I've gotten my self confused.....
Discussion in '2nd Gen. Tacomas (2005-2015)' started by arock, Aug 22, 2014.
  1. Aug 22, 2014 at 1:56 PM
    arock
    arock [OP] Well-Known Member
    MD
    2020 Cement TRD Off-Road
    So I have been reading and researching about suspension and tires on here for over 3 months now and all the info is starting to jumble together in my brain. I think that I have gotten most of it figured out except.....
    If you want to run 33's on a 2-3 inch suspension lift and you replace the upper control arms do you still need to run wheel spacers if you want to keep your stock 16" wheels?
  2. Aug 22, 2014 at 2:07 PM
    mAtTyG04
    mAtTyG04 Well-Known Member
    Edmonton
    2019 Quick Sand OR
    6112 Front Suspension, Fox 2.0 Rear Shocks, Nitto Ridge Grappler - LT285/75R17 C, Rear Blackout Tacoma Badge, De-badged, Icon Rebound Wheels, TRD Grill Gights, CBI Ditch Light Brackets w/ Baja Design Lights, Husky Liners, JBA UCAs, Geenlane Off-road Sliders, Tacotrooper Decal, DuraBump Rear Bump Stops, Pro-clip USA Phone Mount
    As far as I know yes. You will be rubbing the UCA's without spacers on stock wheels. A 1.25 spacer will fix that.
  3. Aug 22, 2014 at 2:19 PM
    medic2230
    Murph
    Bama! Roll Tide
    I'm running 33's on a 3" OME lift and I will only rub the UCA's when at almost full droop. I do rub the LCA at full lock on the passenger side. I have the stock 16" wheels.
  4. Aug 22, 2014 at 2:48 PM
    arock
    MD
    That's what I thought but I wanted to make sure. Thanks
