Ive never wondered...factory alarm
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 93civEJ1, May 20, 2013.
  1. May 20, 2013 at 4:28 PM
    93civEJ1
    93civEJ1 [OP] Well-Known Member
    09 DC TRD OR
    Procomp 6" Stage 1, Bilstein 5100's in front, flowmaster 40 series
    I have a hornet alarm system in a box that i purchased a long time ago that I never installed in one of my vehicles. I found it today.
    I was wondering if I could put it on my tacoma....but then I thought, but maybe mine already has factory alarm options?
    It has keyless entry already, so what would the point be of having another aftermarket one to control it?
    My truck beeps when I lock the doors. (leave a door open and hit it and it stays solid beeped)
    Unlock the doors but never open one and it locks itself back.
    When locked of course the little red light on the dash flashes the truck with the key looking light.
    What dont I know about this thing or is that about it?
    If you install an aftermarket alarm and it lets you unlock your doors and all that, do you just stop using the factory one? What am I missing here?
  2. May 21, 2013 at 8:01 AM
    93civEJ1
    09 DC TRD OR
    Tons of people look but not 1 person responds. Way to help a bro out.
  3. May 21, 2013 at 8:05 AM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    As far as I know, (little at that), if you have someone put in an aftermarket alarm system, it uses the same sensors as the dealer one...maybe they add a couple more...but whoever installs it should be disabling the dealer alarm so that the new one takes over. Or you get two alarms. That's cool!
  4. May 21, 2013 at 8:09 AM
    carcharias
    carcharias Giggiddy what what
    Los Angeles, CA
    SOLD: '11 AC MGM OR
    Kings all-around w/ 700lb coils, Dakar leaf pack, TC uca's, DO single hoop bumper, BAMF bolt-on sliders w/ kickouts, Rigid 20" e-series spot/flood, aFe pro-dry, BFG KM2 255/85/16, silver TRD FJ wheels, WARN M8000-s, Access LE, Grillcraft, BAMF lightbar, BAMF rear dif skid, BAMF LCA skids, window tint, Wet Okoles, WeatherTech floorliners, Silverstar lights, led dome lights, Redline Tuning hood struts, center console lock mod, mag-lite mod, extra d-rings, re-routed exhaust, ATO skids, ATO Hi-Lift mounts, pipe tailgate lock, seatbelt alarm delete, wheel/spare locks, Viper 5901, LoJack... WISHLIST: a golden canary that poops platinum
    Mine no longer uses the factory alarm due to the aftermarket one. The Viper added a few more sensors as well as another speaker. It also offers things (remote start, for example, and 2-way communication to the truck) that the factory alarm doesn't offer. All for pretty darned cheap (see my build thread). Much happier with this one.
  5. May 21, 2013 at 8:10 AM
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    Sale your one in the box.
    Dont think its going to work the same as stock.
    Yes disconnect your old one. One another would conflict and the horn would not stop sounding.
    Why would u want to replace it anyway. For basically the same.
    Remote start and those whistles why not.
  6. May 21, 2013 at 8:12 AM
    93civEJ1
    09 DC TRD OR
    I dont even know that I have a factory one. Thats what I am trying to find out.
    All it does is beep if I lock / unlock doors and those little things.
    How can I find out otherwise if it does anything else?
  7. May 21, 2013 at 8:13 AM
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    The things you described are consistent with just factory keyless entry and auto locks. None of that is specific to an alarm system.
  8. May 21, 2013 at 8:16 AM
    93civEJ1
    09 DC TRD OR
    Thats what I was thinking.
    I am not sure anything would happen if say I broke into my truck or busted my window. (not going to try to find out)
    :p
  9. May 21, 2013 at 8:21 AM
    VolcomTacoma
    Jeff
    NorCal
    Well. My truck was broken in to...alarm was still active...they smashed in my passenger side window and apparently crawled in and tossed my truck...alarm was still active when I found it in the morning...so that tells you how good the factory system is...
  10. May 21, 2013 at 8:41 AM
    AZDesertTRD
    AZDesertTRD Well-Known Member
    Pamela
    Arizona
    2012 PreRunner Sport
    Sounds like you simply have keyless entry. To double check if there is any alarm triggers, sit in the truck, lock the doors with the fob then try opening the door. Most alarms will be triggered with a door opening. You can also pound firmly on a window to see if there is a shock sensor (with the doors locked of course.)
    Some models have a anti-theft chip in the key making stealing the truck a little difficult but not much I'm sure.
  11. May 21, 2013 at 8:43 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    roll windows down
    lock it up
    reach in and open the door ...what happens ?
  12. May 21, 2013 at 8:50 AM
    ExtremeCustoms505
    ExtremeCustoms505 Well-Known Member
    Albuquerque WS
    2010 Tacoma 4d 4x4
    3" Revtek spacer kit in front w/ aal and 1" block in rear. No TSB aal installed yet. Spider Trax spacers.
    OP What you have described is nothing more than toyotas Keyless Entry System. I have the same one on my Tacoma also.
    It does nothing more than the locking/unlocking of the doors. If you want something that is going to alert you of a break in you will need to go with an aftermarket system, in which you would have a multitude of options you can use such as remote start, multiple shock sensors, tilt sensors, and lots of others.
    Hope this helps you out.
  13. May 21, 2013 at 8:54 AM
    GREEKBOY12295
    GREEKBOY12295 Well-Known Member
    Nick
    Phoenix, AZ
    2005 Toyota Tacoma PreRunner
    Radflo 2.5 Coilovers, Viper Alarm 5902, Bilstein 5100's, Polk Speakers, Blacked out grille and Emblems, All Pro 3" leafs, Pioneer AVH-4300 Double Din, BHLM, 4" Maxtrac Spindle, Aero Turbine 2525xl, Ultra Gauge, Rockford Fosgate 300 mono amp, 10" Kicker CVR
    I have a viper alarm and its awesome. Id recommend that. My friend only reached inside my truck and it set off the alarm. It has a pager so it tells me my alarm is going off within half mile or mile depending on the buildings around.
