I've really done it this time
Discussion in '2nd Gen. Tacomas (2005-2015)' started by The Tricky Jew, Aug 16, 2014.
  1. Aug 16, 2014 at 9:14 PM
    The Tricky Jew
    The Tricky Jew [OP] Member
    In the attempt to add led map lights to my cab, my map and dome lights won't turn on even with stock bulbs back in them. Did I break something? How do I "reset" the fuse if that's the problem? Thanks
  2. Aug 16, 2014 at 9:15 PM
    1993t100
    1993t100 I’m good looking and I drive a Jeep.
    Big Sexy
    Nebraska
    Jeep Wrangler Rubicon
    Did you put the bulb back in right?
  3. Aug 16, 2014 at 9:17 PM
    The Tricky Jew
    I put it in both ways flipped 180 degrees
  4. Aug 16, 2014 at 9:17 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    Sounds like you may have blown a fuse, most likely in the drivers side foot well area.
  5. Aug 16, 2014 at 9:19 PM
    BulletToothTony
    BulletToothTony You’ll have that on these big jobs.
    You can call me Susan if it makes you happy.
    Check your fuses
  6. Aug 16, 2014 at 9:20 PM
    The Tricky Jew
    If that's the case do I retry the same led bulbs afterwards or would that be a dumb mood thing to do
  7. Aug 16, 2014 at 9:49 PM
    SWB Tacoma
    SWB Tacoma Well-Known Member
    Arkansas
    2017 Tacoma Limited DC AT SB 4x4
    Depends on how many fuses you have on hand.
  8. Aug 16, 2014 at 9:51 PM
    The Tricky Jew
    Thanks everyone. Any suggested 06 map light leds that don't blow fuses?
  9. Aug 16, 2014 at 9:53 PM
    1993t100
    Big Sexy
    Nebraska
    superbrightleds.com
  10. Aug 17, 2014 at 4:38 PM
    JPS11
    JPS11 Active Member
    Melbourne, FL
    2011 Prerunner DC TRD OR Black
    I just had to pull the fuse when I installed my interior LED's. Once they were installed I never blew the fuse.
  11. Aug 25, 2014 at 6:50 PM
    The Tricky Jew
