I've got the 2014 Taco double cab Limited with 18" rims. What's the biggest tire size I can have ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Sean4X4, Jan 15, 2019.
  1. Jan 15, 2019 at 6:58 PM
    Sean4X4
    Sean4X4 [OP] Member
    Sean
    2014 Silver Tacoma LTD Double Cab Long Bed
    I've got the 2014 Taco double cab Limited with 18" rims. What's the biggest tire size I can have on the same rims without lifts, spacers or potential rubbing ?
  2. Jan 15, 2019 at 7:22 PM
    R490
    R490 Well-Known Member
    Upgrayedd
    VA
    p l e a s e u s e t h e s e a r c h f e a t u r e
  3. Jan 15, 2019 at 7:23 PM
    Matmo215
    Matmo215 Well-Known Member
    Matthew
    Waco, TX
    2015 Sport DCSB
    Google is your friend
    Tacotim0321 likes this.
  4. Jan 17, 2019 at 11:59 AM
    Sean4X4
    Sean4X4 [OP] Member
    Sean
    If I didn't make myself clear.
    I can NOT find anything in the search matches MY SPECIFIC TRUCK MAKE & MODEL & that's why I created this thread.
    BassAckwards likes this.
  5. Jan 17, 2019 at 12:26 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Doesnt matter what 6 lug truck you have they all have the same physical size wheel well and spacing of components surrounding the area the limit OUTER diameter size. Biggest tire you can go with without any rubbing issues is going to be a 265/75R16 or 265/70R17.... which if you take a quick minute to put that into the tacoma world tire size calculator ( https://www.tacomaworld.com/tirecalc )and find the matching OD for an 18 in rim you come up with a 265/65R18
  6. Jan 17, 2019 at 12:46 PM
    Sean4X4
    Sean4X4 [OP] Member
    Sean
    Thank you very much nd4spdbh.
    That was an excellent detailed explaination which I truely appreciate. Thanks a lot.
  7. Jan 25, 2019 at 6:42 PM
    4x4cajun
    4x4cajun Well-Known Member
    Fredericksburg, VA
    2014 Limited 4x4
    CHEVERLY my service dog! Lol
    That’s what I have on my limited!
    Casper66 likes this.
  8. Jan 26, 2019 at 3:26 AM
    topcathr
    topcathr Well-Known Member
    2015 limited
    My 2015 Limited has 265 60 18 and there is lots of room for larger tires. I keep things stock so maybe someone knows the exact size.......
  9. Jan 26, 2019 at 6:50 PM
    GREENBIRD56
    GREENBIRD56 Well-Known Member
    Casper / Tucson
    014 Taco 4Dr 4wd
    My limited has a set of 255/70/18's on the factory rims ......32 inches tall.
  10. Jan 26, 2019 at 7:48 PM
    Pigpen
    Dan
    Northwest Montana
    That's a skinny slice o' rubber
  11. Jan 27, 2019 at 7:08 AM
    GREENBIRD56
    Casper / Tucson
    014 Taco 4Dr 4wd
    Yeah - 265/60/18 was .33 wider and 1-1/2 inches shorter. And I wanted the 3/4 inch taller sidewall to get the sills and diff up. They ride a bunch better on the road and my outfit is a DD.
    Eyeballing the before and after pics you can't see the .33 width change.
  12. Jan 27, 2019 at 7:13 AM
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    '15 DCSB TRD Sport 4wd super white (sold) '13 access cab SR5 4wd
    piddly stuff
    Hey! Hi from Culpeper you k ow we have some local threads also 1 rt in F’burg
    4x4cajun[QUOTED] likes this.
  13. Jan 27, 2019 at 8:10 AM
    road2cycle
    road2cycle Well-Known Member
    Sonoma County, CA
    2014 Tacoma DCLB 4x4 Limited
    If you change out to 16” or 17” rims you’ll have more tire choices. I switched to the T4R Trail Edition 17” rims when I found the pickings to be slim for the Limited’s 18” rims.
  14. Jan 27, 2019 at 11:42 AM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    265-65-18.
  15. Jan 28, 2019 at 2:45 PM
    4x4cajun
    Fredericksburg, VA
    2014 Limited 4x4
    I was not aware of that. How do I touch base?
    Casper66[QUOTED] likes this.
  16. Jan 28, 2019 at 2:46 PM
    hyper15125
    hyper15125 Headlight Retrofitting Hobbyist Vendor
    NJ (609)
    265/65-18
    TegoTaco likes this.
  17. Jan 28, 2019 at 4:45 PM
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
    NOVA is by far the most active
    https://www.tacomaworld.com/threads/northern-virginia-roll-call.188512/
    This is your more local thread. The issue is we are all spread out from King george over here to Culpeper and down toward Charlottesville and even around Richmond but it is centralized around F'burg
    https://www.tacomaworld.com/threads...-between-the-north-and-the-true-south.452145/
    Both have good guys alot of Veterans and even some of us older guys
