J66 or U402 Stage 1
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Knapz, Jun 16, 2022.
  1. Jun 16, 2022 at 8:43 AM
    Knapz
    Knapz [OP] Well-Known Member
    El Paso, TX
    2019 DCSB TRDOR / Dual-motor CyberTruck pre-order
    FOX 2.5/2.0 resi & DSC, OVTUNED, Archive Garage hangers,
    Only have the OEM tri-fold cover and a bed mat.
    Current rear setup is: FOX 2.0 985-26-117 Remote Reservoir, Wheeler's MP3a 3 leaf progressive AAL, and factory overload leaf.
    J66 - 10 leafs, military wrap, diamond cut ends, anti-friction pads and four piece bolt through retaining clips.
    U402 Stage I – 9 leafs, military wrap, diamond cut ends, anti-friction pads and four piece bolt through retaining clips. 2-inch lift. Designed for bed weight of 0-300 lbs.
    I'm trying to improve the ride, but see both of these as options. Might just remove overload to see if that makes things better while I decide which one or a deal comes up. Front end currently measures 23" and rear 25.5" center hub to fender.
    Any advise?
  2. Aug 22, 2022 at 9:01 PM
    Baja Action Drone
    Baja Action Drone Do cool stuff, rinse and repeat!
    Gregory
    2021 TRD Off Road Access Cab
    Front ADS 2.5 Coil overs RR w/Clicker. Rear ADS 2.5 piggyback, Camburg 1 1/4 Uniball UCA's,Camburg LCA's Camburg Performance Spindles, Deaver U401 Stage 1 Leaf Pack, BAMF Greaseable Shackels, CaliRaised Rock Sliders/Overland Bed Rack, Method 305 Wheels, Borla S-Type Cat Back & uuuuh, various Pods, Light Bar Rotopax..........
    J66 is fantastic for lighter loads and will give you smother articulation while wheeling. . If you carry more weight or want to load your rig with a rack down the line the U402 stage 1 is a great option. You will love either. Email Marie at Headstrong Offroad with any questions, she is the s**t! Cheers
    Saskabush likes this.
  3. Aug 22, 2022 at 9:15 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Seen a couple of bad orders come out of them, I as an example, received the wrong pack and as a drop shipper it was a PITA getting it corrected.
  4. Aug 22, 2022 at 9:25 PM
    Baja Action Drone
    Gregory
    Wrong pack shipped from Headstrong? I guess it happens, but that blows!
  5. Aug 22, 2022 at 9:34 PM
    Breakdown
    Breakdown Well-Known Member
    I'm happy with my U402. Not sure about the J66. HS does have really good customer service.
  6. Aug 22, 2022 at 9:39 PM
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    J66 is good with little to no extra weight. Speaking from personal experience:
    They definitely sag under any load over 200lbs. Towing isn’t scary or dangerous, but without an overload you will ride the bumpstops. Also possibly loose the little arch they have.
    If you almost never use the truck for a “truck” or tow, and are willing to sacrifice both of these for daily comfort or gravel road plush, they you will be happy.
    Saskabush and Baja Action Drone like this.
  7. Aug 22, 2022 at 10:00 PM
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    100% go U402 stage 1's. The J66 are meant for very lightly loaded trucks and desert speed. I've heard way too many people regret J66's. I've not heard of anyone regretting U402's.
    I have U402's
    JoeCOVA and Sterling_vH111 like this.
  8. Aug 22, 2022 at 10:43 PM
    JoeCOVA
    Joe
    Colorado Springs
    They are a drop shipper so they dont ship anything. They transfer the order and it ships from Deaver.
  9. Aug 22, 2022 at 11:31 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    I wouldn’t put it past that it was Deaver who botched it. I had a few issues getting things shipped and I ordered directly from them. Good stuff and they corrected to right away but it’s happened to a few folks of varying degrees
  10. Aug 23, 2022 at 4:29 AM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    The shocks you got are for a 2-3" lift, so...
  11. Aug 23, 2022 at 6:19 AM
    JoeCOVA
    Joe
    Colorado Springs
    Buddy had the same issue with Dakars. Wrong pack was ordered.
    How did you order direct? They flat out refused to take a direct order when I called them.
