I've searched but...4L but no 4H.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Leer, Aug 9, 2011.
  1. Aug 9, 2011 at 11:56 PM
    Leer
    Leer [OP] Well-Known Member
    Lee
    Hilo HI
    2015 Tacoma 4x4
    I've just had this truck a few days now and before I bought it, I did test the 4wd in the parking lot, but I only tested the 4L figuring that was enough.
    So now I figured I'll throw her in 4H but it was a no go. I turn the switch, but no indicator light on the dash. I tried it at several speeds and even in neutrel but still no indicatir light.
    I can put it in 4L and that is still working fine though. Any ideas?
  2. Aug 10, 2011 at 12:22 AM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    Check the plugs on the transfer case that work you indicator lights,
    one could be unplugged or something :thumbsup:
    If not that then test to see if you have power to your front wheels in both
    4hi and 4lo.
  3. Aug 10, 2011 at 1:24 AM
    Leer
    Lee
    Hilo HI
    2015 Tacoma 4x4
    Thanks, I'll check that out. BUT 4H isn't even engaging. I can feel it in 4L but when I switch to 4H nothing at all happens!
  4. Aug 10, 2011 at 8:12 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    You do understand, that driving straight the 'feel' of H4 is the same as 2WD... L4 'feels' way different because it is a much, much lower gear like for crawling...
    What will feel different in H4 is when you try to turn tightly on pavement... If there is resistance and a struggle, then you are indeed in H4!
  5. Aug 10, 2011 at 8:16 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Yeah-There is no way to get to 4L without 4H engaging. You aren't going to feel anything really different unless you try to make tight turns-
    Do you get 1 light or 2 when Lo is engaged??
  6. Aug 10, 2011 at 8:20 AM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    I could be wrong but I don't think you can even get into 4lo with getting in 4hi first. Like mentioned you were probably already in 4hi but never knew it since the light on the dash didn't light up.
  7. Aug 10, 2011 at 8:23 AM
    tig1
    tig1 Well-Known Member
    Paul
    Saint John,New Brunswick,Canada
    2009 tacoma
    n fabs,window visor tonneau ,bilstein 5100's all round.245/75R16Toyo A/T II
    my problem is the other way. I got 4H but no 4L,same thing light flashes and truck stays in 4H.
    later tig1
  8. Aug 10, 2011 at 8:29 AM
    MxRacer190
    MxRacer190 Well-Known Member
    Georgia
    06 SR5 4x4 Indigo
    Try completely stopping and put it into neutral before switchinig to 4Lo
  9. Aug 10, 2011 at 9:10 AM
    Leer
    Lee
    Hilo HI
    2015 Tacoma 4x4
    Thanks for the help guys. The only way I can get into 4L is to stop and put it in neutral. Then I switch it to 4H and nothing, not light no nothing. I can tell it's not engaging. Then I push in the switch and go to 4L and I get the 2 lights that come on, the truck and the Low.
    I am familiar with the way a truck feels once the front tires are engaged, I had 2 older toyota 4x4's. I can definately tell that 4H is not engaging at all no matter if I try to get it in at 50 mph, 40 mph, 30 mph, 20 mph, from a dead stop or even from a dead stop in neutral.
    I'll play with its ome more just in case I am wrong and it is actually engaging without the light, but it sure hasnt felt like it so far!
    Thanks again everyone!
  10. Aug 10, 2011 at 9:11 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    how do you know its not going into 4 hi? like what are you doing?
  11. Aug 10, 2011 at 9:14 AM
    kinkrider101
    kinkrider101 Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
    Maybe you should check the wiring, could be a bad switch
  12. Aug 10, 2011 at 9:18 AM
    Bfoster133
    Bfoster133 If i asked my dad for money, He'd knock me out
    Blake
    Thousand oaks, California
    2011 PreRunner TRD offroad
    15% Tint, 5100's at 1.75, Rear Diff Breather, CB radio, Black rattle canned rims, 265/75/16 Goodyear MTR, Magnaflow Offroad pro cat back, hi-lift bed mounted, shovel bed mounted
    shove it up on some jacks :D hahahaha see if the wheels spin. that might be dangerous
  13. Aug 10, 2011 at 9:23 AM
    Leer
    Lee
    Hilo HI
    2015 Tacoma 4x4
    Well when I put it in, (lol put it in) I slow down and I guess kinda give it gas while I swerve a little so I should feel it in the handeling and when I give it gas right?
    I'll do that today!
    Who knows, that might be an option!
    To tell you the truth, I haven't noticed. I'll check that out too!
  14. Aug 10, 2011 at 1:15 PM
    MAPLENUTS
    MAPLENUTS Well-Known Member
    STEVEN
    East Coast, USA
    TRD SPORT TACOMA 4X4 L/B
    Stock
    I thought mine was not working at first. Turned out that the bulb was out, because it did not light up. I had the dealer replace a total of 5 dash bulbs for the 4WD switch among other things. True, check to see if you feel resistance when cutting hard on the steering wheel, like the truck wants to hop. I would still want my 4wd indicators working anyways.
  15. Aug 12, 2011 at 8:12 AM
    tig1
    Paul
    2009 tacoma
    yeah, I tried it in every way it has got to ceased.:confused:
    later tig1
