepilot
    rmepilot Well-Known Member
    Rob
    Huntsville, AL
    '23 LR DCSB TRD OR 4x4 Premium Pkg
    2019 Jeep GC Summit 5.7l '15 DCLB S/C 4x4 Limited Pyrite Mica - Deceased
    I'm considering the same setup, but just starting with the TRD Pro suspension, then go with an AAL and maybe 1/4" spacers upfront at a later time. Still doing research though.
  17. Jul 25, 2016 at 8:09 AM
    #57
    Colt4587
    Colt
    Thanks for all your help man. I really appreciate it. Sorry I didn't respond 'till today. Had a weekend out on the lake :)
    And yeah, not for sure where I'm going with it. Although I'm definitely thinking new tires are going to be first on the list. Got a little bit of rain here in KS today, and tires broke loose a couple of times just trying to move forward from a stop light :burnrubber:
    Pigpen[QUOTED] likes this.
  18. Jul 25, 2016 at 11:03 AM
    #58
    Colt4587
    Colt
    Thanks for the advice! It's mostly a city truck for the moment. But there are some trails in the area that I hope to eventually be on, I will be checking out the website then for sure :)
    jowybyo[QUOTED] likes this.
  19. Jul 25, 2016 at 11:10 AM
    #59
    jowybyo
    Joe
    Baltimore, MD
    My bumpers only seem to get damaged in the city. Damn bump parking jobs. Haha.
