J16/j06 recall not being honored by toyota
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Fluffhead1988, Mar 26, 2021.
  1. Mar 26, 2021 at 9:18 AM
    Fluffhead1988
    Fluffhead1988 [OP] Member
    Gabriel
    2018 Cement Tacoma TRD SPORT
    SSIA I have a 2018 TRD Sport manufactured on 1/17/2018, just two weeks shy of the Master cylinder recall (dated 2/2018-11/2018) and they don’t want to honor it, instead seeming to be OK letting me risk my families safety with malfunctioning brakes.
    What do I do? I opened a claim with ToNA, they said the truck does not fall into the specified dates.
    Edit: the truck is having a reduction in brake pedal performance like the recall.
    thanks
  2. Mar 26, 2021 at 9:42 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Are you having issues?
    Toyota knows the parts usage down to individual VINs and batches, esp for something critical in the safety systems.
    If you are not having issues, I would not think twice about it.
    hiPSI, t.hornstra and Aqualoon like this.
  3. Mar 26, 2021 at 9:45 AM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    They won't do the recall because your truck isn't part of the recall. Seems pretty straight forward.
  4. Mar 26, 2021 at 9:45 AM
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    hiPSI and tonered like this.
  5. Mar 26, 2021 at 9:51 AM
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    You drive your truck like nothing is wrong with it because the parts affected by the recall are not on your truck. There is no grace period on defective parts production ranges outside of what the manufacturer may have built into the recall. You're wasting people's time (including your own) by opening a claim.
    hiPSI, TheFang, ugawino and 1 other person like this.
  6. Mar 26, 2021 at 10:29 AM
    Fluffhead1988
    Gabriel
    I call BS, a line of symptoms matching exactly what is going on with the same truck model and year of a recall just a week and a half shy of its release isn’t suspicious to you? I think it’s pretty straight forward, I’m having a reduction in brake pedal performance exactly like that master cylinder recall. Pads rotors lines all checked/replaced and solid. Should not be having this issue especially if they are aware of it.
  7. Mar 26, 2021 at 10:30 AM
    Fluffhead1988
    Gabriel
  8. Mar 26, 2021 at 10:31 AM
    Fluffhead1988
    Gabriel
    unfortunately yes I experienced it last week and it was pretty scary especially with kids in the car.
    tonered[QUOTED] likes this.
  9. Mar 26, 2021 at 10:32 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Then, you are taking the correct approach and have a right to be worried.
    If your VIN is showing up on the NHTSA site, it should be showing up in the Owners section at toyota.com. From there, there should be no question. Just print it, even print both, and head to the dealer. You should get no resistance.
  10. Mar 26, 2021 at 10:33 AM
    CraigF
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    Then report the dealer to NHTSA for non-compliance, that is the nuclear option
    tonered and Fluffhead1988[OP] like this.
  11. Mar 26, 2021 at 10:35 AM
    Fluffhead1988
    Gabriel
    I don’t want have to send it through the stratosphere unless I absolutely have too, not my usual option but for this I’ll try my hardest to get it covered. I’ll update you all as to how it goes. Currently bleeding lines at the dealership to see if it’s air.
  12. Mar 26, 2021 at 10:48 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    If you're having symptoms, are on the list, and being denied, there is only one option.
  13. Mar 26, 2021 at 11:22 AM
    GOTSAND?18
    GOTSAND?18 Well-Known Member
    2020 tacoma trd off road 4x4 Manual
    stock
    Wouldn’t be easier to go to a different dealer and just explain to them the issue you are having . Let them diagnose it . Don’t mention the recall . Best of luck .
  14. Mar 26, 2021 at 11:28 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    No BS. They know down to the individual truck what master cylinder was used. Yours does not have it.
    TX BAJA1 likes this.
  15. Mar 26, 2021 at 11:37 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    But:
  16. Mar 26, 2021 at 12:49 PM
    Fluffhead1988
    Gabriel
    Ah I got you my bad, misscomm on my part.
    good news, they fixed it, free of charge too. Great day.
    Malvolio, hiPSI[QUOTED] and tonered like this.
  17. Mar 26, 2021 at 12:53 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Nice outcome!
    :cheers:
    Malvolio likes this.
  18. Mar 26, 2021 at 1:36 PM
    GOLIVER0131
    GOLIVER0131 TrdMo
    Socal
    '17 Wht Trd OR DCLB(TrdMo)
    TrdPro grille, blackout badges. Pretty much stock.
    I noticed a softish pedal on my 2017 OR. My best mod under $200 is still installing ss brake lines.
    Glad u got it sorted! :thumbsup:
  19. Mar 26, 2021 at 1:55 PM
    GrundleJuice
    Michigan
    2016 TRD Bro
    Probably useful info that should be disclosed initially.
    jsinnard likes this.
  20. Mar 26, 2021 at 2:01 PM
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    Recall is not going to happen for you. Just bite the bullet, fix it and be done. Is it really worth your family's life to fight over this? Master cylinder is not that expensive and can be replaced with bleeding lines in about an hour.
