J shift t case rebuild
Discussion in '1st Gen. Tacomas (1995-2004)' started by anthony250f, Dec 21, 2015.
  1. Dec 24, 2015 at 9:26 AM
    anthony250f
    anthony250f [OP] Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    How would I know? This is my first 4wd lol
    1997 v6 manual
  2. Dec 24, 2015 at 9:27 AM
    anthony250f
    Anthony
    San Diego, CA
    I've driven my friends 98 5 speed and there was no 4lo noise
  3. Dec 24, 2015 at 9:41 AM
    Ritchie
    Ritchie Well-Known Member
    San Diego (North County)
    RC Step side Pre-runner
    2.7 w/auto, 4WU 3 link, F & R Diamonds, ARB's F/R w/ Yukon 5.29's, Inchworm 4.7 Lefty, Deavers, ARB OBA, Schrockworks up front.
    Here is some info from Marlin Crawler:
    How to ID Gear Drive Case
    If you have 7 bolts in the rear cover then you have the gear driven unit.
    If you have 5 bolts holding the rear cover then you have the chain drive unit.
    Bolt #7 is behind the drive shaft and can't be seen in this picture.
  4. Dec 24, 2015 at 9:48 AM
    anthony250f
    Anthony
    San Diego, CA
    I saw that...i didn't know 1st gens could have either? Which one is better? I won't see my truck till after Christmas to check. But i think it's the 7
  5. Dec 24, 2015 at 9:51 AM
    Ritchie
    You should be a driver side drop, correct?
    If that is the original T-case, it probably has a chain driven case. That being the case, there may be a other issues to check out... possibly the 3rd member or ring & pinion.
    Does it whine while you are off the throttle, in gear & coasting?
  6. Dec 24, 2015 at 9:56 AM
    anthony250f
    Anthony
    San Diego, CA
    Drivers side drop...the whine is only in 4lo...2wd and 4hi are silent
  7. Dec 24, 2015 at 9:56 AM
    anthony250f
    Anthony
    San Diego, CA
    The 3rd members are recently built so those are good
  8. Dec 24, 2015 at 10:01 AM
    anthony250f
    Anthony
    San Diego, CA
    image.jpg Looks just like this
  9. Dec 24, 2015 at 10:02 AM
    Ritchie
    OK, perhaps there is an issue inside.
    I have an extra if you want it... just cover shipping.
    Oh, and that is a chain driven case.
  10. Dec 24, 2015 at 10:09 AM
    Ritchie
    Ist gens came with the chain driven case. The gear driven units are an older version. Mine is a gear driven Inch Worm 4.7 T-case.
    As to which are better, don't know but I'm sure there is some debate about them.
  11. Dec 24, 2015 at 10:10 AM
    anthony250f
    Anthony
    San Diego, CA
    You have an extra chain driven drivers drop j shift case?
    Yeah it doesn't sound normal. Sounds like some serious metal on metal
  12. Dec 24, 2015 at 10:21 AM
    Ritchie
    It's not a J shift case but you can work with it to make it so with the parts you have.
    At least the insides are good, no whine.
  13. Dec 24, 2015 at 12:05 PM
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    Does it sound like a manual trans car in reverse while in 4lo? If so that whining noise is normal.
  14. Dec 24, 2015 at 12:07 PM
    anthony250f
    Anthony
    San Diego, CA
    Hmm I may take you up in that...are they easy to take apart??
    Yeah it does but it has more of a grinding type sound...ill have to get a video when my truck is running again
  15. Dec 24, 2015 at 12:08 PM
    #35
    slander
    Hickory, NC
    That's only a problem if you have duals, the op doesn't have duals. Completely different problem.
  16. Dec 24, 2015 at 12:10 PM
    #36
    anthony250f
    Anthony
    San Diego, CA
    I'll ipdate after Christmas with a video of the sound...I've changed the oil before with no change in tone
  17. Dec 24, 2015 at 12:11 PM
    #37
    anthony250f
    Anthony
    San Diego, CA
    I can't find any info regarding servicing this case
  18. Dec 24, 2015 at 1:27 PM
    #38
    Ritchie
    Yes sir... I was more after the noise portion for the OP. Guess I should have made that clear.
  19. Jan 9, 2016 at 5:56 PM
    #39
    anthony250f
    Anthony
    San Diego, CA
  20. Jan 9, 2016 at 7:44 PM
    #40
    slander
    Hickory, NC
    Sounds normal to me.
