J shift t case rebuild
Discussion in '1st Gen. Tacomas (1995-2004)' started by anthony250f, Dec 21, 2015.
  1. Dec 21, 2015 at 8:52 AM
    anthony250f
    anthony250f [OP] Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Has anyone ever re built the j shift t case? Mine makes a grind/whirring sound only in 4lo
  2. Dec 23, 2015 at 11:06 AM
    anthony250f
    Anthony
    San Diego, CA
  3. Dec 23, 2015 at 2:58 PM
    Ritchie
    Ritchie Well-Known Member
    San Diego (North County)
    RC Step side Pre-runner
    2.7 w/auto, 4WU 3 link, F & R Diamonds, ARB's F/R w/ Yukon 5.29's, Inchworm 4.7 Lefty, Deavers, ARB OBA, Schrockworks up front.
    My Inch Worm has made a similar noise since new.
    One thing I noticed: my shifter is part of it. While driving, I can move the shifter around slightly and the noise quiets down a bit. For me, it's the actual shifter resonating noise from the 4HI shift rod.
    Could that be what you're hearing?
  4. Dec 23, 2015 at 3:03 PM
    anthony250f
    Anthony
    San Diego, CA
    I can try that...mines like a metallic howling type sound...only in 4lo
  5. Dec 23, 2015 at 3:09 PM
    Ritchie
    Mine does bother me... I've been thinking of a way to 'dip' the tip of the shifter in a Teflon based material to eliminate the noise transfer.
    It functions properly regardless. No bearing issues at all. Everything has been re-built so that isn't the issue.
    Good luck with that.
  6. Dec 23, 2015 at 3:11 PM
    anthony250f
    Anthony
    San Diego, CA
    I thought it was normal until I heard my friends 98 that made no noise
  7. Dec 23, 2015 at 7:53 PM
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    Any metal flakes in the fluid? If not I would not worry about it. You can also try thicker gear oil. My lefty/dual case makes all kind of racket, thicker gear lube and a louder stereo fixed that problem.
  8. Dec 23, 2015 at 8:03 PM
    anthony250f
    Anthony
    San Diego, CA
    Yeah no flakes...I guess I'll ignore it lol
  9. Dec 23, 2015 at 8:12 PM
    anthony250f
    Anthony
    San Diego, CA
    What did yours sound like ??
  10. Dec 24, 2015 at 5:15 AM
    Ritchie
    What kind of shrink tube did you use?
    I thought of that but was wondering if it would peel and get into the case oil and possibly plug up something?
    Do you have twin sticks? I am contemplating going that route. May look at the shrink tube idea for that when I make the change.
    Thanks.
  11. Dec 24, 2015 at 6:48 AM
    Ritchie
    Ahh, gotcha.
    I was referring to the round tip at the end of the shifter under the base plate.
    I modified my shift handle moving it forward. The weight pushes that tip back against the shift rod which is the source of the noise transfer. If I pull back slightly, the noise is quieter but still there.
  12. Dec 24, 2015 at 6:59 AM
    anthony250f
    Anthony
    San Diego, CA
    People outside my truck say they don't hear anything. But it's super loud inside
  13. Dec 24, 2015 at 7:04 AM
    Ritchie
    Hmm, mine isn't loud, just there.
    When you change the oil, any gunk or metallic pieces?
  14. Dec 24, 2015 at 7:14 AM
    anthony250f
    Anthony
    San Diego, CA
    Nope looked great
  15. Dec 24, 2015 at 7:17 AM
    Ritchie
    Have you read the thread on TTORA started by Phil?
    Without going into details, he did a lot of research and found there was a bearing issue with some cases built in a period of time.
    Perhaps that's your problem, dunno.
    I'll dig it up and post here.
  16. Dec 24, 2015 at 7:20 AM
    anthony250f
    Anthony
    San Diego, CA
    I've searched every crevice of Google. For some reason most other forums don't work on my iPhone. I google click the link and it goes to the home page
  17. Dec 24, 2015 at 8:27 AM
    Ritchie
    Here it is! This video and post from NorcalPR Phil from TTORA:
    https://www.youtube.com/watch?v=nJCwPSAEfGw
    This is with the stock t-case in low range, and the tranny shifting from 3-5. The Whining is normal, it's the crackling/rattling sound that sounds like a loose shifter...
    I had to have the stock t-case in low range, otherwise I'd be driving faster and the road noise is too loud. The crawl box still makes noise at gears between 3-5...
  18. Dec 24, 2015 at 8:48 AM
    anthony250f
    Anthony
    San Diego, CA
    Mine sounds pretty much just like that. Has that same exact whine and when shifting gears then accelerating had a slight Metallic type whine.
  19. Dec 24, 2015 at 8:58 AM
    Ritchie
    I'm wondering if.. I have an A340F auto trans, would it whine if I had the manual trans?
    There is another question to seek answers to, does anyone with an auto trans and 4.7 Lefty have this issue?
    Good luck.
  20. Dec 24, 2015 at 9:01 AM
    Ritchie
    ... I'm assuming you have a gear driven case?
