I've had it with the OME's
Discussion in 'Suspension' started by MontanaTaco, Oct 11, 2010.
  1. Oct 11, 2010 at 6:51 PM
    MontanaTaco
    MontanaTaco [OP] Well-Known Member
    Colter
    Relocated to Albany, NY
    14 DCLB Sport
    OME lift
    Ok so I recently bought some ome 885s and the nitro 90000s and put them on my truck. I am starting to hate the way my truck rides, it is more stiff and bumpy than any 3500 I've ridden in. I even get a headache when driving on bumpy roads for long periods of time.
    My question is there a way of loosening them or am I going to have to get something different?
  2. Oct 11, 2010 at 6:53 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    Your gonna have to do something different or find a way to beat those springs down. You might be able to find a member with 884's and possibly do a straight trade with them! I had 884's and they rode pretty soft but harsh at the same time because my 4 banger doesnt have as much weight up front. Are you running the top plate spacer up front as well? Maybe take that out and see if the ride improves?
  3. Oct 11, 2010 at 6:54 PM
    rcbs204
    rcbs204 Well-Known Member Vendor
    Stock FTW! Sorry your having issues bro.
  4. Oct 11, 2010 at 6:58 PM
    08pretaco
    az
    Stock is lame and no fun! OP you could just sell the front suspension and get 5100 set at 1.75" and be happy
  5. Oct 11, 2010 at 7:58 PM
    jr114
    jr114 Well-Known Member
    Jon
    SoCal
    Truck
    Icon Ext travel CO, Icon tubular uniball UCAs, Maxtrac Spindles, Icon RR rear w 2"aal.
    maybe try a different spring. 884?
  6. Oct 11, 2010 at 8:03 PM
    Fluffymonkey
    Fluffymonkey Token
    College Station, TX
    2013 Trd Sport DC, 07 DC sr5, 03 Prerunner
    2003: Stock 2007: Avid Offroad sliders, 30% front tint, bed mat, Truxedo low-pro qt tonneu cover, aero turbine 2525 muffler w/ 8'' tip, AR25 Resonator, 16x8 Dick Cepek DC-1 w/ 265/75 Goodyear Wrangler Duratracs, 2010 headlights, ome 884 coils with .5'' top plate spacer, OME sport front shocks, bilsten 5100s rear, 2'' aal, locking gas cap, LR ucas, Viper 2-way remote start, afe drop in filter, Rocky locking bike mounts, gear chest, scangauge, pop n lock tailgate lock 2013: most things transferred over from my 07, 5100s @ .85 + eibachs and Toytec tps for 3'' front lift, wheelers progressive aal w/ overload; compustar 2-way remote start; Antennex shorty antenna, pop n lock tailgate lock with programmable key, seat covers, Toyota's crappy all-weather floor mats (should have got Husky's or Weathertechs), TRD skid plate, led light pods mounted in front bumper valence w/ Eyourlife wireless harness and remote, led bed lights, light pods mounted in bed, Devil Horns emblem from Diaz Fabrications, rear facing pod lights in bed, under seat lights,
    i was told the 884s and 885s were the same spring rate, the 885s are just longer so you get more lift, whereas the 884s are only set to give you around 2'' of lift without the top plate spacer. So you might have to just go with something different altogether.
  7. Oct 11, 2010 at 8:07 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    According to Toytec the 884's are for the single and extended cabs. The 885's or for the double cabs. My impression is that the 885 has a slightly higher spring rate, enough to handle the double cab and provide the same amount of lift on the proper vehicles.
  8. Oct 11, 2010 at 8:09 PM
    hendooman
    hendooman The Stroker Ace
    Jeff
    KC
    2009 Tacoma OR (SOLD); 2015 TRD PRO 4Runner
    Toytec TRD PRO LIFT with 1.5 SAW in rear, 255 Coopers, Baja Rack, Southern Style Front Bumper, Warn Wireless Winch, DeMello Sliders.
    I thought the 885's were more for DC's? You might need to go 884's.
  9. Oct 11, 2010 at 8:10 PM
    MontanaTaco
    Colter
    14 DCLB Sport
    OME lift
    Yeah I don't want to spend a ton on new shocks...so I was thinking 5100's but I kinda want a little more lift...like 3.5".
  10. Oct 11, 2010 at 8:12 PM
    jr114
    Jon
    SoCal
    Truck
    more lifts not gonna happen from springs and shocks. gonna have to do a drop bracket kit or spindles if your 2wd. if you think it rides harsh now itll ride even worse if you try to get 3.5 outta springs and shocks.
  11. Oct 11, 2010 at 8:12 PM
    Jigzor
    Jigzor Well-Known Member
    Pennsylvania
    20 Gladiator Rubicon
    Steersmarts Draglink, Tie rod, Track Bar
    3.5"? Go with the RCD lift.
  12. Oct 11, 2010 at 8:14 PM
    hendooman
    Jeff
    KC
    I would just sell the 885's and get the 884's. OME is known to be a better ride than 5100's. I am pretty sure no matter what suspension you get you are not going to be happy with the ride at 3.5", that is a lot of front lift for these trucks.
  13. Oct 11, 2010 at 8:14 PM
    LBtaco
    LBtaco Thread killer
    Long Beach , CA
    15 Nissan Leaf
    Jetsons mod
    'I dont think you're going to get that amount of lift and a 'smooth' ride, unless you got spindles. but yeah I have Icons and the stiffness is starting to bug.
  14. Oct 11, 2010 at 8:29 PM
    DTacoms
    DTacoms Well-Known Member
    Frisco, Texas
    05 4x4 DC LB BSP
    If you wanted that much lift from COs, it's going to be stiff. I had 5100 with stock spring; it was soft but then it's at 1.75". Now I have ICON at 3", I hate the stiffness but I have to live with it to fit 33".
  15. Oct 11, 2010 at 8:39 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    The 884's and 885's are the same spring rate, but the 885's are longer, thus preloaded a little more when installed on the shock, than the 884's.
  16. Oct 11, 2010 at 8:41 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    I stand corrected. Thank you sir, its nice when people are there to cover your ass.
  17. Oct 11, 2010 at 8:57 PM
    kinkrider101
    kinkrider101 Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
    use spindles for 4" and stock suspension!
  18. Oct 11, 2010 at 8:58 PM
    KenpachiZaraki
    KenpachiZaraki Its Wicked Flow BITCHES!!
    Alex •﹏•
    Lubbock
    05 TRD. 325/275/365 SBD
    ALL POSER- Afe Pro Dry S drop in filter, 3" AP leaf pack, Eibach w/5100's up front, 5100's rear, Fog Light Mod, ABS off mod, Dash Light MOD, Doug Thorley Long Tube Headers, Wicked Flow Bitches MAX Muffler, 4" floods, 20", 43" light bars, 265/75/16 Hankook Dynapro ATm, oil catch can, rear diff breather relocate, Custome Sliders, SOS concepts Front bumper, Demon Eye Mod, backlit TRD emblem on bumper, Morimoto D2S projectors,
    Go with o.e. Blown shocks for ultimate softness! :D
  19. Oct 12, 2010 at 8:50 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Put a few hundred pounds of gear in the front of your truck bed.
  20. Oct 12, 2010 at 9:17 AM
    MontanaTaco
    Colter
    14 DCLB Sport
    OME lift
    Someone mentioned spindles. Have any suggestions?
